[Nek5000-users] mpi issue
Wed Jan 29 02:13:56 CST 2014
Hi Tubois.
I guess you need to let the -np. The command line actually is: mpiexec -np
4 ./nek5000
Le 29 janv. 2014 09:11, <nek5000-users at lists.mcs.anl.gov> a écrit :
> Hi, Katie
> I changed mpiexec -np $2 ./nek5000
> to mpiexec -4 $2 ./nek5000 in ~/bin/nekmpi to set 4 proc as defaut
> then type nekmpi ext_cyl
> Then I got the error
> Tubois
> On Tue, Jan 28, 2014 at 7:42 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Tubois,
>> What command are you using to submit the run?
>> Katie
>> On Tue, Jan 28, 2014 at 3:58 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hello,
>>> I run into this error with mpi. I am not sure what is about. Has someone
>>> an idea? Thank you!
>>> Best
>>> Tubois
>>> #                  Compilation successful!                  #
>>>    text       data        bss        dec        hex    filename
>>> 2405375       3336    196307656    198716367    bd82bcf    nek5000
>>> mv: cannot stat `ext_cyl.log.': No such file or directory
>>> mv: cannot stat `ext_cyl.sch': No such file or directory
>>> mpiexec was unable to launch the specified application as it could not
>>> find an executable:
>>> Executable: -4
>>> Node: boquette
>>> while attempting to start process rank 0.
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140129/dfb036b6/attachment.html>
