[Nek5000-users] Reg: Visit
Mon Jun 2 10:36:14 CDT 2014
Hi Ravi,
try visnek <name of your fld file>
A <>.nek5000 file would be created. You would be able to read that from
visit
Tanmoy
On Mon, Jun 2, 2014 at 2:09 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I tried it. I still receive the same error though.
> Ravi Kiran Pendyala,
> Graduate Research Assistant,
> Department of Aerospace Engineering,
> Mississippi State University,
> Email: srp265 at msstate.edu
> On Mon, Jun 2, 2014 at 3:38 AM, Msu <srp265 at msstate.edu> wrote:
>> Thank you for the kind and quickest response.
>> Thanks again,
>> On Jun 2, 2014, at 3:38, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> Create a separate file with ' .nek5000 ' has extension and write those
>> lines in it and open it via Visit and It should work.
>> Best Regards,
>> Kamal
>> On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov wrote:
>> No. I didn't not get a clue of working with metadata file. I read about
>> it. Couldn't figure out how to create this. Is a a separate file or set of
>> commands?
>> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov wrote:
>>   Hi Ravi,
>> Did you create a metadata file ?? A meta data file is the one which helps
>> you to open a *.fld or *.f00000 file in visit
>> It looks like this
>> NEK5000
>> version: 1.0
>> filetemplate: divpipe%01d.f%05d
>> firsttimestep: 1
>> numtimesteps: 09
>> Best regards,
>> Kamal
>> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>>  Hello all,
>>  I cannot view the output files from the nek5000 .fld format using
>> VisIt. I am very new to using nek5000 code.
>> . I tried paraview too. It didn't work.
>>  Help greatly appreciated. The following message was posted in forum but
>> didn't find reply so had to post.
>>  error message
>> VisIt could not read from the file "C:\Users\s
>> pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f*
>> database".
>> The generated error message was:
>> There was an error opening C:\Users\s
>> database. It may be an invalid file.
>> VisIt tried using the following file format readers to open the file: Silo
>>  Thank you,
>> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/30d1be09/attachment.html>
