[Nek5000-users] Wall Clock Time
Thu Sep 4 13:09:11 CDT 2014
What compiler and platform are you running on?  Also what MPI
implementation are you using?
Thanks
Katherine
On Tue, Sep 2, 2014 at 4:19 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hello all,
> I'm interested in comparing the wall clock time for a same run with
> different number of CPU's. However, the time output seems to always give 0.
> I have tried using the mpi_wtime and dnekclock functions in the userchk
> subroutine and it has also been giving me 0 for each processor. I have
> included the end of my logfile in this email. The last 2 values of the
> first output line for a time step should give the total wall clock time and
> step wall clock time, but are both showing 0. At the end of the run, total
> elapsed time should be shown, but once again the value output is zero.
> Has anyone figured out a method permitting to obtain the total wall clock
> time?
> Thank you,
> Jérémie
> ----------------------- END OF LOGFILE ------------------------------
> Step     20, t= 4.8774474E-02, DT= 2.4387237E-03, C=  0.501 0.0000E+00
> 0.0000E+00
>              Solving for fluid
>       20  1  4.7138E-02  1.7111E-07  2.7549E+05  15 alph1x
>     20 halpha  15 -1.1778E-03  1.2672E-01  6.1694E-02  1.1588E-01
> 5.4007E-02  5.1022E-02  3.1403E-02  2.4425E-02  1.0726E-02 6.0344E-03
>          20    Hmholtz VELX:      3   2.6011E-13   1.7111E-07 1.0000E-12
>       20  2  3.4534E-02  2.5050E-07  1.3786E+05  15 alph1x
>     20 halpha  15  1.8538E-02  1.0186E-01  4.5783E-02  4.5495E-02
> 4.2007E-02  4.7957E-02  3.7328E-02  2.8192E-02  2.2477E-02 9.2507E-03
>          20    Hmholtz VELY:      3   3.4751E-13   2.5050E-07 1.0000E-12
>    20   15 alpha: -2.7079E-06 -1.8713E-04  3.2842E-03  3.7249E-03
> 2.1355E-03  1.4731E-03  1.7188E-03  3.0469E-03  1.6907E-03 1.1608E-03
>     20  15  4.0387E-03  7.8105E-07  5.1708E+03 alph12
>         20 U-PRES gmres:     13  8.2682E-13  1.0000E-12  1.0390E-09
> 0.0000E+00  0.0000E+00
>           20  DNORM, DIVEX   8.2682338981824994E-013
> 8.2682352659334355E-013
>          20   4.8774E-02  0.0000E+00 Fluid done
>  call outfld: ifpsco: F
>        20  4.8774E-02 Write checkpoint:
>        0      20 OPEN: naca24150.f00001
>        20  4.8774E-02 done :: Write checkpoint
>                               file size =      4.4    MB
>                               avg data-throughput =     InfMB/s
>                               io-nodes =     1
> end of time-step loop
> runtime statistics:
>  total time   9.9999999999999995E-008
>  inv3 time         621   0.0000000000000000 0.0000000000000000
>  invc time          80   0.0000000000000000 0.0000000000000000
>  mltd time        1282   0.0000000000000000 0.0000000000000000
>  cdtp time        1282   0.0000000000000000 0.0000000000000000
>  eslv time          20   0.0000000000000000 0.0000000000000000
>  pres time          20   0.0000000000000000 0.0000000000000000
>  crsl time         565   0.0000000000000000 0.0000000000000000
>  crsl min    0.0000000000000000
>  crsl max    0.0000000000000000
>  crsl avg    0.0000000000000000
>  hmhz time           8   0.0000000000000000 0.0000000000000000
>  spro time          21   0.0000000000000000 0.0000000000000000
>  usbc time          21   0.0000000000000000 0.0000000000000000
>  usbc min    0.0000000000000000
>  usbc max    0.0000000000000000
>  usb  avg    0.0000000000000000
>  axhm time         458   0.0000000000000000 0.0000000000000000
>  advc time          40   0.0000000000000000 0.0000000000000000
>  vdss time         622   0.0000000000000000 0.0000000000000000
>  vdss min    0.0000000000000000
>  vdss max    0.0000000000000000
>  vdss avg    0.0000000000000000
>  dsum time        2139   0.0000000000000000 0.0000000000000000
>  dsum min    0.0000000000000000
>  dsum max    0.0000000000000000
>  dsum avg    0.0000000000000000
>  dadd time           0   0.0000000000000000 0.0000000000000000
>  ddsl time         565   0.0000000000000000 0.0000000000000000
>  solv time         565   0.0000000000000000 0.0000000000000000
>  prep time          20   0.0000000000000000 0.0000000000000000
> #  nid       tusbc       tdadd       tcrsl       tvdss tdsum        tgop
>   qqq    F
>         0  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
>         1  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
>         2  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
>         3  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
>         4  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
>         5  0.0000E+00  0.0000E+00  0.0000E+00  0.0000E+00 0.0000E+00
> 0.0000E+00 qqq
> call exitt: dying ...
> backtrace(): obtained 5 stack frames.
> ./nek5000(print_stack_+0x1a) [0x4fa15a]
> ./nek5000(exitt_+0x1a6) [0x5e6b56]
> ./nek5000(main+0x39) [0x419489]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x2b7993c6076d]
> ./nek5000() [0x4194b9]
> total elapsed time             :   0.00000E+00 sec
> total solver time incl. I/O    :   0.00000E+00 sec
> time/timestep                  :   0.00000E+00 sec
> CPU seconds/timestep/gridpt    :   0.00000E+00 sec
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140904/3288ec65/attachment.html>
