[Nek5000-users] Pipe with expansion
Wed Jan 15 03:48:49 CST 2014
Hi Paul,
I looked at the example and it looks very helpful, but for a sudden
expansion we have only two parts (i.e) the inlet pipe and the outlet
pipe. Whereas in a diverging pipe we have three section (i.e,) The inlet
pipe, Diverging section and the outlet pipe.
Is it possible for me to create a 2D diverging section using mesh
modification and revolve it around the centre axis to get a 3d diverging
pipe ?
or should I apply the mesh modification directly to the 3d sudden
expansion pipe using usrdat2() ?
Kamal
On 14/01/2014 21:09, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Thanks a lot for the update. I will take a look at as soon as possible and keep you updated with it.
> Thank you,
> Kamal
> On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Kamal,
>> I've added an example for a step-type expansion in a pipe.  New example directory
>> is nek5_svn/examples/expansion, with a README.
>> If you want a standard diffuser, I would use mesh-morphing, as outlined in the
>> nek primer, which can be found on this page:
>> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
>> I've also automated our turbulent outflow bc treatment -- one simply provides an
>> expansion factor (typically ~ 1.5) and two persistent arrays to turb_outflow(), which
>> is now in navier5.f.    This can be useful when very strong vortices are leaving the
>> domain, which is possible for certain diffuser flow conditions (and others).
>> Paul
>> ________________________________________
>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>> Sent: Monday, January 13, 2014 3:35 AM
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: [Nek5000-users] Creating a Mesh
>> Hi
>> Can some one please help me in this because I am new to nek
>> 1) How can I create a .rea for a specific geometry say ' A sudden
>> expansion pipe ' or a ' Diverging pipe '
>> 2) What tool I should use to create that mesh.
>> Thank you
>> kamal
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
