[Nek5000-users] Optimal response for nek5000
Thu Sep 5 09:11:19 CDT 2013
Dear Paul
I switch between time-dependent NS and time-dependent Stokes (both for
Euler time-stepping). I missed the fact that prsolvv gives steady state
solution. I guess it will be PnPn-2, but not sure. Is there a crucial
difference between PnPn and PnPn-2 when it comes to switching between NS
and Stokes?
regards
Adam
On 05/09/13 15:46, nek5000-users at lists.mcs.anl.gov wrote:
> Adam,
> Just to clarify,
> are you switching between time-dependent NS and time-dependent Stokes.
> Or, are you switching between time-dependent NS and steady Stokes ?
> Also, are you using PnPn or PnPn-2 ?
> Thanks,
> Paul
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Thursday, September 5, 2013 7:49:01 AM
> Subject: [Nek5000-users] Optimal response for nek5000
> Dear neks
> I'm going to implement optimal response to forcing in nekton and I have
> question related to pressure solver. During calculations I have to
> continuously switch between time dependent N-S and Stokes problem. I was
> going to do something similar to prsolvv. However, in nek_init the
> choice of pressure solver depends on IFTRAN suggesting different solver
> for Stokes problem, but prslovv seem to be called without
> reinitialisation of pressure solver. So can I use the same pressure
> solver (say itr) for both full N-S and Stokes?
> Regards
> Adam
> Nek5000-users mailing list
