[Nek5000-users] LES-wall
Tue Dec 30 10:07:16 CST 2014
Thanks Tanmoy for your suggestion.
You are right, for a eddy viscosity type of turbulent model, the
Channel example is a good starting point (though, I think it should
be considerably modified to be used in a case with a different
geometry compared to a channel). But I was thinking of using sort of
wall model when employing the explicit filtering of velocity field as
a LES model.
Mohsen
On 24-Dec-14, at 11:23 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Mohsen,
> For LES with near wall modelling, you have to develop your own
> script in .usr file. There are no in-built routines except eddy_visc
> () in turbChannel example.  If you use eddy-viscosity type of near
> wall models in LES, you can modify the scripts and write your own
> eddy-viscosity routines in uservp.
> Thanks,
> Tanmoy
> Best Regards,
> Tanmoy
> On Thu, Dec 25, 2014 at 12:47 AM, <nek5000-users at lists.mcs.anl.gov>
> wrote:
> Hello all,
> I have a question regarding LES capability of Nek.
> I know that the explicit filtering introduced in Nek can be
> effective for velocity field to provide sort of eddy viscosity
> modeling. Nevertheless, there should be some form of modeling for
> the near wall regions, since it is almost infeasible to have DNS
> like resolution in such regions for problems with relatively high
> Reynolds number and large scale geometries. I have seen SFR
> assemblies example on the Nek web in which LES used, however, I am
> not sure if that was an LES with near-wall resolution or with near-
> wall modeling.
> So I was wondering if anyone has any experience of using Nek LES
> with near wall models, or kind of hybrid RANS-LES approaches.
> Thanks,
> Mohsen
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20141230/deb6c26c/attachment.html>
