[Nek5000-users] how to get vorticity in the post processing
Fri Jun 6 22:14:52 CDT 2014
Hi Paul
 Thanks for replying so soon. I want to know how does comp_vort3 enforce that. If it just do average at element interface? Then it won't be so smooth, right?
Yours Sincerely
Wei Zhang
Ph.D
On 2014-6-7, at 上午10:56, nek5000-users at lists.mcs.anl.gov wrote:
> On Fri, 6 Jun 2014, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Neks
>> Could any one tell me how to get vorticity in the NEK5000 for post
>> processing? I also want to know if it is in the element level or global
>> level. For my understanding, I suppose NEK5000 do things in C0 space, how
>> could one enforce the continuity in first order derivative?
>> Thanks
>> Yours Sincerely
>> Wei Zhang
>> Ph.D
> Hi Wei,
> I would do the following from userchk:
>      parameter (lt=lx1*ly1*lz1*lelt)
>      common /myvort/ v1(lt),v2(lt),v3(lt)
>      if (mod(istep,iostep).eq.0) then
>         call comp_vort3(v1,v2,v3,vx,vy,vz)
>         call outpost(v1,v2,v3,pr,t,'vrt')
>      endif
> The result will be put into a file vrtsample0.f00001, etc.,
> if your session name is "sample"...   You can then
> visualize this field in VisIt.
> If you look at the source for comp_vort3 in navier5.f you
> will see that the returned field is averaged at the interfaces in order to make it continuous.
> Paul
> Nek5000-users mailing list
