[Nek5000-users] Moab Issues
Thu Oct 9 11:31:02 CDT 2014
Friedrich,
Clearly its not finding the iMeshP_f.h includes. Can you verify
whether the file exists in your installation at
/home/eng/esumgy/moab-4.6.3/include ? If not, you will have to
re-configure MOAB with --enable-imesh and install it again.
If possible, please also upgrade to 4.7 since we had quite a few fixes
and enhancements in the newer versions.
Vijay
On Thu, Oct 9, 2014 at 11:27 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi All,
> I am trying to use moab enabled Nek5000 and have followed all steps
> installing and linking moab, HDF5 and Zoltan together successfully.
> However when I try to run the moab example,
> mpif77 -c  -O2 -r8 -fpconstant -fpp -DMOAB -DPTRSIZE8 -DMPI -DLONGINT8
> -DUNDERSCORE -DGLOBAL_LONG_LONG -I/home/eng/esumgy/nek5_svn/examples/moab
> -I/home/eng/esumgy/nek5_svn/trunk/nek -I./ -DUNORDERED_MAP_NS=std::tr1
> -DHAVE_UNORDERED_MAP=tr1/unordered_map
> -DHAVE_UNORDERED_SET=tr1/unordered_set
> -I/home/eng/esumgy/hdf5/hdf5-1.8/hdf5/include -isystem
> /home/eng/esumgy/hdf5/hdf5-1.8/hdf5/include  -DTEMPLATE_SPECIALIZATION
> -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
> -DHDF5_FILE -I/home/eng/esumgy/moab-4.6.3/include
> /home/eng/esumgy/nek5_svn/trunk/nek/3rd_party/moab.f -o obj/moab.o
> MOABCORE(16): #error: can't find include file: iMeshP_f.h
> moab.f(545): #error: can't find include file: iMeshP_f.h
> moab.f(720): #error: can't find include file: iMeshP_f.h
> And so on...
> The iMesh part I believe is linked to the definition of the Moab directory
> in the makenek file, which I have set up accordingly so I am at a loss why
> it is finding the file.
> I thought it may be a problem with the hdf5 installation which is currently
> just set up in series not parallel so I have tried to play with the
> installation options here, but this does not effect the outcome.
> Thanks,
> Friedrich.
> Nek5000-users mailing list
