[Nek5000-users] [PossibleSpam] Re: Reg: Visit
Mon Jun 2 19:28:39 CDT 2014
Hi Aleks,
The error is different apparently.
Following is error:
VisIt could not read from the file "C:\Users\s
pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test.nek5000".
The generated error message was:
There was an error opening C:\Users\s
pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowMach_test.nek5000. It
may be an invalid file. VisIt tried using the following file format readers
to open the file: Nek5000
Ravi Kiran Pendyala,
On Mon, Jun 2, 2014 at 7:13 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi Ravi,
> What error are you getting?  It should not be the same error you reported
> earlier:
> 2.7.2\lowMach_test0.f00001.nek5000".
> since you are presumably opening lowMach_test.nek5000 instead, right?
> Aleks
> *From:* nek5000-users-bounces at lists.mcs.anl.gov [
> nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Monday, June 02, 2014 6:21 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Reg: Visit
>   I get error even now. I  modified the way you suggested, but still I
> get error. I typed 'visnek lowMach_test'. I get below message in my
> terminal.
>  Also one may need to correct for an endian by inserting the first line
> "endian big" or "endian little" in case of, e.g., files transfered from
> other systems
> Total 10 file(s) are in the generated file lowMach_test.nek5000 ... Done!
>  But when I try to view the files
>  I get the error again.
> Graduate Research Assistant,
> Department of Aerospace Engineering,
> Mississippi State University,
> Email: srp265 at msstate.edu
> On Mon, Jun 2, 2014 at 3:15 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>  Hi Ravi and Tanmoy,
>> Actually you need to provide a case name for visnek script since it
>> creates the following template
>>     echo 'filetemplate:	       '$base'%01d.f%05d'		>  $base.nek5000
>> Thus you should try
>> visnek lowMach_test
>> and not 'visnek lowMach_test0.f00001'
>> (ANother alternative, before running nek with scripts tools/scripts/nek*,
>> delete 'rm SESSION.NAME' from them and just type visnek so it can look
>> up for the case name in the SESSION.NAME file)
>> Aleks
>> *Sent:* Monday, June 02, 2014 2:55 PM
>>    I have my nek5000 program on linux system. For post processing I take
>> the data files on to my windows system where I have my VisIt tool. Is this
>> problem for not being able to read the files. visnek also didn't help. I
>> did this.  start VisIt and use File->Open AsŠ and then select Nek5000 reader
>> as the reader to use to open the files. Thanks for your patience.
>>  ERROR:
>> 2.7.2\lowMach_test0.f00001.nek5000. It may be an invalid file. VisIt tried
>> using the following file format readers to open the file: Nek5000
>>  The following error(s) may be helpful in identifying the problem:
>> When attempting to use "Nek", the file matched the general format
>> expected by the reader but eventually encountered this error: "Could not
>> open file C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt
>> 2.7.2\lowMach_test0.f000010.f00001, which should exist according to header
>> 2.7.2\lowMach_test0.f00001.nek5000.".
>> On Mon, Jun 2, 2014 at 10:36 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Ravi,
>>>  try visnek <name of your fld file>
>>> A <>.nek5000 file would be created. You would be able to read that from
>>> visit
>>>  Tanmoy
>>> On Mon, Jun 2, 2014 at 2:09 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>>>  Hi,
>>>>  I tried it. I still receive the same error though.
>>>>  On Mon, Jun 2, 2014 at 3:38 AM, Msu <srp265 at msstate.edu> wrote:
>>>>>  Thank you for the kind and quickest response.
>>>>>  Thanks again,
>>>>> On Jun 2, 2014, at 3:38, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>  Hi,
>>>>> Create a separate file with ' .nek5000 ' has extension and write those
>>>>> lines in it and open it via Visit and It should work.
>>>>> Best Regards,
>>>>> Kamal
>>>>> On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> No. I didn't not get a clue of working with metadata file. I read
>>>>> about it. Couldn't figure out how to create this. Is a a separate file or
>>>>> set of commands?
>>>>> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>  Hi Ravi,
>>>>> Did you create a metadata file ?? A meta data file is the one which
>>>>> helps you to open a *.fld or *.f00000 file in visit
>>>>> It looks like this
>>>>> NEK5000
>>>>> version: 1.0
>>>>> filetemplate: divpipe%01d.f%05d
>>>>> firsttimestep: 1
>>>>> numtimesteps: 09
>>>>> Best regards,
>>>>> Kamal
>>>>> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>  Hello all,
>>>>>  I cannot view the output files from the nek5000 .fld format using
>>>>> VisIt. I am very new to using nek5000 code.
>>>>> . I tried paraview too. It didn't work.
>>>>>  Help greatly appreciated. The following message was posted in forum
>>>>> but didn't find reply so had to post.
>>>>>  error message
>>>>> pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f*
>>>>> database".
>>>>> database. It may be an invalid file.
>>>>> VisIt tried using the following file format readers to open the file:
>>>>> Silo
>>>>>  Thank you,
>>>>> _______________________________________________
>>>>> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/30347014/attachment-0001.html>
