[Nek5000-users] gmsh to nek converter
Sat Jun 7 04:48:41 CDT 2014
Dear neks
Using a code from here https://bitbucket.org/mikael_mortensen/nek5000-tools
we wrote a converter from gmsh to rea format. You can find it here
https://bitbucket.org/cpraveen/nek5000
I would be very keen to have others try it out and tell us if there are any
bugs. Currently it works only for 2d meshes. It can also create circular
faces.
See inside gmsh2nek directory. The karman.geo example can be tested
together with the setup files from here
https://code.google.com/p/cfdlab/source/browse/trunk/nek5000/cyl_turek/
Replace the mesh in cyl.rea with the mesh created in karman.rea
To generate karman.rea do the following (use latest Gmsh software)
gmsh -2 karman.geo
python karman.py
Best
praveen
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140607/2e4e0f38/attachment.html>
