[Nek5000-users] Problem reading binary .fld files into postnek
Wed Sep 4 14:59:21 CDT 2013
Hi Chris,
Is your file format .fld or f0000 ?
Paul
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Wednesday, September 4, 2013 1:46:00 PM
Subject: Re: [Nek5000-users] Problem reading binary .fld files into postnek
Hi Paul,
Thank you for your suggestions. I am using a standard .rea file and already had the flags at p66 and p67 set to 4 (the extension of my data is .fld) but the problem still occurs. I tried setting the flags to 6 anyways but still encountered the same problem.
Chris
On Wed, Sep 4, 2013 at 9:33 AM, Christopher Mehrvarzi < chrisom3 at vt.edu > wrote:
Hi Neks,
I am having some issues importing my binary-type data into postnek. When the files are imported into postnek, many of the elements are missing and this is part of the message that appears in the terminal:
-Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1
NEKTON Version 2.6
I/O Error: No String Terminator sent to PRS
Enter Session Name (Default= g40cond_as
Beginning Session g40cond_as
renaming SESSION.NAME SESSION.NAME ~
Session name:"g40cond_as "
cp: /Users/chris/.nekdefaults: No such file or directory
renaming g40cond_as.plt01 g40cond_as.plt01~
LTRUNC: string: 80
LTRUNC: string: 28
Wed Sep 4 09:30:51 EDT 2013
Reading geometry from
XYZ Min,Max:
-40.0000 40.0000
-40.0000 40.0000
0.00000 1.00000
1 3017 1 TRYING TO READ BC
7 3072 2 TRYING TO READ BC
7 3072 3 TRYING TO READ BC
7 3072 4 TRYING TO READ BC
7 3072 5 TRYING TO READ BC
Error reading options in .REA file
this is iffmat: F 4.0000000
g40cond_as
g40cond_as.fld01
The same data can be read correctly in Visit, however. Any ideas?
Additionally, if this problem cannot be overcome, is there a way to take profile points using Visit or Matlab?
Thank you for your help,
Chris
Christopher O. Mehrvarzi
Paul Research Group
Virginia Tech - Mechanical Engineering
chrisom3 at vt.edu
Paul Research Group
chrisom3 at vt.edu
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
