[Nek5000-users] Problem reading binary .fld files into postnek
Wed Sep 4 13:46:00 CDT 2013
Hi Paul,
Thank you for your suggestions. I am using a standard .rea file and already
had the flags at p66 and p67 set to 4 (the extension of my data is .fld)
but the problem still occurs. I tried setting the flags to 6 anyways but
still encountered the same problem.
Chris
On Wed, Sep 4, 2013 at 9:33 AM, Christopher Mehrvarzi <chrisom3 at vt.edu>wrote:
> Hi Neks,
> I am having some issues importing my binary-type data into postnek. When
> the files are imported into postnek, many of the elements are missing and
> this is part of the message that appears in the terminal:
> -Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1
>  NEKTON Version   2.6
>  I/O Error: No String Terminator sent to PRS
> Enter Session Name (Default= g40cond_as
>  Beginning Session g40cond_as
>  renaming SESSION.NAME SESSION.NAME~
>  Session name:"g40cond_as
> cp: /Users/chris/.nekdefaults: No such file or directory
>  renaming g40cond_as.plt01                         g40cond_as.plt01~
>  LTRUNC: string:          80
>  LTRUNC: string:          28
> Wed Sep  4 09:30:51 EDT 2013
>  Reading geometry from
> XYZ Min,Max:
>   -40.0000       40.0000
>   -40.0000       40.0000
>    0.00000       1.00000
>            1        3017           1  TRYING TO READ BC
>            7        3072           2  TRYING TO READ BC
>            7        3072           3  TRYING TO READ BC
>            7        3072           4  TRYING TO READ BC
>            7        3072           5  TRYING TO READ BC
> Error reading options in .REA file
>  this is iffmat: F   4.0000000
> g40cond_as
> g40cond_as.fld01
> The same data can be read correctly in Visit, however. Any ideas?
> Additionally, if this problem cannot be overcome, is there a way to take
> profile points using Visit or Matlab?
> Thank you for your help,
> Chris
> Christopher O. Mehrvarzi
> Paul Research Group
> Virginia Tech - Mechanical Engineering
> chrisom3 at vt.edu
Paul Research Group
chrisom3 at vt.edu
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130904/dee8ff7c/attachment.html>
