[Nek5000-users] Reg: Visit
Tue Jun 3 07:17:04 CDT 2014
Thanks,  Ravi,
I would try a Nek run with ASCII dump  (p66<0 in .rea) to check whether formatting of the files is an issue.
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Monday, June 02, 2014 7:13 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Reg: Visit
Hi Ravi,
What error are you getting?  It should not be the same error you reported earlier:
VisIt could not read from the file "C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test0.f00001.nek5000".
since you are presumably opening lowMach_test.nek5000 instead, right?
Aleks
Sent: Monday, June 02, 2014 6:21 PM
I get error even now. I  modified the way you suggested, but still I get error. I typed 'visnek lowMach_test'. I get below message in my terminal.
Also one may need to correct for an endian by inserting the first line "endian big" or "endian little" in case of, e.g., files transfered from other systems
Total 10 file(s) are in the generated file lowMach_test.nek5000 ... Done!
But when I try to view the files
I get the error again.
Ravi Kiran Pendyala,
Graduate Research Assistant,
Department of Aerospace Engineering,
Mississippi State University,
Email: srp265 at msstate.edu<mailto:srp265 at msstate.edu>
On Mon, Jun 2, 2014 at 3:15 PM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hi Ravi and Tanmoy,
Actually you need to provide a case name for visnek script since it creates the following template
    echo 'filetemplate:        '$base'%01d.f%05d'               >  $base.nek5000
Thus you should try
visnek lowMach_test
and not 'visnek lowMach_test0.f00001'
(ANother alternative, before running nek with scripts tools/scripts/nek*, delete 'rm SESSION.NAME<http://SESSION.NAME>' from them and just type visnek so it can look up for the case name in the SESSION.NAME<http://SESSION.NAME> file)
Aleks
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> [nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>] on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> [nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>]
Sent: Monday, June 02, 2014 2:55 PM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
I have my nek5000 program on linux system. For post processing I take the data files on to my windows system where I have my VisIt tool. Is this problem for not being able to read the files. visnek also didn't help. I did this.  start VisIt and use File->Open AsŠ and then select Nek5000 reader as the reader to use to open the files. Thanks for your patience.
ERROR:
The generated error message was:
There was an error opening C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test0.f00001.nek5000. It may be an invalid file. VisIt tried using the following file format readers to open the file: Nek5000
The following error(s) may be helpful in identifying the problem:
When attempting to use "Nek", the file matched the general format expected by the reader but eventually encountered this error: "Could not open file C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test0.f000010.f00001, which should exist according to header file C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test0.f00001.nek5000.".
On Mon, Jun 2, 2014 at 10:36 AM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
Hi Ravi,
try visnek <name of your fld file>
A <>.nek5000 file would be created. You would be able to read that from visit
Tanmoy
On Mon, Jun 2, 2014 at 2:09 AM, <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
I tried it. I still receive the same error though.
On Mon, Jun 2, 2014 at 3:38 AM, Msu <srp265 at msstate.edu<mailto:srp265 at msstate.edu>> wrote:
Thank you for the kind and quickest response.
Thanks again,
On Jun 2, 2014, at 3:38, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Create a separate file with ' .nek5000 ' has extension and write those lines in it and open it via Visit and It should work.
Best Regards,
Kamal
On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
No. I didn't not get a clue of working with metadata file. I read about it. Couldn't figure out how to create this. Is a a separate file or set of commands?
On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Ravi,
Did you create a metadata file ?? A meta data file is the one which helps you to open a *.fld or *.f00000 file in visit
It looks like this
NEK5000
version: 1.0
filetemplate: divpipe%01d.f%05d
firsttimestep: 1
numtimesteps: 09
Best regards,
Kamal
On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hello all,
I cannot view the output files from the nek5000 .fld format using VisIt. I am very new to using nek5000 code.
. I tried paraview too. It didn't work.
Help greatly appreciated. The following message was posted in forum but didn't find reply so had to post.
error message
VisIt could not read from the file "C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database".
There was an error opening C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database. It may be an invalid file.
VisIt tried using the following file format readers to open the file: Silo
Thank you,
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140603/12874c75/attachment-0001.html>
