[Nek5000-users] Pipe with expansion
Tue Jan 14 14:09:27 CST 2014
Hi Paul,
Thanks a lot for the update. I will take a look at as soon as possible and keep you updated with it.
Thank you,
Kamal
On Jan 14, 2014, at 9:04 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Kamal,
> I've added an example for a step-type expansion in a pipe.  New example directory
> is nek5_svn/examples/expansion, with a README.
> If you want a standard diffuser, I would use mesh-morphing, as outlined in the
> nek primer, which can be found on this page:
> http://nek5000.mcs.anl.gov/index.php/UG#Documentation
> I've also automated our turbulent outflow bc treatment -- one simply provides an
> expansion factor (typically ~ 1.5) and two persistent arrays to turb_outflow(), which
> is now in navier5.f.    This can be useful when very strong vortices are leaving the
> domain, which is possible for certain diffuser flow conditions (and others).
> Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> Sent: Monday, January 13, 2014 3:35 AM
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Creating a Mesh
> Hi
> Can some one please help me in this because I am new to nek
> 1) How can I create a .rea for a specific geometry say ' A sudden
> expansion pipe ' or a ' Diverging pipe '
> 2) What tool I should use to create that mesh.
> Thank you
> kamal
> Nek5000-users mailing list
