[Nek5000-users] Reg: Visit
Mon Jun 2 04:09:08 CDT 2014
I tried it. I still receive the same error though.
Ravi Kiran Pendyala,
Graduate Research Assistant,
Department of Aerospace Engineering,
Mississippi State University,
Email: srp265 at msstate.edu
On Mon, Jun 2, 2014 at 3:38 AM, Msu <srp265 at msstate.edu> wrote:
> Thank you for the kind and quickest response.
> Thanks again,
> On Jun 2, 2014, at 3:38, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Create a separate file with ' .nek5000 ' has extension and write those
> lines in it and open it via Visit and It should work.
> Best Regards,
> Kamal
> On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov wrote:
> No. I didn't not get a clue of working with metadata file. I read about
> it. Couldn't figure out how to create this. Is a a separate file or set of
> commands?
> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov wrote:
>   Hi Ravi,
> Did you create a metadata file ?? A meta data file is the one which helps
> you to open a *.fld or *.f00000 file in visit
> It looks like this
> NEK5000
> version: 1.0
> filetemplate: divpipe%01d.f%05d
> firsttimestep: 1
> numtimesteps: 09
> Best regards,
> Kamal
> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>  Hello all,
>  I cannot view the output files from the nek5000 .fld format using VisIt.
> I am very new to using nek5000 code.
> . I tried paraview too. It didn't work.
>  Help greatly appreciated. The following message was posted in forum but
> didn't find reply so had to post.
>  error message
> VisIt could not read from the file "C:\Users\s
> pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f*
> database".
> The generated error message was:
> There was an error opening C:\Users\s
> database. It may be an invalid file.
> VisIt tried using the following file format readers to open the file: Silo
>  Thank you,
> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/6455c9b4/attachment.html>
