[Nek5000-users] Problem reading binary .fld files into postnek
Wed Sep 4 08:49:03 CDT 2013
Chris,
What type of .rea file do you have ?  (Do you have .re2, or just
standard .rea?)
Also, take a look at p66 and p67 in your .rea file -- they should
either be 4 or 6, depending on whether your file extension is .fld
or .f00000
My guess is that fixing those values should resolve the issue.
Please let me know if this works.
Best, Paul
On Wed, 4 Sep 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I am having some issues importing my binary-type data into postnek. When
> the files are imported into postnek, many of the elements are missing and
> this is part of the message that appears in the terminal:
> -Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1
> NEKTON Version   2.6
> I/O Error: No String Terminator sent to PRS
> Enter Session Name (Default= g40cond_as
> Beginning Session g40cond_as
> renaming SESSION.NAME SESSION.NAME~
> Session name:"g40cond_as
> cp: /Users/chris/.nekdefaults: No such file or directory
> renaming g40cond_as.plt01                         g40cond_as.plt01~
> LTRUNC: string:          80
> LTRUNC: string:          28
> Wed Sep  4 09:30:51 EDT 2013
> Reading geometry from
> XYZ Min,Max:
>  -40.0000       40.0000
>  -40.0000       40.0000
>   0.00000       1.00000
>           1        3017           1  TRYING TO READ BC
>           7        3072           2  TRYING TO READ BC
>           7        3072           3  TRYING TO READ BC
>           7        3072           4  TRYING TO READ BC
>           7        3072           5  TRYING TO READ BC
> Error reading options in .REA file
> this is iffmat: F   4.0000000
> g40cond_as
> g40cond_as.fld01
> The same data can be read correctly in Visit, however. Any ideas?
> Additionally, if this problem cannot be overcome, is there a way to take
> profile points using Visit or Matlab?
> Thank you for your help,
> Chris
> Christopher O. Mehrvarzi
> Paul Research Group
> Virginia Tech - Mechanical Engineering
> chrisom3 at vt.edu
