[Nek5000-users] Outlet boundary treatment
Mon Apr 14 10:26:06 CDT 2014
Hi omid,
To simulate turbulent flows, I guess you can use the sub routine
turb_outflow().
Take a look at expansion.usr file in expansion example.
Best,Kamal
On 14/04/2014 17:17, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks,
> I want to simulate turbulent flow in a stenosis, and use outflow
> boundary condition at the outlet. Because of the possible backflow at
> the outlet in this case, I want to impose div U>0 at the last layer of
> the outlet.
> I have already seen an example in NEK5000 website (peris) which uses
> the same boundary condition as I want to impose.
> In this example, three subroutines are mentioned as the names of the
> following to apply this boundary condition:
> *fill_div(div)*
> *set_outflow_dist*
> *get_div_const(cdiv)*
> Now, I intend to use the same outlet B.C for a case the same as
> stenosis in pipe example. The both examples; pipe and peris, have
> similar geometries. So, may I use these subroutines exactly in the
> .usr file of stenosis case? or I should do any modification in this case.
> Thanks so much in advance.
> Omid
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20140414/9476377b/attachment.html>
