[Nek5000-users] Reg: Visit
Mon Jun 2 03:38:54 CDT 2014
Thank you for the kind and quickest response.
Thanks again,
Ravi Kiran Pendyala,
> On Jun 2, 2014, at 3:38, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Create a separate file with ' .nek5000 ' has extension and write those lines in it and open it via Visit and It should work.
> Best Regards,
> Kamal
>> On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov wrote:
>> No. I didn't not get a clue of working with metadata file. I read about it. Couldn't figure out how to create this. Is a a separate file or set of commands?
>> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Ravi,
>>> Did you create a metadata file ?? A meta data file is the one which helps you to open a *.fld or *.f00000 file in visit
>>> It looks like this
>>> NEK5000
>>> version: 1.0
>>> filetemplate: divpipe%01d.f%05d
>>> firsttimestep: 1
>>> numtimesteps: 09
>>> Best regards,
>>> Kamal
>>> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hello all,
>>>> I cannot view the output files from the nek5000 .fld format using VisIt. I am very new to using nek5000                 code.
>>>> . I tried paraview too. It didn't work.
>>>> Help greatly appreciated. The following message was posted in forum but didn't find reply so had to post.
>>>> error message
>>>> VisIt could not read from the file "C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database".
>>>> The generated error message was:
>>>> There was an error opening C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database. It may be an invalid file.
>>>> VisIt tried using the following file format readers to open the file: Silo
>>>> Thank you,
>>>> Graduate Research Assistant,
>>>> Department of Aerospace Engineering,
>>>> Mississippi State University,
>>>> Email: srp265 at msstate.edu
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/28565a05/attachment.html>
