[Nek5000-users] Reg: Visit
Mon Jun 2 03:35:21 CDT 2014
No. I didn't not get a clue of working with metadata file. I read about it. Couldn't figure out how to create this. Is a a separate file or set of commands?
Ravi Kiran Pendyala,
> On Jun 2, 2014, at 3:18, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Ravi,
> Did you create a metadata file ?? A meta data file is the one which helps you to open a *.fld or *.f00000 file in visit
> It looks like this
> NEK5000
> version: 1.0
> filetemplate: divpipe%01d.f%05d
> firsttimestep: 1
> numtimesteps: 09
> Best regards,
> Kamal
>> On 02/06/2014 09:57, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello all,
>> I cannot view the output files from the nek5000 .fld format using VisIt. I am very new to using nek5000 code.
>> . I tried paraview too. It didn't work.
>> Help greatly appreciated. The following message was posted in forum but didn't find reply so had to post.
>> error message
>> VisIt could not read from the file "C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database".
>> The generated error message was:
>> There was an error opening C:\Users\s pendyala\AppData\Local\Programs\LLNL\VisIt 2.7.2\lowmach\lowMach_test0.f* database. It may be an invalid file.
>> VisIt tried using the following file format readers to open the file: Silo
>> Thank you,
>> Graduate Research Assistant,
>> Department of Aerospace Engineering,
>> Mississippi State University,
>> Email: srp265 at msstate.edu
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140602/4e57595b/attachment.html>
