[Nek5000-users] Problem reading binary .fld files into postnek
Wed Sep 4 15:43:35 CDT 2013
Hi Chris,
Are you using the current version of postnek?
Katie
On Wed, Sep 4, 2013 at 1:46 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Paul,
> Thank you for your suggestions. I am using a standard .rea file and
> already had the flags at p66 and p67 set to 4 (the extension of my data
> is .fld) but the problem still occurs. I tried setting the flags to 6
> anyways but still encountered the same problem.
> Chris
> On Wed, Sep 4, 2013 at 9:33 AM, Christopher Mehrvarzi <chrisom3 at vt.edu>wrote:
>> Hi Neks,
>> I am having some issues importing my binary-type data into postnek. When
>> the files are imported into postnek, many of the elements are missing and
>> this is part of the message that appears in the terminal:
>> -Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1
>>  NEKTON Version   2.6
>>  I/O Error: No String Terminator sent to PRS
>> Enter Session Name (Default= g40cond_as
>>  Beginning Session g40cond_as
>>  renaming SESSION.NAME SESSION.NAME~
>>  Session name:"g40cond_as
>> cp: /Users/chris/.nekdefaults: No such file or directory
>>  renaming g40cond_as.plt01                         g40cond_as.plt01~
>>  LTRUNC: string:          80
>>  LTRUNC: string:          28
>> Wed Sep  4 09:30:51 EDT 2013
>>  Reading geometry from
>> XYZ Min,Max:
>>   -40.0000       40.0000
>>   -40.0000       40.0000
>>    0.00000       1.00000
>>            1        3017           1  TRYING TO READ BC
>>            7        3072           2  TRYING TO READ BC
>>            7        3072           3  TRYING TO READ BC
>>            7        3072           4  TRYING TO READ BC
>>            7        3072           5  TRYING TO READ BC
>> Error reading options in .REA file
>>  this is iffmat: F   4.0000000
>> g40cond_as
>> g40cond_as.fld01
>> The same data can be read correctly in Visit, however. Any ideas?
>> Additionally, if this problem cannot be overcome, is there a way to take
>> profile points using Visit or Matlab?
>> Thank you for your help,
>> Chris
>> Christopher O. Mehrvarzi
>> Paul Research Group
>> Virginia Tech - Mechanical Engineering
>> chrisom3 at vt.edu
> Paul Research Group
> chrisom3 at vt.edu
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130904/2fcff049/attachment.html>
