[Nek5000-users] Optimal response for nek5000
Thu Sep 5 08:46:12 CDT 2013
Adam,
Just to clarify,
are you switching between time-dependent NS and time-dependent Stokes.
Or, are you switching between time-dependent NS and steady Stokes ?
Also, are you using PnPn or PnPn-2 ?
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Thursday, September 5, 2013 7:49:01 AM
Subject: [Nek5000-users] Optimal response for nek5000
Dear neks
I'm going to implement optimal response to forcing in nekton and I have
question related to pressure solver. During calculations I have to
continuously switch between time dependent N-S and Stokes problem. I was
going to do something similar to prsolvv. However, in nek_init the
choice of pressure solver depends on IFTRAN suggesting different solver
for Stokes problem, but prslovv seem to be called without
reinitialisation of pressure solver. So can I use the same pressure
solver (say itr) for both full N-S and Stokes?
Regards
Adam
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
