[Nek5000-users] mpi issue
Wed Jan 29 02:11:22 CST 2014
Hi, Katie
I changed mpiexec -np $2 ./nek5000
to mpiexec -4 $2 ./nek5000 in ~/bin/nekmpi to set 4 proc as defaut
then type nekmpi ext_cyl
Then I got the error
Tubois
On Tue, Jan 28, 2014 at 7:42 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Tubois,
> What command are you using to submit the run?
> Katie
> On Tue, Jan 28, 2014 at 3:58 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hello,
>> I run into this error with mpi. I am not sure what is about. Has someone
>> an idea? Thank you!
>> Best
>> Tubois
>> #                  Compilation successful!                  #
>>    text       data        bss        dec        hex    filename
>> 2405375       3336    196307656    198716367    bd82bcf    nek5000
>> mv: cannot stat `ext_cyl.log.': No such file or directory
>> mv: cannot stat `ext_cyl.sch': No such file or directory
>> mpiexec was unable to launch the specified application as it could not
>> find an executable:
>> Executable: -4
>> Node: boquette
>> while attempting to start process rank 0.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140129/e6049ea3/attachment.html>
