[Nek5000-users] mpi issue
Wed Jan 29 02:25:32 CST 2014
Hi, Katie,
Thank you very much. It works.
Best
Tubois
On Wed, Jan 29, 2014 at 9:13 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Tubois.
> I guess you need to let the -np. The command line actually is: mpiexec -np
> 4 ./nek5000
> Le 29 janv. 2014 09:11, <nek5000-users at lists.mcs.anl.gov> a écrit :
> Hi, Katie
>> I changed mpiexec -np $2 ./nek5000
>> to mpiexec -4 $2 ./nek5000 in ~/bin/nekmpi to set 4 proc as defaut
>> then type nekmpi ext_cyl
>> Then I got the error
>> Tubois
>> On Tue, Jan 28, 2014 at 7:42 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Tubois,
>>> What command are you using to submit the run?
>>> Katie
>>> On Tue, Jan 28, 2014 at 3:58 AM, <nek5000-users at lists.mcs.anl.gov>wrote:
>>>> Hello,
>>>> I run into this error with mpi. I am not sure what is about. Has
>>>> someone an idea? Thank you!
>>>> Best
>>>> Tubois
>>>> #                  Compilation successful!                  #
>>>>    text       data        bss        dec        hex    filename
>>>> 2405375       3336    196307656    198716367    bd82bcf    nek5000
>>>> mv: cannot stat `ext_cyl.log.': No such file or directory
>>>> mv: cannot stat `ext_cyl.sch': No such file or directory
>>>> mpiexec was unable to launch the specified application as it could not
>>>> find an executable:
>>>> Executable: -4
>>>> Node: boquette
>>>> while attempting to start process rank 0.
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140129/b0b8303b/attachment-0001.html>
