[Nek5000-users] how to get vorticity in the post processing
Fri Jun 6 22:18:11 CDT 2014
Right -- not so smooth.
Personally, I wouldn't enforce it... it somewhat depends on what you want to do
with the vorticity.  If it's nearly continuous, then the interface averaging will not be
detrimental in any case.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Friday, June 06, 2014 10:14 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] how to get vorticity in the post processing
Hi Paul
 Thanks for replying so soon. I want to know how does comp_vort3 enforce that. If it just do average at element interface? Then it won't be so smooth, right?
Yours Sincerely
Wei Zhang
Ph.D
On 2014-6-7, at 上午10:56, nek5000-users at lists.mcs.anl.gov wrote:
> On Fri, 6 Jun 2014, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks
>> Could any one tell me how to get vorticity in the NEK5000 for post
>> processing? I also want to know if it is in the element level or global
>> level. For my understanding, I suppose NEK5000 do things in C0 space, how
>> could one enforce the continuity in first order derivative?
>> Thanks
>> Yours Sincerely
>> Wei Zhang
>> Ph.D
> Hi Wei,
> I would do the following from userchk:
>      parameter (lt=lx1*ly1*lz1*lelt)
>      common /myvort/ v1(lt),v2(lt),v3(lt)
>      if (mod(istep,iostep).eq.0) then
>         call comp_vort3(v1,v2,v3,vx,vy,vz)
>         call outpost(v1,v2,v3,pr,t,'vrt')
>      endif
> The result will be put into a file vrtsample0.f00001, etc.,
> if your session name is "sample"...   You can then
> visualize this field in VisIt.
> If you look at the source for comp_vort3 in navier5.f you
> will see that the returned field is averaged at the interfaces in order to make it continuous.
> Paul
> Nek5000-users mailing list
