[Nek5000-users] Reg: Visit
Mon Jun 2 03:38:08 CDT 2014
Create a separate file with ' .nek5000 ' has extension and write those
lines in it and open it via Visit and It should work.
Best Regards,
Kamal
On 02/06/2014 10:35, nek5000-users at lists.mcs.anl.gov wrote:
> No. I didn't not get a clue of working with metadata file. I read
> about it. Couldn't figure out how to create this. Is a a separate file
> or set of commands?
> Ravi Kiran Pendyala,
> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Ravi,
>> Did you create a metadata file ?? A meta data file is the one which
>> helps you to open a *.fld or *.f00000 file in visit
>> It looks like this
>> NEK5000
>> version: 1.0
>> filetemplate: divpipe%01d.f%05d
>> firsttimestep: 1
>> numtimesteps: 09
>> Best regards,
>> Kamal
>> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello all,
>>> I cannot view the output files from the nek5000 .fld format using
>>> VisIt. I am very new to using nek5000 code.
>>> . I tried paraview too. It didn't work.
>>> Help greatly appreciated. The following message was posted in forum
>>> but didn't find reply so had to post.
>>> error message
>>> VisIt could not read from the file "C:\Users\s
>>> pendyala\AppData\Local\Programs\LLNL\VisIt
>>> 2.7.2\lowmach\lowMach_test0.f* database".
>>> The generated error message was:
>>> There was an error opening C:\Users\s
>>> 2.7.2\lowmach\lowMach_test0.f* database. It may be an invalid file.
>>> VisIt tried using the following file format readers to open the
>>> file: Silo
>>> Thank you,
>>> Graduate Research Assistant,
>>> Department of Aerospace Engineering,
>>> Mississippi State University,
>>> Email: srp265 at msstate.edu <mailto:srp265 at msstate.edu>
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/bc886505/attachment-0001.html>
