[Nek5000-users] Extruding 2D .fld file to 3D
Wed Oct 23 19:52:45 CDT 2013
Hi Holly,
I would likely do this in usrdat2().
Suppose my 2D problem had 70 elements. The the following
should work:
In SIZE, set lelx=70,lely=1, and lelz=# of levels in your extruded geometry.
In usrdat2() in the .usr file, set nelx=lelx,nely=lely,nelz=lelz.
Then:
       parameter (l2d=lx1*ly1*lelx) ! Number of points in 2D field
       common /mystuff/ u2d(l2d),v2d(l2d)
       if (nid.eq.0) then
          open(33,file='my2dfile.dat')
          do i=1,l2d
             read(33,*) u2d(i),v2d(i)
          enddo
          close(33)
       endif
       nbytes = 8*l2d
       call bcast(u2d,nbytes)
       call bcast(v2d,nbytes)
Once you load your 2D data you can use
       call z_average_transpose(vx,u2d)
       call z_average_transpose(vy,v2d)
to map this to 3D.
After that, I would just dump the 3D results and exit:
       call outpost(vx,vy,vz,pr,t,'   ')
       call exitti('Quit in usrdat2.$',nelgt)
This _should_ work, but probably needs a couple iterations
to get everything correct.
To generate myfile2d.dat, I would do the following:
1) Run the 2D code and dump an ascii .fld file by setting
    param(66)=0 in usrdat2 or userchk prior to output the fld file.
2) Edit the resultant .fld file and get rid of the first few
    line at the top of that file so that your u,v data is all
    that it holds.  (Look both at the top and bottom of the file
    when you're ready -- they should have the same column format.)
Hope this helps.
Paul
On Wed, 23 Oct 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Neks !
> In order to reduce runtime, it would be useful to be able to run a 2D
> simulation and extrude the results to a 3D domain when using a 2D model
> (for example the Rankine vortex). Is it possible to extrude a 2D .fld
> file to a 3D one ? I was thinking of loading a 2D .fld file into a 3D
> simulation using something similar to load_fld() and then using loops to
> impose the same velocity to all the points in the domain. However
> load_fld() doesn't seem to like loading a 2D .fld in a 3D simulation.
> Has anyone else had this problem ?
> Thanks for your help!
> Holly JOHNSON
> PhD Student ONERA - DAFE
> Département d'Aérodynamique Fondamentale et Expérimentale
> 8, Rue des Vertugadins
> 92190 - Meudon - France
> Nek5000-users mailing list
uuuu
c-----------------------------------------------------------------------
       subroutine q_filter(wght)
c
c     filter vx,vy,vz, and p by simple interpolation
c
       include 'SIZE'
       include 'TOTAL'
c
c
c     These are the dimensions that we interpolate onto for v and p:
       parameter(lxv=lx1-1)
       parameter(lxp=lx2-1)
c
       real intdv(lx1,lx1)
       real intuv(lx1,lx1)
       real intdp(lx1,lx1)
       real intup(lx1,lx1)
       real intv(lx1,lx1)
       real intp(lx1,lx1)
c
       save intdv
       save intuv
       save intdp
       save intup
       save intv
       save intp
       common /ctmp0/ intw,intt
      $             , wk1,wk2
      $             , zgmv,wgtv,zgmp,wgtp,tmax(100),omax(103)
       real intw(lx1,lx1)
       real intt(lx1,lx1)
       real wk1  (lx1,lx1,lx1,lelt)
       real wk2  (lx1,lx1,lx1)
       real zgmv(lx1),wgtv(lx1),zgmp(lx1),wgtp(lx1)
c
c     outpost arrays
       parameter (lt=lx1*ly1*lz1*lelv)
       common /scruz/ w1(lt),w2(lt),w3(lt),wt(lt)
       character*18 sfmt
       integer icalld
       save    icalld
       data    icalld /0/
       imax = nid
       imax = iglmax(imax,1)
       jmax = iglmax(imax,1)
       if (icalld.eq.0) then
          icalld = 1
          ncut = param(101)+1
          call build_new_filter(intv,zgm1,nx1,ncut,wght,nid)
       elseif (icalld.lt.0) then   ! old (std.) filter
          icalld = 1
          call zwgll(zgmv,wgtv,lxv)
          call igllm(intuv,intw,zgmv,zgm1,lxv,nx1,lxv,nx1)
          call igllm(intdv,intw,zgm1,zgmv,nx1,lxv,nx1,lxv)
c
          call zwgl (zgmp,wgtp,lxp)
          call iglm (intup,intw,zgmp,zgm2,lxp,nx2,lxp,nx2)
          call iglm (intdp,intw,zgm2,zgmp,nx2,lxp,nx2,lxp)
c
c        Multiply up and down interpolation into single operator
c
          call mxm(intup,nx2,intdp,lxp,intp,nx2)
          call mxm(intuv,nx1,intdv,lxv,intv,nx1)
c
c        Weight the filter to make it a smooth (as opposed to truncated)
c        decay in wave space
c
          w0 = 1.-wght
          call ident(intup,nx2)
          call add2sxy(intp,wght,intup,w0,nx2*nx2)
c
          call ident   (intuv,nx1)
          call add2sxy (intv ,wght,intuv,w0,nx1*nx1)
c
c        if (nid.eq.0) call outmatx(intp,nx2,nx2,21,'flt2')
c        if (nid.eq.0) call outmatx(zgm2 ,nx2,1  ,22,'zgm2')
c        if (nid.eq.0) call outmatx(intv,nx1,nx1,11,'flt1')
c        if (nid.eq.0) call outmatx(zgm1 ,nx1,1  ,12,'zgm1')
c
       endif
       ifldt  = ifield
c     ifield = 1
       if ( (ifflow.and. .not. ifmhd)  .or.
      $     (ifield.eq.1 .and. ifmhd)      ) then
          call filterq(vx,intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
          call filterq(vy,intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
          if (if3d)
      $      call filterq(vz,intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
          if (ifsplit.and..not.iflomach)
      $      call filterq(pr,intv,nx1,nz1,wk1,wk2,intt,if3d,pmax)
       endif
c
       if (ifmhd.and.ifield.eq.ifldmhd) then
          call filterq(bx,intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
          call filterq(by,intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
          if (if3d)
      $   call filterq(bz,intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
       endif
c
       if (ifpert) then
         do j=1,npert
          ifield = 1
          call filterq(vxp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
          call filterq(vyp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
          if (if3d)
      $   call filterq(vzp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
          ifield = 2
          if (ifheat .and. .not.ifcvode)
      $   call filterq(tp(1,j,1),intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
         enddo
       endif
c
       mmax = 0
       if (ifflow) then
c        pmax    = glmax(pmax,1)
          omax(1) = glmax(umax,1)
          omax(2) = glmax(vmax,1)
          omax(3) = glmax(wmax,1)
          mmax = ndim
       endif
c
       nfldt = 1+npscal
       if (ifheat .and. .not.ifcvode) then
          do ifld=1,nfldt
             ifield = ifld + 1
             call filterq(t(1,1,1,1,ifld),intv
      $                  ,nx1,nz1,wk1,wk2,intt,if3d,tmax(ifld))
             mmax = mmax+1
             omax(mmax) = glmax(tmax(ifld),1)
          enddo
       endif
       if (nid.eq.0) then
          if (npscal.eq.0) then
c           write(6,101) mmax
c           write(sfmt,101) mmax
c 101       format('''(i8,1p',i1,'e12.4,a6)''')
c           write(6,sfmt) istep,(omax(k),k=1,mmax),' qfilt'
c         write(6,'(i8,1p4e12.4,a6)') istep,(omax(k),k=1,mmax),' qfilt'
          else
             if (if3d) then
                write(6,1) istep,ifield,umax,vmax,wmax
             else
             endif
     1       format(4x,i7,i3,' qfilt:',1p3e12.4)
             if(ifheat .and. .not.ifcvode)
      &            write(6,'(1p50e12.4)') (tmax(k),k=1,nfldt)
          endif
       endif
       ifield = ifldt   ! RESTORE ifield
       return
       end
       subroutine filterq(v,f,nx,nz,w1,w2,ft,if3d,dmax)
c
       include 'SIZE'
       include 'TSTEP'
       real v(nx*nx*nz,nelt),w1(1),w2(1)
       logical if3d
c
       real f(nx,nx),ft(nx,nx)
c
       integer e
c
       call transpose(ft,nx,f,nx)
c
       nxyz=nx*nx*nz
       dmax = 0.
       nel = nelfld(ifield)
       if (if3d) then
          do e=1,nel
c           Filter
             call copy(w2,v(1,e),nxyz)
             call mxm(f,nx,w2,nx,w1,nx*nx)
             i=1
             j=1
             do k=1,nx
                call mxm(w1(i),nx,ft,nx,w2(j),nx)
                i = i+nx*nx
                j = j+nx*nx
             enddo
             call mxm (w2,nx*nx,ft,nx,w1,nx)
             call sub3(w2,v(1,e),w1,nxyz)
             call copy(v(1,e),w1,nxyz)
             smax = vlamax(w2,nxyz)
             dmax = max(dmax,abs(smax))
          enddo
c
       else
          do e=1,nel
c           Filter
             call copy(w1,v(1,e),nxyz)
             call mxm(f ,nx,w1,nx,w2,nx)
             call mxm(w2,nx,ft,nx,w1,nx)
c
          enddo
       endif
c
       return
       end
       subroutine outmatx(a,m,n,io,name)
       real a(m*n)
       character*4 name
c
       open(unit=io,file=name)
       do i=1,m*n
          write(io,1) a(i)
       enddo
     1 format(1p1e22.13)
       close(unit=io)
c
       return
       end
       subroutine drag_calc(scale)
c
       INCLUDE 'SIZE'
       INCLUDE 'TOTAL'
c
       common /scrns/         pm1(lx1,ly1,lz1,lelv)
      $,vxx(lx1,ly1,lz1,lelv),vxy(lx1,ly1,lz1,lelv),vxz(lx1,ly1,lz1,lelv)
      $,vyx(lx1,ly1,lz1,lelv),vyy(lx1,ly1,lz1,lelv),vyz(lx1,ly1,lz1,lelv)
       common /scruz/
      $ vzx(lx1,ly1,lz1,lelv),vzy(lx1,ly1,lz1,lelv),vzz(lx1,ly1,lz1,lelv)
      $,one(lx1,ly1,lz1,lelv)
        real work(1)
        equivalence (work,one)
c
       common /cdrag/ dragx(0:maxobj),dragy(0:maxobj),dragz(0:maxobj)
      $             ,  momx(0:maxobj), momy(0:maxobj), momz(0:maxobj)
      $             ,  dpdx_mean,dpdy_mean,dpdz_mean
       real momx ,momy ,momz
c
       common /tdrag/ drag(11)
       real dragpx,dragpy,dragpz,dragvx,dragvy,dragvz
       real momvx ,momvy ,momvz
       real check1,check2
c
       equivalence (dragpx,drag(1)),(dragpy,drag(2)),(dragpz,drag(3))
       equivalence (dragvx,drag(4)),(dragvy,drag(5)),(dragvz,drag(6))
       equivalence (momvx ,drag(7)),(momvy ,drag(8)),(momvz ,drag(9))
       equivalence (check1,drag(10)),(check2,drag(11))
       common /cvflow_r/ flow_rate,base_flow,domain_length,xsec
      $                , scale_vf(3)
       ntot1  = nx1*ny1*nz1*nelv
c    Map pressure onto mesh 1   (vxx and vyy are used as work arrays)
       call mappr(pm1,pr,vxx,vyy)
       call rone (one,ntot1)
c
c    Add mean_pressure_gradient.X to p:
       if (param(55).ne.0) then
          dpdx_mean = -scale_vf(1)
          dpdy_mean = -scale_vf(2)
          dpdz_mean = -scale_vf(3)
       endif
       call add2s2(pm1,xm1,dpdx_mean,ntot1)  ! Doesn't work if object is cut by
       call add2s2(pm1,ym1,dpdy_mean,ntot1)  ! periodicboundary.  In this case,
       call add2s2(pm1,zm1,dpdz_mean,ntot1)  ! set ._mean=0 and compensate in
c                                           ! usrchk()  [ pff 10/21/04 ].
c    Compute du/dn
                 CALL DUDXYZ (vxx,vx,RXM1,SXM1,TXM1,JACM1,1,1)
                 CALL DUDXYZ (vxy,vx,RYM1,SYM1,TYM1,JACM1,1,1)
       if (if3d) CALL DUDXYZ (vxz,vx,RZM1,SZM1,TZM1,JACM1,1,1)
c
                 CALL DUDXYZ (vyx,vy,RXM1,SXM1,TXM1,JACM1,1,1)
                 CALL DUDXYZ (vyy,vy,RYM1,SYM1,TYM1,JACM1,1,1)
       if (if3d) CALL DUDXYZ (vyz,vy,RZM1,SZM1,TZM1,JACM1,1,1)
c
       if (if3d) then
                 CALL DUDXYZ (vzx,vz,RXM1,SXM1,TXM1,JACM1,1,1)
                 CALL DUDXYZ (vzy,vz,RYM1,SYM1,TYM1,JACM1,1,1)
                 CALL DUDXYZ (vzz,vz,RZM1,SZM1,TZM1,JACM1,1,1)
       endif
c
c     Fill up viscous array w/ default
c
       if (istep.lt.1) call cfill(vdiff,param(2),ntot1)
c
       call col2(vxx,vdiff,ntot1)
       call col2(vxy,vdiff,ntot1)
       call col2(vxz,vdiff,ntot1)
       call col2(vyx,vdiff,ntot1)
       call col2(vyy,vdiff,ntot1)
       call col2(vyz,vdiff,ntot1)
       call col2(vzx,vdiff,ntot1)
       call col2(vzy,vdiff,ntot1)
       call col2(vzz,vdiff,ntot1)
c
       dragxt=0.0
       dragyt=0.0
       dragzt=0.0
c
       DO 100 II=1,NHIS
          IF (HCODE(10,II).NE.'I') GOTO 100
          IOBJ   = LOCHIS(1,II)
          MEMTOT = NMEMBER(IOBJ)
C
c
          IF (HCODE(1,II).NE.' ' .OR. HCODE(2,II).NE.' ' .OR.
      $       HCODE(3,II).NE.' ' ) THEN
             IFIELD = 1
c
c---------------------------------------------------------------------------
c           Compute drag for this object
c
             dragvx=0.0
             dragvy=0.0
             dragvz=0.0
             dragpx=0.0
             dragpy=0.0
             dragpz=0.0
c
             momvx=0.0
             momvy=0.0
             momvz=0.0
c
             check1=0.0
             check2=0.0
             DO 50 MEM=1,MEMTOT
                ISK   = 0
                IEG   = OBJECT(IOBJ,MEM,1)
                IFC   = OBJECT(IOBJ,MEM,2)
                IF (GLLNID(IEG).EQ.NID) THEN
C                 This processor has a contribution
                   IE = GLLEL(IEG)
c
c                 Pressure drag
                   check1=check1+facint(one,one,area,ifc,ie)
                   check2=check2+facint(one,uny,area,ifc,ie)
c
                   dragpx=dragpx+facint(pm1,unx,area,ifc,ie)
                   dragpy=dragpy+facint(pm1,uny,area,ifc,ie)
                   if (if3d) dragpz=dragpz+facint(pm1,unz,area,ifc,ie)
c
c                 Viscous drag
                   if (if3d) then
                      dragvx=dragvx+facint(vxx,unx,area,ifc,ie)
      $                            +facint(vxy,uny,area,ifc,ie)
      $                            +facint(vxz,unz,area,ifc,ie)
      $                            +facint(vxx,unx,area,ifc,ie)
      $                            +facint(vyx,uny,area,ifc,ie)
      $                            +facint(vzx,unz,area,ifc,ie)
                      dragvy=dragvy+facint(vyx,unx,area,ifc,ie)
      $                            +facint(vyy,uny,area,ifc,ie)
      $                            +facint(vyz,unz,area,ifc,ie)
      $                            +facint(vxy,unx,area,ifc,ie)
      $                            +facint(vzy,unz,area,ifc,ie)
                      dragvz=dragvz+facint(vzx,unx,area,ifc,ie)
      $                            +facint(vzy,uny,area,ifc,ie)
      $                            +facint(vzz,unz,area,ifc,ie)
      $                            +facint(vxz,unx,area,ifc,ie)
      $                            +facint(vyz,uny,area,ifc,ie)
c
                      momvx=momvx-facint2(vxy,unx,unz,area,ifc,ie)
      $                        -facint2(vyx,unx,unz,area,ifc,ie)
      $                        -facint2(vyy,uny,unz,area,ifc,ie)
      $                        -facint2(vzy,unz,unz,area,ifc,ie)
      $                        -facint2(vyz,unz,unz,area,ifc,ie)
      $                        +facint2(vxz,unx,uny,area,ifc,ie)
      $                        +facint2(vzx,unx,uny,area,ifc,ie)
      $                        +facint2(vyz,uny,uny,area,ifc,ie)
      $                        +facint2(vzy,uny,uny,area,ifc,ie)
      $                        +facint2(vzz,unz,uny,area,ifc,ie)
                      momvy=momvy+facint2(vxx,unx,unz,area,ifc,ie)
      $                        +facint2(vxx,unx,unz,area,ifc,ie)
      $                        +facint2(vyx,uny,unz,area,ifc,ie)
      $                        +facint2(vxy,uny,unz,area,ifc,ie)
      $                        +facint2(vzx,unz,unz,area,ifc,ie)
      $                        +facint2(vxz,unz,unz,area,ifc,ie)
      $                        -facint2(vxz,unx,unx,area,ifc,ie)
      $                        -facint2(vzx,unx,unx,area,ifc,ie)
      $                        -facint2(vyz,uny,unx,area,ifc,ie)
      $                        -facint2(vzy,uny,unx,area,ifc,ie)
      $                        -facint2(vzz,unz,unx,area,ifc,ie)
                      momvz=momvz-facint2(vxx,unx,uny,area,ifc,ie)
      $                        -facint2(vxx,unx,uny,area,ifc,ie)
      $                        -facint2(vyx,uny,uny,area,ifc,ie)
      $                        -facint2(vxy,uny,uny,area,ifc,ie)
      $                        -facint2(vzx,unz,uny,area,ifc,ie)
      $                        -facint2(vxz,unz,uny,area,ifc,ie)
      $                        +facint2(vxy,unx,unx,area,ifc,ie)
      $                        +facint2(vyx,unx,unx,area,ifc,ie)
      $                        +facint2(vyy,uny,unx,area,ifc,ie)
      $                        +facint2(vzy,unz,unx,area,ifc,ie)
      $                        +facint2(vyz,unz,unx,area,ifc,ie)
c
                   else
                   endif
                ENDIF
    50       CONTINUE
c
c          Sum contributions from all processors
             call gop(drag,work,'+  ',11)
             dragvx = -dragvx
             dragvy = -dragvy
             dragvz = -dragvz
          ENDIF
c
c        Scale by user specified scale factor (for convenience)
c
          dragvx = scale*dragvx
          dragvy = scale*dragvy
          dragvz = scale*dragvz
c
          dragpx = scale*dragpx
          dragpy = scale*dragpy
          dragpz = scale*dragpz
c
          dragx(iobj) = dragvx+dragpx
          dragy(iobj) = dragvy+dragpy
          dragz(iobj) = dragvz+dragpz
c
c
          momx(iobj)  = 0.5*momvx
          momy(iobj)  = 0.5*momvy
          momz(iobj)  = 0.5*momvz
c
          dragxt = dragxt + dragx(iobj)
          dragyt = dragyt + dragy(iobj)
          dragzt = dragzt + dragz(iobj)
c
          if (nid.eq.0.and.istep.eq.1)
      $      write(6,*) 'drag_calc: scale=',scale
          if (nid.eq.0) then
             write(6,6) istep,time,dragx(iobj),dragpx,dragvx,'dragx',iobj
             write(6,6) istep,time,dragy(iobj),dragpy,dragvy,'dragy',iobj
             if (if3d)
      $      write(6,6) istep,time,dragz(iobj),dragpz,dragvz,'dragz',iobj
c
c done by zly (3/17/03)
c          if(if3d) then
c             write(6,113) istep,time,momx,momy,momz
c          else
c             write(6,112) istep,time,momx,momy
c          endif
c
          endif
     6    format(i8,1p4e15.7,2x,a5,i5)
   112    format(i6,1p3e15.7,'  momx')
   113    format(i6,1p4e15.7,'  momx')
          if (istep.lt.10.and.nid.eq.0)
      $      write(6,9) 'check:',check1,check2,dpdx_mean,istep
     9    format(a6,1p3e16.8,i9)
c        if (time.gt.1.0.and.dragx.gt.10.) call emerxit
   100 continue
c
       if (nid.eq.0) then
          write(6,6) istep,time,dragxt,dragpx,dragvx,'drgxt',iobj
          write(6,6) istep,time,dragyt,dragpy,dragvy,'drgyt',iobj
          if (if3d)
      $   write(6,6) istep,time,dragzt,dragpz,dragvz,'drgzt',iobj
       endif
c
       dragx(0) = dragxt
       dragy(0) = dragyt
       dragz(0) = dragzt
c
       return
       end
       subroutine mappr(pm1,pm2,pa,pb)
c
       INCLUDE 'SIZE'
       INCLUDE 'TOTAL'
       real pm1(lx1,ly1,lz1,lelv),pm2(lx2,ly2,lz2,lelv)
      $    ,pa (lx1,ly2,lz2)     ,pb (lx1,ly1,lz2)
c
C     Map the pressure onto the velocity mesh
C
       NGLOB1 = NX1*NY1*NZ1*NELV
       NYZ2   = NY2*NZ2
       NXY1   = NX1*NY1
       NXYZ   = NX1*NY1*NZ1
C
       IF (IFSPLIT) THEN
          CALL COPY(PM1,PM2,NGLOB1)
       ELSE
          DO 1000 IEL=1,NELV
             CALL MXM (IXM21,NX1,PM2(1,1,1,IEL),NX2,pa (1,1,1),NYZ2)
             DO 100 IZ=1,NZ2
                CALL MXM (PA(1,1,IZ),NX1,IYTM21,NY2,PB(1,1,IZ),NY1)
  100        CONTINUE
             CALL MXM (PB(1,1,1),NXY1,IZTM21,NZ2,PM1(1,1,1,IEL),NZ1)
  1000    CONTINUE
C     Average the pressure on elemental boundaries
        IFIELD=1
        CALL DSSUM (PM1,NX1,NY1,NZ1)
        CALL COL2  (PM1,VMULT,NGLOB1)
       ENDIF
C
C
       return
       end
c
       function facint_a(a,area,f,e)
c     Integrate areal array a() on face f of element e.  27 June, 2012 pff
c     f  is in the preprocessor notation
       include 'SIZE'
       include 'TOPOL'
       real a(lx1,lz1,6,lelt),area(lx1,lz1,6,lelt)
       integer e,f
       sum=0.0
       do i=1,lx1*lz1
          sum = sum + a(i,1,f,e)*area(i,1,f,e)
       enddo
       facint_a = sum
       return
       end
       function facint_v(a,area,f,e)
c     Integrate volumetric array a() on face f of element e
c        fd  is the dssum notation.
c        27 June, 2012            PFF
       include 'SIZE'
       include 'TOPOL'
       real a(lx1,ly1,lz1,lelt),area(lx1,lz1,6,lelt)
       integer e,f,fd
       call dsset(nx1,ny1,nz1) ! set counters
       fd     = eface1(f)
       js1    = skpdat(1,fd)
       jf1    = skpdat(2,fd)
       jskip1 = skpdat(3,fd)
       js2    = skpdat(4,fd)
       jf2    = skpdat(5,fd)
       jskip2 = skpdat(6,fd)
       sum=0.0
       i = 0
       do 100 j2=js2,jf2,jskip2
       do 100 j1=js1,jf1,jskip1
          i = i+1
          sum = sum + a(j1,j2,1,e)*area(i,1,f,e)
   100 continue
       facint_v = sum
       return
       end
       function facint(a,b,area,ifc,ie)
c
C
C     Take the dot product of A and B on the surface IFACE1 of element IE.
C
C         IFACE1 is in the preprocessor notation
C         IFACE  is the dssum notation.
C         5 Jan 1989 15:12:22      PFF
C
       INCLUDE 'SIZE'
       INCLUDE 'TOPOL'
       DIMENSION A    (LX1,LY1,LZ1,lelv)
      $         ,B    (lx1,lz1,6,lelv)
      $         ,area (lx1,lz1,6,lelv)
C
C     Set up counters
C
       CALL DSSET(NX1,NY1,NZ1)
       IFACE  = EFACE1(IFC)
       JS1    = SKPDAT(1,IFACE)
       JF1    = SKPDAT(2,IFACE)
       JSKIP1 = SKPDAT(3,IFACE)
       JS2    = SKPDAT(4,IFACE)
       JF2    = SKPDAT(5,IFACE)
       JSKIP2 = SKPDAT(6,IFACE)
C
       SUM=0.0
       I = 0
       DO 100 J2=JS2,JF2,JSKIP2
       DO 100 J1=JS1,JF1,JSKIP1
          I = I+1
          SUM = SUM + A(J1,J2,1,ie)*B(I,1,ifc,ie)*area(I,1,ifc,ie)
c        SUM = SUM + A(J1,J2,1,ie)*B(J1,J2,1,ie)*area(I,1,ifc,ie)
   100 CONTINUE
C
       facint = SUM
c
       return
       end
       function facint2(a,b,c,area,ifc,ie)
       include 'SIZE'
       include 'TOPOL'
       dimension a    (lx1,ly1,lz1,lelv)
      $        , b    (lx1,lz1,6,lelv)
      $        , c    (lx1,lz1,6,lelv)
      $        , area (lx1,lz1,6,lelv)
       iface  = eface1(ifc)
       js1    = skpdat(1,iface)
       jf1    = skpdat(2,iface)
       jskip1 = skpdat(3,iface)
       js2    = skpdat(4,iface)
       jf2    = skpdat(5,iface)
       jskip2 = skpdat(6,iface)
       sum=0.0
       i=0
       do j2=js2,jf2,jskip2
       do j1=js1,jf1,jskip1
          i=i+1
          sum=sum+a(j1,j2,1,ie)*b(i,1,ifc,ie)*c(i,1,ifc,ie)
      $          *area(i,1,ifc,ie)
       end do
       end do
       facint2=sum
       return
       end
       subroutine out_csrmats(acsr,ia,ja,n,name9)
       real    acsr(1)
       integer ia(1),ja(1)
c
       character*9 name9
       character*9 s(16)
c
       nnz = ia(n+1)-ia(1)
c
       write(6,1) name9,n,nnz
     1 format(/,'CSR Mat:',a9,3x,'n =',i5,3x,'nnz =',i5,/)
c
       n16 = min(n,16)
       n29 = min(n,29)
       do i=1,n29
          call blank(s,9*16)
          n1 = ia(i)
          n2 = ia(i+1)-1
          do jj=n1,n2
             j = ja  (jj)
             a = acsr(jj)
             if (a.ne.0..and.j.le.n16) write(s(j),9) a
          enddo
          write(6,16) (s(k),k=1,n16)
       enddo
     9 format(f9.4)
    16 format(16a9)
c
       return
       end
       subroutine local_grad3(ur,us,ut,u,N,e,D,Dt)
c     Output: ur,us,ut         Input:u,N,e,D,Dt
       real ur(0:N,0:N,0:N),us(0:N,0:N,0:N),ut(0:N,0:N,0:N)
       real u (0:N,0:N,0:N,1)
       real D (0:N,0:N),Dt(0:N,0:N)
       integer e
c
       m1 = N+1
       m2 = m1*m1
c
       call mxm(D ,m1,u(0,0,0,e),m1,ur,m2)
       do k=0,N
          call mxm(u(0,0,k,e),m1,Dt,m1,us(0,0,k),m1)
       enddo
       call mxm(u(0,0,0,e),m2,Dt,m1,ut,m1)
c
       return
       end
       subroutine local_grad2(ur,us,u,N,e,D,Dt)
c     Output: ur,us         Input:u,N,e,D,Dt
       real ur(0:N,0:N),us(0:N,0:N)
       real u (0:N,0:N,1)
       integer e
c
       m1 = N+1
c
       call mxm(D ,m1,u(0,0,e),m1,ur,m1)
       call mxm(u(0,0,e),m1,Dt,m1,us,m1)
c
       return
       end
       subroutine gradm1(ux,uy,uz,u)
c
c     Compute gradient of T -- mesh 1 to mesh 1 (vel. to vel.)
c
       include 'SIZE'
       include 'DXYZ'
       include 'GEOM'
       include 'INPUT'
       include 'TSTEP'
c
       parameter (lxyz=lx1*ly1*lz1)
       real ux(lxyz,1),uy(lxyz,1),uz(lxyz,1),u(lxyz,1)
       common /ctmp1/ ur(lxyz),us(lxyz),ut(lxyz)
       integer e
       nxyz = nx1*ny1*nz1
       ntot = nxyz*nelt
       N = nx1-1
       do e=1,nelt
          if (if3d) then
             call local_grad3(ur,us,ut,u,N,e,dxm1,dxtm1)
             do i=1,lxyz
                ux(i,e) = jacmi(i,e)*(ur(i)*rxm1(i,1,1,e)
      $                             + us(i)*sxm1(i,1,1,e)
      $                             + ut(i)*txm1(i,1,1,e) )
                uy(i,e) = jacmi(i,e)*(ur(i)*rym1(i,1,1,e)
      $                             + us(i)*sym1(i,1,1,e)
      $                             + ut(i)*tym1(i,1,1,e) )
                uz(i,e) = jacmi(i,e)*(ur(i)*rzm1(i,1,1,e)
      $                             + us(i)*szm1(i,1,1,e)
      $                             + ut(i)*tzm1(i,1,1,e) )
             enddo
          else
             if (ifaxis) call setaxdy (ifrzer(e))
             call local_grad2(ur,us,u,N,e,dxm1,dytm1)
             do i=1,lxyz
                ux(i,e) =jacmi(i,e)*(ur(i)*rxm1(i,1,1,e)
      $                            + us(i)*sxm1(i,1,1,e) )
                uy(i,e) =jacmi(i,e)*(ur(i)*rym1(i,1,1,e)
      $                            + us(i)*sym1(i,1,1,e) )
             enddo
          endif
       enddo
c
       return
       end
       subroutine comp_vort3(vort,work1,work2,u,v,w)
c
       include 'SIZE'
       include 'TOTAL'
c
       parameter(lt=lx1*ly1*lz1*lelv)
       real vort(lt,3),work1(1),work2(1),u(1),v(1),w(1)
c
       ntot  = nx1*ny1*nz1*nelv
       if (if3d) then
c        work1=dw/dy ; work2=dv/dz
            call dudxyz(work1,w,rym1,sym1,tym1,jacm1,1,2)
            call dudxyz(work2,v,rzm1,szm1,tzm1,jacm1,1,3)
            call sub3(vort(1,1),work1,work2,ntot)
c        work1=du/dz ; work2=dw/dx
            call dudxyz(work1,u,rzm1,szm1,tzm1,jacm1,1,3)
            call dudxyz(work2,w,rxm1,sxm1,txm1,jacm1,1,1)
            call sub3(vort(1,2),work1,work2,ntot)
c        work1=dv/dx ; work2=du/dy
            call dudxyz(work1,v,rxm1,sxm1,txm1,jacm1,1,1)
            call dudxyz(work2,u,rym1,sym1,tym1,jacm1,1,2)
            call sub3(vort(1,3),work1,work2,ntot)
       else
            call sub3(vort,work1,work2,ntot)
       endif
c
c    Avg at bndry
c
       ifielt = ifield
       ifield = 1
       if (if3d) then
          do idim=1,ndim
             call col2  (vort(1,idim),bm1,ntot)
             call dssum (vort(1,idim),nx1,ny1,nz1)
             call col2  (vort(1,idim),binvm1,ntot)
          enddo
       else
          call col2  (vort,bm1,ntot)
          call dssum (vort,nx1,ny1,nz1)
          call col2  (vort,binvm1,ntot)
       endif
       ifield = ifielt
c
       return
       end
       subroutine surface_int(sint,sarea,a,ie,iface1)
C
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'TOPOL'
       real a(lx1,ly1,lz1,1)
c
       integer icalld
       save    icalld
       data    icalld/0/
       logical ifpf
       save    ifpf
c
          icalld=icalld+1
          if (skpdat(1,2).eq.nx1) then
c           write(6,*) 'In surface_int, using pf version of skpdat.'
             ifpf = .true.
          else
c           write(6,*) 'In surface_int, using std version of skpdat.'
             ifpf = .false.
          endif
       endif
C
       sarea = 0.
       sint  = 0.
C
       iface  = eface1(iface1)
c
c     Check skpdat (because of difference in pf vs. commercial version...arrghh)
c
       if (ifpf) then
c        pf version
       else
c        std version
          js1    = skpdat(iface,1)
          jf1    = skpdat(iface,2)
          jskip1 = skpdat(iface,3)
          js2    = skpdat(iface,4)
          jf2    = skpdat(iface,5)
          jskip2 = skpdat(iface,6)
       endif
C
       I = 0
          I = I+1
          sarea = sarea+area(i,1,iface1,ie)
          sint  = sint +area(i,1,iface1,ie)*a(j1,j2,1,ie)
   100 continue
C
       return
       end
       subroutine surface_flux(dq,qx,qy,qz,ie,iface,w)
C
       include 'SIZE'
       include 'GEOM'
       include 'INPUT'
       include 'PARALLEL'
       include 'TOPOL'
       parameter (l=lx1*ly1*lz1)
       real w(lx1,ly1,lz1),qx(l,1),qy(l,1),qz(l,1)
c
       integer icalld
       save    icalld
       data    icalld/0/
       logical ifpf
       save    ifpf
c
          icalld=icalld+1
c           write(6,*) 'In surface_flux, using pf version of skpdat.'
             ifpf = .true.
          else
c           write(6,*) 'In surface_flux, using std version of skpdat.'
             ifpf = .false.
          endif
       endif
C
       ifacepf  = eface1(iface)
c
c
       if (ifpf) then
c        pf version
          js1    = skpdat(1,ifacepf)
          jf1    = skpdat(2,ifacepf)
          jskip1 = skpdat(3,ifacepf)
          js2    = skpdat(4,ifacepf)
          jf2    = skpdat(5,ifacepf)
          jskip2 = skpdat(6,ifacepf)
       else
c        std version
          js1    = skpdat(ifacepf,1)
          jf1    = skpdat(ifacepf,2)
          jskip1 = skpdat(ifacepf,3)
          js2    = skpdat(ifacepf,4)
          jf2    = skpdat(ifacepf,5)
          jskip2 = skpdat(ifacepf,6)
       endif
C
       call faccl3 (w,qx(1,ie),unx(1,1,iface,ie),iface)
       call faddcl3(w,qy(1,ie),uny(1,1,iface,ie),iface)
       if (if3d)
      $call faddcl3(w,qz(1,ie),unz(1,1,iface,ie),iface)
c
       dq = 0
       i  = 0
          i = i+1
          dq    = dq   +area(i,1,iface,ie)*w(j1,j2,1)
   100 continue
C
       return
       end
       subroutine gaujordf(a,m,n,indr,indc,ipiv,ierr,rmult)
C
C     Gauss-Jordan matrix inversion with full pivoting
c
c     Num. Rec. p. 30, 2nd Ed., Fortran
c
C
C     a     is an m x n matrix
C     rmult is a  work array of dimension m
C
c
       real a(m,n),rmult(m)
       integer indr(m),indc(n),ipiv(n)
c     call outmat(a,m,n,'ab4',n)
c     do i=1,m
c        write(6,1) (a(i,j),j=1,n)
c     enddo
c 1   format('mat: ',1p6e12.4)
       ierr = 0
       eps = 1.e-9
       call izero(ipiv,m)
       do k=1,m
          amx=0.
          do i=1,m                    ! Pivot search
             if (ipiv(i).ne.1) then
                do j=1,m
                   if (ipiv(j).eq.0) then
                     if (abs(a(i,j)).ge.amx) then
                        amx = abs(a(i,j))
                        ir  = i
                        jc  = j
                     endif
                  elseif (ipiv(j).gt.1) then
                     ierr = -ipiv(j)
                     return
                  endif
               enddo
            endif
         enddo
         ipiv(jc) = ipiv(jc) + 1
c
c       Swap rows
         if (ir.ne.jc) then
            do j=1,n
               tmp     = a(ir,j)
               a(ir,j) = a(jc,j)
               a(jc,j) = tmp
            enddo
         endif
         indr(k)=ir
         indc(k)=jc
c       write(6 ,*) k,' Piv:',jc,a(jc,jc)
c       write(28,*) k,' Piv:',jc,a(jc,jc)
         if (abs(a(jc,jc)).lt.eps) then
            write(6 ,*) 'small Gauss Jordan Piv:',jc,a(jc,jc)
            write(28,*) 'small Gauss Jordan Piv:',jc,a(jc,jc)
            ierr = jc
            call exitt
            return
         endif
         piv = 1./a(jc,jc)
         a(jc,jc)=1.
         do j=1,n
            a(jc,j) = a(jc,j)*piv
         enddo
c
         do j=1,n
            work    = a(jc,j)
            a(jc,j) = a(1 ,j)
            a(1 ,j) = work
         enddo
         do i=2,m
            rmult(i) = a(i,jc)
            a(i,jc)  = 0.
         enddo
c
         do j=1,n
         do i=2,m
            a(i,j) = a(i,j) - rmult(i)*a(1,j)
         enddo
         enddo
c
         do j=1,n
            work    = a(jc,j)
            a(jc,j) = a(1 ,j)
            a(1 ,j) = work
         enddo
c
c       do i=1,m
c          if (i.ne.jc) then
c             rmult   = a(i,jc)
c             a(i,jc) = 0.
c             do j=1,n
c                a(i,j) = a(i,j) - rmult*a(jc,j)
c             enddo
c          endif
c       enddo
c
       enddo
c
c     Unscramble matrix
       do j=m,1,-1
          if (indr(j).ne.indc(j)) then
             do i=1,m
                tmp=a(i,indr(j))
                a(i,indr(j))=a(i,indc(j))
                a(i,indc(j))=tmp
             enddo
          endif
       enddo
c
       return
       end
       subroutine legendre_poly(L,x,N)
c
c     Evaluate Legendre polynomials of degrees 0-N at point x
c
       real L(0:N)
c
       L(0) = 1.
       L(1) = x
c
       do j=2,N
          L(j) = ( (2*j-1) * x * L(j-1) - (j-1) * L(j-2) ) / j
       enddo
c
       return
       end
       subroutine build_new_filter(intv,zpts,nx,kut,wght,nid)
c
c     This routing builds a 1D filter with a transfer function that
c     looks like:
c
c
c        ^
c    d_k |
c        |                 |
c     1  |__________      _v_
c        |          -_
c        |            \  wght
c        |             \  ___
c        |             |   ^
c     0  |-------------|---|>
c
c        0         c   N   k-->
c
c        Where c := N-kut is the point below which d_k = 1.
c
c
c
c      Here, nx = number of points
c
       real intv(nx,nx),zpts(nx)
c
       parameter (lm=40)
       parameter (lm2=lm*lm)
       real      phi(lm2),pht(lm2),diag(lm2),rmult(lm),Lj(lm)
       integer   indr(lm),indc(lm),ipiv(lm)
c
       if (nx.gt.lm) then
          write(6,*) 'ABORT in build_new_filter:',nx,lm
          call exitt
       endif
c
       kj = 0
       n  = nx-1
       do j=1,nx
          z = zpts(j)
          call legendre_poly(Lj,z,n)
          kj = kj+1
          pht(kj) = Lj(1)
          kj = kj+1
          pht(kj) = Lj(2)
          do k=3,nx
             kj = kj+1
             pht(kj) = Lj(k)-Lj(k-2)
          enddo
       enddo
       call transpose (phi,nx,pht,nx)
       call copy      (pht,phi,nx*nx)
       call gaujordf  (pht,nx,nx,indr,indc,ipiv,ierr,rmult)
c
c     Set up transfer function
c
       call ident   (diag,nx)
c
       k0 = nx-kut
       do k=k0+1,nx
          kk = k+nx*(k-1)
          amp = wght*(k-k0)*(k-k0)/(kut*kut)   ! quadratic growth
          diag(kk) = 1.-amp
       enddo
c
       call mxm  (diag,nx,pht,nx,intv,nx)      !          -1
       call mxm  (phi ,nx,intv,nx,pht,nx)      !     V D V
       call copy (intv,pht,nx*nx)
c
       do k=1,nx*nx
          pht(k) = 1.-diag(k)
       enddo
       np1 = nx+1
       if (nid.eq.0) then
          write(6,6) 'filt amp',(pht (k),k=1,nx*nx,np1)
          write(6,6) 'filt trn',(diag(k),k=1,nx*nx,np1)
    6     format(a8,16f7.4,6(/,8x,16f7.4))
       endif
c
       return
       end
       subroutine avg_all
c
c     This routine computes running averages E(X),E(X^2),E(X*Y)
c     and outputs to avg*.fld*, rms*.fld*, and rm2*.fld* for all
c     fields.
c
c     E denotes the expected value operator and X,Y two
c     real valued random variables.
c
c     variances and covariances can be computed in a post-processing step:
c
c        var(X)   := E(X^X) - E(X)*E(X)
c        cov(X,Y) := E(X*Y) - E(X)*E(Y)
c
c     Note: The E-operator is linear, in the sense that the expected
c           value is given by E(X) = 1/N * sum[ E(X)_i ], where E(X)_i
c           is the expected value of the sub-ensemble i (i=1...N).
c
       include 'SIZE'
       include 'TOTAL'
       include 'AVG'
       logical ifverbose
       integer icalld
       save    icalld
       data    icalld  /0/
       if (ax1.ne.lx1 .or. ay1.ne.ly1 .or. az1.ne.lz1) then
          if(nid.eq.0) write(6,*)
      $     'ABORT: wrong size of ax1,ay1,az1 in avg_all(), check SIZE!'
          call exitt
       endif
       if (ax2.ne.lx2 .or. ay2.ne.ay2 .or. az2.ne.lz2) then
      $     'ABORT: wrong size of ax2,ay2,az2 in avg_all(), check SIZE!'
          call exitt
       endif
       ntott = nx1*ny1*nz1*nelt
       nto2  = nx2*ny2*nz2*nelv
       ! initialization
          icalld = icalld + 1
          atime  = 0.
          timel  = time
          call rzero(uavg,ntot)
          call rzero(vavg,ntot)
          call rzero(wavg,ntot)
          call rzero(pavg,nto2)
          do i = 1,ldimt
             call rzero(tavg(1,1,1,1,i),ntott)
          enddo
          call rzero(urms,ntot)
          call rzero(vrms,ntot)
          call rzero(wrms,ntot)
          call rzero(prms,nto2)
          do i = 1,ldimt
             call rzero(trms(1,1,1,1,i),ntott)
          enddo
          call rzero(vwms,ntot)
          call rzero(wums,ntot)
          call rzero(uvms,ntot)
       endif
       dtime = time  - timel
       atime = atime + dtime
       ! dump freq
       iastep = param(68)
       if  (iastep.eq.0) iastep=param(15)   ! same as iostep
       if  (iastep.eq.0) iastep=500
       ifverbose=.false.
       if (istep.le.10) ifverbose=.true.
       if  (mod(istep,iastep).eq.0) ifverbose=.true.
       if (atime.ne.0..and.dtime.ne.0.) then
          if(nid.eq.0) write(6,*) 'Compute statistics ...'
          beta  = dtime/atime
          alpha = 1.-beta
          ! compute averages E(X)
          call avg1    (uavg,vx,alpha,beta,ntot ,'um  ',ifverbose)
          call avg1    (vavg,vy,alpha,beta,ntot ,'vm  ',ifverbose)
          call avg1    (wavg,vz,alpha,beta,ntot ,'wm  ',ifverbose)
          call avg1    (pavg,pr,alpha,beta,nto2 ,'prm ',ifverbose)
          call avg1    (tavg,t ,alpha,beta,ntott,'tm  ',ifverbose)
          do i = 2,ldimt
             call avg1 (tavg(1,1,1,1,i),t(1,1,1,1,i),alpha,beta,
      &                 ntott,'psav',ifverbose)
          enddo
          ! compute averages E(X^2)
          call avg2    (urms,vx,alpha,beta,ntot ,'ums ',ifverbose)
          call avg2    (vrms,vy,alpha,beta,ntot ,'vms ',ifverbose)
          call avg2    (wrms,vz,alpha,beta,ntot ,'wms ',ifverbose)
          call avg2    (prms,pr,alpha,beta,nto2 ,'prms',ifverbose)
          call avg2    (trms,t ,alpha,beta,ntott,'tms ',ifverbose)
          do i = 2,ldimt
             call avg2 (trms(1,1,1,1,i),t(1,1,1,1,i),alpha,beta,
      &                 ntott,'psms',ifverbose)
          enddo
          ! compute averages E(X*Y) (for now just for the velocities)
          call avg3    (uvms,vx,vy,alpha,beta,ntot,'uvm ',ifverbose)
          call avg3    (vwms,vy,vz,alpha,beta,ntot,'vwm ',ifverbose)
          call avg3    (wums,vz,vx,alpha,beta,ntot,'wum ',ifverbose)
       endif
c
       if ( (mod(istep,iastep).eq.0.and.istep.gt.1) .or.lastep.eq.1) then
          time_temp = time
          time      = atime   ! Output the duration of this avg
          call outpost2(uavg,vavg,wavg,pavg,tavg,ldimt,'avg')
          call outpost2(urms,vrms,wrms,prms,trms,ldimt,'rms')
          call outpost (uvms,vwms,wums,prms,trms,      'rm2')
          atime = 0.
          time  = time_temp  ! Restore clock
       endif
c
       timel = time
c
       return
       end
       subroutine avg1(avg,f,alpha,beta,n,name,ifverbose)
       include 'SIZE'
       include 'TSTEP'
c
       real avg(n),f(n)
       character*4 name
       logical ifverbose
c
       do k=1,n
          avg(k) = alpha*avg(k) + beta*f(k)
       enddo
c
       if (ifverbose) then
          avgmax = glmax(avg,n)
          avgmin = glmin(avg,n)
          if (nid.eq.0) write(6,1) istep,time,avgmin,avgmax
      $                           ,alpha,beta,name
     1    format(i9,1p5e13.5,1x,a4,' av1mnx')
       endif
c
       return
       end
       subroutine avg2(avg,f,alpha,beta,n,name,ifverbose)
       include 'SIZE'
       include 'TSTEP'
c
       real avg(n),f(n)
       character*4 name
       logical ifverbose
c
       do k=1,n
          avg(k) = alpha*avg(k) + beta*f(k)*f(k)
       enddo
c
       if (ifverbose) then
      $                           ,alpha,beta,name
     1    format(i9,1p5e13.5,1x,a4,' av2mnx')
       endif
c
       return
       end
       subroutine avg3(avg,f,g,alpha,beta,n,name,ifverbose)
       include 'SIZE'
       include 'TSTEP'
c
       real avg(n),f(n),g(n)
       character*4 name
       logical ifverbose
c
       do k=1,n
          avg(k) = alpha*avg(k) + beta*f(k)*g(k)
       enddo
c
       if (ifverbose) then
      $                           ,alpha,beta,name
     1    format(i9,1p5e13.5,1x,a4,' av3mnx')
       endif
c
       return
       end
       subroutine build_legend_transform(Lj,Ljt,zpts,nx)
c
       real Lj(nx*nx),Ljt(nx*nx),zpts(nx)
c
       parameter (lm=90)
c
       if (nx.gt.lm) then
          write(6,*) 'ABORT in build_legend_transform:',nx,lm
          call exitt
       endif
c
       j = 1
       n = nx-1
       do i=1,nx
          z = zpts(i)
          call legendre_poly(Lj(j),z,n)  ! Return Lk(z), k=0,...,n
          j = j+nx
       enddo
       call transpose1(Lj,nx)
c     call outmat(Lj,nx,nx,'Lj ',n)
c     call exitt
       call gaujordf  (Lj,nx,nx,indr,indc,ipiv,ierr,rmult)
       call transpose (Ljt,nx,Lj,nx)
c
       return
       end
       subroutine local_err_est(err,u,nx,Lj,Ljt,uh,w,if3d)
c
c     Local error estimates for u_e
c
       include 'SIZE'
       real err(5,2),u(1),uh(nx,nx,nx),w(1),Lj(1),Ljt(1)
       logical if3d
c
       call rzero(err,10)
c
       nxyz = nx**ndim
       utot = vlsc2(u,u,nxyz)
       if (utot.eq.0) return
c
       call tensr3(uh,nx,u,nx,Lj,Ljt,Ljt,w)    !  Go to Legendre space
c
c
c     Get energy in low modes
c
       m = nx-2
c
       if (if3d) then
          amp2_l = 0.
          do k=1,m
          do j=1,m
          do i=1,m
             amp2_l = amp2_l + uh(i,j,k)**2
          enddo
          enddo
          enddo
c
c        Energy in each spatial direction
c
          amp2_t = 0
          do k=m+1,nx
          do j=1,m
          do i=1,m
             amp2_t = amp2_t + uh(i,j,k)**2
          enddo
          enddo
          enddo
c
          amp2_s = 0
          do k=1,m
          do j=m+1,nx
          do i=1,m
             amp2_s = amp2_s + uh(i,j,k)**2
          enddo
          enddo
          enddo
c
          amp2_r = 0
          do k=1,m
          do j=1,m
          do i=m+1,nx
             amp2_r = amp2_r + uh(i,j,k)**2
          enddo
          enddo
          enddo
c
          amp2_h = 0
          do k=m+1,nx
          do j=m+1,nx
          do i=m+1,nx
             amp2_h = amp2_h + uh(i,j,k)**2
          enddo
          enddo
          enddo
c
          etot = amp2_l + amp2_r + amp2_s + amp2_t + amp2_h
c
          relr = amp2_r / (amp2_r + amp2_l)
          rels = amp2_s / (amp2_s + amp2_l)
          relt = amp2_t / (amp2_t + amp2_l)
          relh = (amp2_r + amp2_s + amp2_t + amp2_h) / etot
c
       else
          k = 1
          amp2_l = 0.
          do j=1,m
          do i=1,m
          enddo
          enddo
          if (amp2_l.eq.0) return
c
c
          amp2_t = 0
c
          amp2_s = 0
          do j=m+1,nx
          do i=1,m
          enddo
          enddo
c
          amp2_r = 0
          do j=1,m
          do i=m+1,nx
          enddo
          enddo
c
          amp2_h = 0
          do j=m+1,nx
          do i=m+1,nx
          enddo
          enddo
c
          etot = amp2_l + amp2_r + amp2_s + amp2_h
c
          relt = 0
          relh = (amp2_r + amp2_s + amp2_h) / etot
c
       endif
c
       err (1,1) = sqrt(relr)
       err (2,1) = sqrt(rels)
       if (if3d) err (3,1) = sqrt(relt)
       err (4,1) = sqrt(relh)
       err (5,1) = sqrt(etot)
c
       err (1,2) = sqrt(amp2_r)
       err (2,2) = sqrt(amp2_s)
       if (if3d) err (3,2) = sqrt(amp2_t)
       err (4,2) = sqrt(amp2_h)
       err (5,2) = sqrt(utot)
c
       return
       end
       subroutine transpose1(a,n)
       real a(n,n)
c
       do j=1,n
       do i=j+1,n
          ta     = a(i,j)
          a(i,j) = a(j,i)
          a(j,i) = ta
       enddo
       enddo
       return
       end
       subroutine get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
       integer ex,ey,ez,eg
c
       nelxy = nelx*nely
c
       ez = 1 +  (eg-1)/nelxy
       ey = mod1 (eg,nelxy)
       ey = 1 +  (ey-1)/nelx
       ex = mod1 (eg,nelx)
c
       return
       end
       subroutine dump_header2d(excode,nx,ny,nlx,nly,ierr)
       include 'SIZE'
       include 'TOTAL'
       character*2 excode(15)
       real*4         test_pattern
       character*1 fhdfle1(132)
       character*132 fhdfle
       equivalence (fhdfle,fhdfle1)
       jstep = istep
       if (jstep.gt.10000) jstep = jstep / 10
       nlxy = nlx*nly
       nzz  = 1
c     write(6,'(4i4,1PE14.7,i5,1x,15a2,1x,a12)')
c    $  nlxy,nx,ny,nzz,TIME,jstep,(excode(i),i=1,15),
c    $  'NELT,NX,NY,N'
c
       p66 = 0.
       ierr= 0
       IF (p66.EQ.1.0) THEN
C       unformatted i/o
         WRITE(24)
       ELSEIF (p66.EQ.3.0) THEN
C       formatted i/o to header file
         WRITE(27,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
      $  'NELT,NX,NY,N'
       ELSEIF (p66.eq.4.0) THEN
         WRITE(fhdfle,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
      $  ' 4 NELT,NX,NY,N'
         call byte_write(fhdfle,20,ierr)
       ELSEIF (p66.eq.5.0) THEN
      $  ' 8 NELT,NX,NY,N'
       ELSE
C       formatted i/o
         WRITE(24,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
      $  'NELT,NX,NY,N'
       ENDIF
C     cdrror is a dummy cerror value for now.
       CDRROR=0.0
C       unformatted i/o
         WRITE(24)(CDRROR,I=1,nlxy)
       ELSEIF (p66.eq.3. .or. p66.eq.4.0) then
C       write byte-ordering test pattern to byte file...
         test_pattern = 6.54321
         call byte_write(test_pattern,1,ierr)
       ELSEIF (p66.eq.5.) then
         test_pattern8 = 6.54321
         call byte_write(test_pattern8,2,ierr)
       ELSE
C       formatted i/o
         WRITE(24,'(6G11.4)')(CDRROR,I=1,nlxy)
       ENDIF
       return
       end
       subroutine outfld2d_p(u,v,w,nx,ny,nlx,nly,name,ifld,jid,npido,ir)
       include 'SIZE'
       include 'TOTAL'
       integer icalld
       save    icalld
       data    icalld /0/
       real u(nx*ny*nlx*nly)
       real v(nx*ny*nlx*nly)
       real w(nx*ny*nlx*nly)
       character*4 name
       character*12 fm
       character*20 outfile
       character*1 slash,dot
       save        slash,dot
       data        slash,dot  / '/' , '.' /
       icalld = icalld+1
       call blank(excode,30)
       excode(4) = 'U '
       excode(5) = '  '
       excode(6) = 'T '
       nthings   =  3
       ir = 0 !error code for dump_header2d
       call blank(outfile,20)
       if (npido.lt.100) then
          if (ifld.lt.100) then
             write(outfile,22) jid,slash,name,ifld
    22       format('B',i2.2,a1,a4,'.fld',i2.2)
          elseif (ifld.lt.1000) then
             write(outfile,23) jid,slash,name,ifld
    23       format('B',i2.2,a1,a4,'.fld',i3)
          elseif (ifld.lt.10000) then
             write(outfile,24) jid,slash,name,ifld
    24       format('B',i2.2,a1,a4,'.fld',i4)
          elseif (ifld.lt.100000) then
             write(outfile,25) jid,slash,name,ifld
    25       format('B',i2.2,a1,a4,'.fld',i5)
          elseif (ifld.lt.1000000) then
             write(outfile,26) jid,slash,name,ifld
    26       format('B',i2.2,a1,a4,'.fld',i6)
          endif
       else
             write(outfile,32) jid,slash,name,ifld
    32       format('B',i3.3,a1,a4,'.fld',i2.2)
             write(outfile,33) jid,slash,name,ifld
    33       format('B',i3.3,a1,a4,'.fld',i3)
             write(outfile,34) jid,slash,name,ifld
    34       format('B',i3.3,a1,a4,'.fld',i4)
             write(outfile,35) jid,slash,name,ifld
    35       format('B',i3.3,a1,a4,'.fld',i5)
             write(outfile,36) jid,slash,name,ifld
    36       format('B',i3.3,a1,a4,'.fld',i6)
          endif
       endif
       if (icalld.le.4) write(6,*) nid,outfile,' OPEN',nlx,nly
       open(unit=24,file=outfile,status='unknown')
       call dump_header2d(excode,nx,ny,nlx,nly,ir)
       n = nx*ny*nlx*nly
       write(fm,10) nthings
       write(24,fm) (u(i),v(i),w(i),i=1,n)
    10 format('(1p',i1,'e14.6)')
       close(24)
       return
       end
       subroutine outfld2d(u,v,w,nx,ny,nlx,nly,name,ifld)
       include 'SIZE'
       include 'TOTAL'
       character*3 name
       character*12 fm
c     if (istep.le.10) write(6,*) nid,' in out2d:',iz
c
c     excode(1) = 'X '
c     excode(2) = 'Y '
c     excode(3) = 'U '
c     excode(4) = 'V '
c     excode(5) = 'P '
c     excode(6) = 'T '
c
       excode(4) = 'U '
       excode(5) = '  '
       excode(6) = 'T '
       nthings   =  3
       ierr = 0
       if (nid.eq.0) then
             write(outfile,2) name,ifld
     2       format(a3,'2d.fld',i2.2)
             write(outfile,3) name,ifld
     3       format(a3,'2d.fld',i3)
             write(outfile,4) name,ifld
     4       format(a3,'2d.fld',i4)
             write(outfile,5) name,ifld
     5       format(a3,'2d.fld',i5)
             write(outfile,6) name,ifld
     6       format(a3,'2d.fld',i6)
          endif
          call dump_header2d(excode,nx,ny,nlx,nly,ierr)
          n = nx*ny*nlx*nly
c        write(6,*) fm
c        call exitt
c  10    format('''(1p',i1,'e15.7)''')
c  10    format(1p7e15.7)
c
          close(24)
       endif
       call err_chk(ierr,'Error using byte_write,outfld2d. Abort.$')
       return
       end
       subroutine planar_average_z(ua,u,w1,w2)
c
c     Compute r-s planar average of quantity u()
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
c
       real ua(nz1,nelz),u(nx1*ny1,nz1,nelv),w1(nz1,nelz),w2(nz1,nelz)
       integer e,eg,ez
c
       melxy = nelx*nely
c
       nz = nz1*nelz
       call rzero(ua,nz)
       call rzero(w1,nz)
c
       do e=1,nelt
c
          eg = lglel(e)
          ez = 1 + (eg-1)/melxy
c
          do k=1,nz1
          do i=1,nx1*ny1
             zz = (1.-zgm1(k,3))/2.  ! = 1 for k=1, = 0 for k=nz1
             aa = zz*area(i,1,5,e) + (1-zz)*area(i,1,6,e)  ! wgtd jacobian
             w1(k,ez) = w1(k,ez) + aa
             ua(k,ez) = ua(k,ez) + aa*u(i,k,e)
          enddo
          enddo
       enddo
c
       call gop(ua,w2,'+  ',nz)
       call gop(w1,w2,'+  ',nz)
c
       do i=1,nz
          ua(i,1) = ua(i,1) / w1(i,1)   ! Normalize
       enddo
c
       return
       end
       subroutine drgtrq(dgtq,xm0,ym0,zm0,sij,pm1,visc,f,e)
c
       INCLUDE 'SIZE'
       INCLUDE 'GEOM'
       INCLUDE 'INPUT'
       INCLUDE 'TOPOL'
       INCLUDE 'TSTEP'
c
       real dgtq(3,4)
       real xm0 (lx1,ly1,lz1,lelt)
       real ym0 (lx1,ly1,lz1,lelt)
       real zm0 (lx1,ly1,lz1,lelt)
       real sij (lx1,ly1,lz1,3*ldim-3,lelv)
       real pm1 (lx1,ly1,lz1,lelv)
       real visc(lx1,ly1,lz1,lelv)
c
       real dg(3,2)
c
       integer f,e,pf
       real    n1,n2,n3
c
       call dsset(nx1,ny1,nz1)    ! set up counters
       pf     = eface1(f)         ! convert from preproc. notation
       js1    = skpdat(1,pf)
       jf1    = skpdat(2,pf)
       jskip1 = skpdat(3,pf)
       js2    = skpdat(4,pf)
       jf2    = skpdat(5,pf)
       jskip2 = skpdat(6,pf)
C
       call rzero(dgtq,12)
c
       if (if3d.or.ifaxis) then
        i = 0
        a = 0
          i = i+1
          n1 = unx(i,1,f,e)*area(i,1,f,e)
          n2 = uny(i,1,f,e)*area(i,1,f,e)
          n3 = unz(i,1,f,e)*area(i,1,f,e)
          a  = a +          area(i,1,f,e)
c
          v  = visc(j1,j2,1,e)
c
          s11 = sij(j1,j2,1,1,e)
          s21 = sij(j1,j2,1,4,e)
          s31 = sij(j1,j2,1,6,e)
c
          s12 = sij(j1,j2,1,4,e)
          s22 = sij(j1,j2,1,2,e)
          s32 = sij(j1,j2,1,5,e)
c
          s13 = sij(j1,j2,1,6,e)
          s23 = sij(j1,j2,1,5,e)
          s33 = sij(j1,j2,1,3,e)
c
          dg(1,1) = pm1(j1,j2,1,e)*n1     ! pressure drag
          dg(2,1) = pm1(j1,j2,1,e)*n2
          dg(3,1) = pm1(j1,j2,1,e)*n3
c
          dg(1,2) = -v*(s11*n1 + s12*n2 + s13*n3) ! viscous drag
          dg(2,2) = -v*(s21*n1 + s22*n2 + s23*n3)
          dg(3,2) = -v*(s31*n1 + s32*n2 + s33*n3)
c
          r1 = xm0(j1,j2,1,e)
          r2 = ym0(j1,j2,1,e)
          r3 = zm0(j1,j2,1,e)
c
          do l=1,2
          do k=1,3
             dgtq(k,l) = dgtq(k,l) + dg(k,l)
          enddo
          enddo
c
          dgtq(1,3) = dgtq(1,3) + (r2*dg(3,1)-r3*dg(2,1)) ! pressure
          dgtq(2,3) = dgtq(2,3) + (r3*dg(1,1)-r1*dg(3,1)) ! torque
          dgtq(3,3) = dgtq(3,3) + (r1*dg(2,1)-r2*dg(1,1))
c
          dgtq(1,4) = dgtq(1,4) + (r2*dg(3,2)-r3*dg(2,2)) ! viscous
          dgtq(2,4) = dgtq(2,4) + (r3*dg(1,2)-r1*dg(3,2)) ! torque
          dgtq(3,4) = dgtq(3,4) + (r1*dg(2,2)-r2*dg(1,2))
        enddo
        enddo
       else ! 2D
        i = 0
        a = 0
          i = i+1
          v  = visc(j1,j2,1,e)
          s12 = sij(j1,j2,1,3,e)
          s21 = sij(j1,j2,1,3,e)
          dg(3,1) = 0
          dg(1,2) = -v*(s11*n1 + s12*n2) ! viscous drag
          dg(2,2) = -v*(s21*n1 + s22*n2)
          dg(3,2) = 0.
          r1 = xm0(j1,j2,1,e)
          r2 = ym0(j1,j2,1,e)
          r3 = 0.
          do l=1,2
          do k=1,3
          enddo
          enddo
          dgtq(1,3) = 0! dgtq(1,3) + (r2*dg(3,1)-r3*dg(2,1)) ! pressure
          dgtq(2,3) = 0! dgtq(2,3) + (r3*dg(1,1)-r1*dg(3,1)) ! torque
          dgtq(1,4) = 0! dgtq(1,4) + (r2*dg(3,2)-r3*dg(2,2)) ! viscous
          dgtq(2,4) = 0! dgtq(2,4) + (r3*dg(1,2)-r1*dg(3,2)) ! torque
        enddo
        enddo
       endif
       return
       end
       subroutine torque_calc(scale,x0,ifdout,iftout)
c
c     Compute torque about point x0
c
c     Scale is a user-supplied multiplier so that results may be
c     scaled to any convenient non-dimensionalization.
c
c
       INCLUDE 'SIZE'
       INCLUDE 'TOTAL'
      $                , scale_vf(3)
c
       real x0(3),w1(0:maxobj)
       logical ifdout,iftout
c
       common /scrns/         sij (lx1*ly1*lz1*6*lelv)
       common /scrcg/         pm1 (lx1,ly1,lz1,lelv)
       common /scrsf/         xm0(lx1,ly1,lz1,lelt)
      $,                      ym0(lx1,ly1,lz1,lelt)
      $,                      zm0(lx1,ly1,lz1,lelt)
c
       parameter (lr=lx1*ly1*lz1)
       common /scruz/         ur(lr),us(lr),ut(lr)
      $                     , vr(lr),vs(lr),vt(lr)
      $                     , wr(lr),ws(lr),wt(lr)
c
       common /ctorq/ dragx(0:maxobj),dragpx(0:maxobj),dragvx(0:maxobj)
      $             , dragy(0:maxobj),dragpy(0:maxobj),dragvy(0:maxobj)
      $             , dragz(0:maxobj),dragpz(0:maxobj),dragvz(0:maxobj)
c
      $             , torqx(0:maxobj),torqpx(0:maxobj),torqvx(0:maxobj)
      $             , torqy(0:maxobj),torqpy(0:maxobj),torqvy(0:maxobj)
      $             , torqz(0:maxobj),torqpz(0:maxobj),torqvz(0:maxobj)
c
      $             , dgtq(3,4)
c
c
       n = nx1*ny1*nz1*nelv
c
       call mappr(pm1,pr,xm0,ym0) ! map pressure onto Mesh 1
c
       endif
       call add2s2(pm1,xm1,dpdx_mean,n)  ! Doesn't work if object is cut by
       call add2s2(pm1,ym1,dpdy_mean,n)  ! periodicboundary.  In this case,
       call add2s2(pm1,zm1,dpdz_mean,n)  ! set ._mean=0 and compensate in
c
c    Compute sij
c
       nij = 3
       if (if3d.or.ifaxis) nij=6
       call comp_sij(sij,nij,vx,vy,vz,ur,us,ut,vr,vs,vt,wr,ws,wt)
c
c
c
       if (istep.lt.1) call cfill(vdiff,param(2),n)
c
       call cadd2(xm0,xm1,-x0(1),n)
       call cadd2(ym0,ym1,-x0(2),n)
       call cadd2(zm0,zm1,-x0(3),n)
c
       x1min=glmin(xm0(1,1,1,1),n)
       x2min=glmin(ym0(1,1,1,1),n)
       x3min=glmin(zm0(1,1,1,1),n)
c
       x1max=glmax(xm0(1,1,1,1),n)
       x2max=glmax(ym0(1,1,1,1),n)
       x3max=glmax(zm0(1,1,1,1),n)
c
       do i=0,maxobj
          dragpx(i) = 0   ! BIG CODE  :}
          dragvx(i) = 0
          dragx (i) = 0
          dragpy(i) = 0
          dragvy(i) = 0
          dragy (i) = 0
          dragpz(i) = 0
          dragvz(i) = 0
          dragz (i) = 0
          torqpx(i) = 0
          torqvx(i) = 0
          torqx (i) = 0
          torqpy(i) = 0
          torqvy(i) = 0
          torqy (i) = 0
          torqpz(i) = 0
          torqvz(i) = 0
          torqz (i) = 0
       enddo
c
c
       nobj = 0
       do ii=1,nhis
         if (hcode(10,ii).EQ.'I') then
           iobj   = lochis(1,ii)
           memtot = nmember(iobj)
           nobj   = max(iobj,nobj)
c
           if (hcode(1,ii).ne.' ' .or. hcode(2,ii).ne.' ' .or.
      $      hcode(3,ii).ne.' ' ) then
             ifield = 1
c
c
             do mem=1,memtot
                ieg   = object(iobj,mem,1)
                ifc   = object(iobj,mem,2)
                if (gllnid(ieg).eq.nid) then ! this processor has a contribution
                   ie = gllel(ieg)
                   call drgtrq(dgtq,xm0,ym0,zm0,sij,pm1,vdiff,ifc,ie)
c
                   call cmult(dgtq,scale,12)
c
                   dragpx(iobj) = dragpx(iobj) + dgtq(1,1)  ! pressure
                   dragpy(iobj) = dragpy(iobj) + dgtq(2,1)
                   dragpz(iobj) = dragpz(iobj) + dgtq(3,1)
c
                   dragvx(iobj) = dragvx(iobj) + dgtq(1,2)  ! viscous
                   dragvy(iobj) = dragvy(iobj) + dgtq(2,2)
                   dragvz(iobj) = dragvz(iobj) + dgtq(3,2)
c
                   torqpx(iobj) = torqpx(iobj) + dgtq(1,3)  ! pressure
                   torqpy(iobj) = torqpy(iobj) + dgtq(2,3)
                   torqpz(iobj) = torqpz(iobj) + dgtq(3,3)
c
                   torqvx(iobj) = torqvx(iobj) + dgtq(1,4)  ! viscous
                   torqvy(iobj) = torqvy(iobj) + dgtq(2,4)
                   torqvz(iobj) = torqvz(iobj) + dgtq(3,4)
c
                endif
             enddo
           endif
         endif
       enddo
c
c
       call gop(dragpx,w1,'+  ',maxobj+1)
       call gop(dragpy,w1,'+  ',maxobj+1)
       call gop(dragpz,w1,'+  ',maxobj+1)
       call gop(dragvx,w1,'+  ',maxobj+1)
       call gop(dragvy,w1,'+  ',maxobj+1)
       call gop(dragvz,w1,'+  ',maxobj+1)
c
       call gop(torqpx,w1,'+  ',maxobj+1)
       call gop(torqpy,w1,'+  ',maxobj+1)
       call gop(torqpz,w1,'+  ',maxobj+1)
       call gop(torqvx,w1,'+  ',maxobj+1)
       call gop(torqvy,w1,'+  ',maxobj+1)
       call gop(torqvz,w1,'+  ',maxobj+1)
c
       nobj = iglmax(nobj,1)
c
       do i=1,nobj
          dragx(i) = dragpx(i) + dragvx(i)
          dragy(i) = dragpy(i) + dragvy(i)
          dragz(i) = dragpz(i) + dragvz(i)
c
          torqx(i) = torqpx(i) + torqvx(i)
          torqy(i) = torqpy(i) + torqvy(i)
          torqz(i) = torqpz(i) + torqvz(i)
c
          dragpx(0) = dragpx (0) + dragpx (i)
          dragvx(0) = dragvx (0) + dragvx (i)
          dragx (0) = dragx  (0) + dragx  (i)
c
          dragpy(0) = dragpy (0) + dragpy (i)
          dragvy(0) = dragvy (0) + dragvy (i)
          dragy (0) = dragy  (0) + dragy  (i)
c
          dragpz(0) = dragpz (0) + dragpz (i)
          dragvz(0) = dragvz (0) + dragvz (i)
          dragz (0) = dragz  (0) + dragz  (i)
c
          torqpx(0) = torqpx (0) + torqpx (i)
          torqvx(0) = torqvx (0) + torqvx (i)
          torqx (0) = torqx  (0) + torqx  (i)
c
          torqpy(0) = torqpy (0) + torqpy (i)
          torqvy(0) = torqvy (0) + torqvy (i)
          torqy (0) = torqy  (0) + torqy  (i)
c
          torqpz(0) = torqpz (0) + torqpz (i)
          torqvz(0) = torqvz (0) + torqvz (i)
          torqz (0) = torqz  (0) + torqz  (i)
c
       enddo
c
       i0 = 0
       if (nobj.le.1) i0 = 1  ! one output for single-object case
c
       do i=i0,nobj
         if (nid.eq.0) then
            if (ifdout) then
             write(6,6) istep,time,dragx(i),dragpx(i),dragvx(i),i,'dragx'
             write(6,6) istep,time,dragy(i),dragpy(i),dragvy(i),i,'dragy'
             write(6,6) istep,time,dragz(i),dragpz(i),dragvz(i),i,'dragz'
            endif
            if (iftout) then
             write(6,6) istep,time,torqx(i),torqpx(i),torqvx(i),i,'torqx'
             write(6,6) istep,time,torqy(i),torqpy(i),torqvy(i),i,'torqy'
             write(6,6) istep,time,torqz(i),torqpz(i),torqvz(i),i,'torqz'
            endif
           else
            if (ifdout) then
            endif
            if (iftout) then
            endif
           endif
         endif
     6   format(i8,1p4e19.11,2x,i5,a5)
       enddo
c
       return
       end
       subroutine comp_sij(sij,nij,u,v,w,ur,us,ut,vr,vs,vt,wr,ws,wt)
c                                       du_i       du_j
c     Compute the stress tensor S_ij := ----   +   ----
c                                       du_j       du_i
c
       include 'SIZE'
       include 'TOTAL'
c
       integer e
c
       real sij(lx1*ly1*lz1,nij,lelv)
       real u  (lx1*ly1*lz1,lelv)
       real v  (lx1*ly1*lz1,lelv)
       real w  (lx1*ly1*lz1,lelv)
       real ur (1) , us (1) , ut (1)
      $   , vr (1) , vs (1) , vt (1)
      $   , wr (1) , ws (1) , wt (1)
       real j ! Inverse Jacobian
       n    = nx1-1      ! Polynomial degree
       nxyz = nx1*ny1*nz1
       if (if3d) then     ! 3D CASE
        do e=1,nelv
         call local_grad3(vr,vs,vt,v,N,e,dxm1,dxtm1)
         call local_grad3(wr,ws,wt,w,N,e,dxm1,dxtm1)
         do i=1,nxyz
          j = jacmi(i,e)
          sij(i,1,e) = j*  ! du/dx + du/dx
      $   2*(ur(i)*rxm1(i,1,1,e)+us(i)*sxm1(i,1,1,e)+ut(i)*txm1(i,1,1,e))
          sij(i,2,e) = j*  ! dv/dy + dv/dy
      $   2*(vr(i)*rym1(i,1,1,e)+vs(i)*sym1(i,1,1,e)+vt(i)*tym1(i,1,1,e))
          sij(i,3,e) = j*  ! dw/dz + dw/dz
      $   2*(wr(i)*rzm1(i,1,1,e)+ws(i)*szm1(i,1,1,e)+wt(i)*tzm1(i,1,1,e))
          sij(i,4,e) = j*  ! du/dy + dv/dx
      $   (ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e)+ut(i)*tym1(i,1,1,e) +
      $    vr(i)*rxm1(i,1,1,e)+vs(i)*sxm1(i,1,1,e)+vt(i)*txm1(i,1,1,e) )
          sij(i,5,e) = j*  ! dv/dz + dw/dy
      $   (wr(i)*rym1(i,1,1,e)+ws(i)*sym1(i,1,1,e)+wt(i)*tym1(i,1,1,e) +
      $    vr(i)*rzm1(i,1,1,e)+vs(i)*szm1(i,1,1,e)+vt(i)*tzm1(i,1,1,e) )
          sij(i,6,e) = j*  ! du/dz + dw/dx
      $   (ur(i)*rzm1(i,1,1,e)+us(i)*szm1(i,1,1,e)+ut(i)*tzm1(i,1,1,e) +
      $    wr(i)*rxm1(i,1,1,e)+ws(i)*sxm1(i,1,1,e)+wt(i)*txm1(i,1,1,e) )
         enddo
        enddo
       elseif (ifaxis) then  ! AXISYMMETRIC CASE
c
c        Notation:                       ( 2  x  Acheson, p. 353)
c                     Cylindrical
c            Nek5k    Coordinates
c
c              x          z
c              y          r
c              z          theta
c
          do e=1,nelv
             call setaxdy ( ifrzer(e) )  ! change dytm1 if on-axis
             call local_grad2(vr,vs,v,N,e,dxm1,dytm1)
             call local_grad2(wr,ws,w,N,e,dxm1,dytm1)
             do i=1,nxyz
                j = jacmi(i,e)
                r = ym1(i,1,1,e)                              ! Cyl. Coord:
                sij(i,1,e) = j*  ! du/dx + du/dx              ! e_zz
      $           2*(ur(i)*rxm1(i,1,1,e)+us(i)*sxm1(i,1,1,e))
                sij(i,2,e) = j*  ! dv/dy + dv/dy              ! e_rr
      $           2*(vr(i)*rym1(i,1,1,e)+vs(i)*sym1(i,1,1,e))
                if (r.gt.0) then                              ! e_@@
                   sij(i,3,e) = v(i,e)/r  ! v / r
                else
                   sij(i,3,e) = j*  ! L'Hopital's rule: e_@@ = dv/dr
                endif
                sij(i,4,e) = j*  ! du/dy + dv/dx             ! e_zr
      $            ( ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e) +
      $              vr(i)*rxm1(i,1,1,e)+vs(i)*sxm1(i,1,1,e) )
                if (yyyr.gt.0) then                             ! e_r@
                   sij(i,5,e) = j*  ! dw/dy
      $              ( wr(i)*rym1(i,1,1,e)+ws(i)*sym1(i,1,1,e) )
      $              - w(i,e) / r
                else
                   sij(i,5,e) = 0
                endif
                sij(i,6,e) = j*  ! dw/dx                     ! e_ at z
      $            ( wr(i)*rxm1(i,1,1,e)+ws(i)*sxm1(i,1,1,e) )
             enddo
          enddo
       else              ! 2D CASE
          do e=1,nelv
             call local_grad2(ur,us,u,N,e,dxm1,dxtm1)
             call local_grad2(vr,vs,v,N,e,dxm1,dxtm1)
             do i=1,nxyz
                j = jacmi(i,e)
                sij(i,3,e) = j*  ! du/dy + dv/dx
      $           (ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e) +
             enddo
          enddo
       endif
       return
       end
       subroutine y_slice (ua,u,w1,w2)
c
c     Extract a y slice of quantity u() - assumes global tens.prod.
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
c
       real ua(nx1,nz1,nelx,nelz),u (nx1,ny1,nz1,nelv)
      $    ,w1(nx1,nz1,nelx,nelz),w2(nx1,nz1,nelx,nelz)
       integer e,eg,ex,ey,ez
       real dy2
c
       mxz = nelx*nelz*nx1*nz1
       call rzero(ua,mxz)
c
       do e=1,nelt
c
          eg = lglel(e)
          call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
          j = 1
          if (ey.eq.1) then
             do k=1,nz1
             do i=1,nx1
                ua(i,k,ex,ez) = u(i,j,k,e)
             enddo
             enddo
          endif
       enddo
       call gop(ua,w2,'+  ',mxz)
       return
       end
       subroutine z_slice_g (uz,u,w1,kz,ezi,nx,ny,nz,nlxy)
c
c     Extract a z slice of quantity u()
c
c     ASSUMES data is in a global tensor-product structure, nlxy x nelz,
c             as would be produced by n2to3 or genbox.
c
c     Arguments:
c
c     uz(nx1,ny1,nlxy):       extracted z-slice data
c     u (nx1,ny1,nz1,nelt):   input data
c     w1(nx1,ny1,nlxy):       work array
c     kz:                     z-plane within element ezi to be extracted
c     ezi:                    elemental z-slab to be extracted
c     nx,ny,nz:               dimensions for 3D spectral element input
c     nlxy:                   global number of elements in x-y plane.
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       real uz(nx,ny,nlxy),u (nx,ny,nz,nelv),w1(nx,ny,nlxy)
       integer e,eg,ex,ey,ez,ezi
       real dy2
       nxy = nx*ny
       mxy = nxy*nlxy
       call rzero(uz,mxy) ! zero out the entire plane
       do e=1,nelt
          eg = lglel(e)
          call get_exyz(ex,ey,ez,eg,nlxy,1,1)
          if (ez.eq.ezi)
      $      call copy(uz(1,1,ex),u(1,1,kz,e),nxy) ! u(zlice) --> uz()
       enddo
       call gop(uz,w1,'+  ',mxy) ! Collect partial contributions from all procs
       return
       end
       subroutine z_slice (ua,u,w1,w2)
c
c     Extract a z slice of quantity u() - assumes global tens.prod.
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
c
       real ua(nx1,ny1,nelx,nely),u (nx1,ny1,nz1,nelv)
      $    ,w1(nx1,ny1,nelx,nely),w2(nx1,ny1,nelx,nely)
       real dy2
c
       mxy = nelx*nely*nx1*ny1
       call rzero(ua,mxy)
c
       do e=1,nelt
c
          eg = lglel(e)
          k = 1
          if (ez.eq.1) then
             do j=1,ny1
             do i=1,nx1
                ua(i,j,ex,ey) = u(i,j,k,e)
             enddo
             enddo
          endif
       enddo
       call gop(ua,w2,'+  ',mxy)
       return
       end
       subroutine y_average(ua,u,w1,w2)
c
c     Compute the y average of quantity u() - assumes global tens.prod.
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
c
       real dy2
c
       call rzero(ua,mxz)
       call rzero(w1,mxz)
c
       do e=1,nelt
c
          eg = lglel(e)
c
          do k=1,nz1
          do i=1,nx1
c           dy2 = .5*( ym1(i,ny1,k,e) - ym1(i,1,k,e) )
             dy2 = 1.0  !  Assuming uniform in "y" direction
             do j=1,ny1
                ua(i,k,ex,ez) = ua(i,k,ex,ez)+dy2*wym1(j)*u(i,j,k,e)
                w1(i,k,ex,ez) = w1(i,k,ex,ez)+dy2*wym1(j) ! redundant but clear
             enddo
          enddo
          enddo
       enddo
c
       call gop(w1,w2,'+  ',mxz)
c
       do i=1,mxz
          ua(i,1,1,1) = ua(i,1,1,1) / w1(i,1,1,1)   ! Normalize
       enddo
c
       return
       end
       subroutine y_avg_buff(ux,uy,uz,c2,name,icount)
c
c
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
       real ux(1),uy(1),uz(1)
       character*2 c2,name
       parameter (lyavg = lx1*lz1*lelx*lelz)
       common /scravg/ u (lyavg)
      $              , v (lyavg)
      $              , w (lyavg)
      $              , w1(lyavg)
      $              , w2(lyavg)
       call y_average(u,ux,w1,w2)
       call y_average(v,uy,w1,w2)
       call y_average(w,uz,w1,w2)
       call buff_2d_out(u,v,w,nx1,nz1,nelx,nelz,c2,name,icount)
       return
       end
       subroutine z_avg_buff(ux,uy,uz,c2,name,icount)
c
c     Compute the z average of quantity u() - assumes global tens.prod.
c
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
c
       character*2 c2,name
c
       parameter (lyavg = lx1*ly1*lelx*lely)
      $              , v (lyavg)
      $              , w (lyavg)
      $              , w1(lyavg)
      $              , w2(lyavg)
c
       call z_average(u,ux,w1,w2)
       call z_average(v,uy,w1,w2)
       call z_average(w,uz,w1,w2)
       call buff_2d_out(u,v,w,nx1,ny1,nelx,nely,c2,name,icount)
       return
       end
       subroutine y_ins_buff(ux,uy,uz,c2,name,icount)
c
c
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
c
       character*2 c2,name
c
      $              , v (lyavg)
      $              , w (lyavg)
      $              , w1(lyavg)
      $              , w2(lyavg)
c
       call y_slice  (u,ux,w1,w2)
       call y_slice  (v,uy,w1,w2)
       call y_slice  (w,uz,w1,w2)
c
c
       return
       end
       subroutine z_ins_buff(ux,uy,uz,c2,name,icount)
c
c
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
c
       character*2 c2,name
c
      $              , v (lyavg)
      $              , w (lyavg)
      $              , w1(lyavg)
      $              , w2(lyavg)
c
       call z_slice  (u,ux,w1,w2)
       call z_slice  (v,uy,w1,w2)
       call z_slice  (w,uz,w1,w2)
c
c
       return
       end
       subroutine buff_2d_out(u,v,w,nx,ny,nex,ney,c2,name,ifld)
c
       include 'SIZE'
       include 'TOTAL'
       real u(1),v(1),w(1)
       character*2 c2,name
       character*4  bname
       save         bname
       parameter (lyzm = lelx*max(lely,lelz))
       common /scrav2/ ub(lx1,lz1,lyzm),vb(lx1,lz1,lyzm),wb(lx1,lz1,lyzm)
       integer ibfld,icalld,nxf,nyf,nexf,neyf
       save    ibfld,icalld,nxf,nyf,nexf,neyf
       data    ibfld,icalld,nxf,nyf,nexf,neyf  / 6*0 /
c     npido = 64             !  64 files buffered
       npido = 128            !  64 files buffered
       npido =  min(npido,np) !  P  files buffered
       mpido = np/npido     ! stride between processors (e.g., 128/64 = 2)
       jcalld = mod(icalld,npido)       ! call # 0,1,...,63,0,1,...
       if (mod(nid,mpido) .eq. 0) then  ! this is a buffering/writing proc
          jid = nid/mpido
          if (jid.eq.jcalld) then       ! save this buffer on this proc
c           write(6,1) nid,jid,istep,icalld,jcalld,c2,name,nex,ney,ifld
c   1       format(5i7,' buffering: ',2a2,3i7)
             write(bname,4) c2,name
     4       format(2a2)
             n = nx*ny*nex*ney
             ibfld = ifld
             call copy(ub,u,n)
             call copy(vb,v,n)
             call copy(wb,w,n)
             nxf  = nx
             nyf  = ny
             nexf = nex
             neyf = ney
          endif
          if (jcalld .eq. npido-1) call  ! output buffer
      $  outfld2d_p(ub,vb,wb,nxf,nyf,nexf,neyf,bname,ibfld,jid,npido,ir)
       endif
       call err_chk(ir,'Error with byte_write, buff_2d_out $')
       icalld = icalld+1
       return
       end
       subroutine y2d(u,v,w,p,c1,icount)
c
c
       include 'SIZE'
       include 'TOTAL'
       real u(1),v(1),w(1),p(1)
       character*1 c1,c2(2)
       common /scrns/ ur(lx1*ly1*lz1*lelv)
      $             , ut(lx1*ly1*lz1*lelv)
      $             , wr(lx1*ly1*lz1*lelv)
      $             , wt(lx1*ly1*lz1*lelv)
      $             , wp(lx1*ly1*lz1*lelv)
c
c     Convert velocities to poloidal-toroidal
c
       do i=1,n
          rr = xm1(i,1,1,1)*xm1(i,1,1,1)+ym1(i,1,1,1)*ym1(i,1,1,1)
          rr = sqrt(rr)
          ct = xm1(i,1,1,1)/rr
          st = ym1(i,1,1,1)/rr
          ur(i) = ct*u(i)+st*v(i)
          ut(i) = ct*v(i)-st*u(i)
          wr(i) = ur(i)**2
          wt(i) = ut(i)**2
          wp(i) = w (i)**2
       enddo
       c2(1) = c1
       c2(2) = 'y'
       call y_avg_buff(ur,w ,ut,c2,'ub',icount)
       call y_avg_buff(wr,wp,wt,c2,'u2',icount)
       do i=1,n
          wr(i) = ur(i)*ut(i)
          wt(i) = ut(i)*w (i)
          wp(i) = w (i)*ur(i)
       enddo
       call y_avg_buff(wr,wt,wp,c2,'uv',icount)
       call y_ins_buff(ur,w ,ut,c2,'ui',icount)
       return
       end
       subroutine z2d(u,v,w,p,c1,icount)
c
c
       include 'SIZE'
       include 'TOTAL'
c
c
c
       do i=1,n
          wr(i) = u (i)**2
          wt(i) = v (i)**2
          wp(i) = w (i)**2
       enddo
       c2(1) = c1
       c2(2) = 'z'
       call z_avg_buff(u ,v ,w ,c2,'ub',icount)
       call z_avg_buff(wr,wt,wp,c2,'u2',icount)
       do i=1,n
          wr(i) = u(i)*v(i)
          wt(i) = v(i)*w(i)
          wp(i) = w(i)*u(i)
       enddo
       call z_avg_buff(wr,wt,wp,c2,'uv',icount)
       call z_ins_buff(u ,v ,w ,c2,'ui',icount)
       return
       end
       subroutine anal_2d
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
       integer icount
       save    icount
       if (nelx.gt.lelx .or.
      $    nely.gt.lely .or.
      $    nelz.gt.lelz ) then
          if (nid.eq.0) write(6,1) nelx,nely,nelz,lelx,lely,lelz
     1    format('anal_2d fail:',6i6)
          return
       endif
       if (istep.eq.0) then   ! dump four times, just to keep phase
          icount = 0
          call z2d(xm1,ym1,zm1,pr,'u',icount)
          if (ifmhd) call z2d(xm1,ym1,zm1,pm,'b',icount)
          call y2d(xm1,ym1,zm1,pr,'u',icount)
          if (ifmhd) call y2d(xm1,ym1,zm1,pm,'b',icount)
       endif
       icount = icount + 1
       call z2d(vx,vy,vz,pr,'u',icount)
       if (ifmhd) call z2d(bx,by,bz,pm,'b',icount)
       call y2d(vx,vy,vz,pr,'u',icount)
       if (ifmhd) call y2d(bx,by,bz,pm,'b',icount)
       return
       end
       subroutine chkit(u,name4,n)
       include 'SIZE'
       include 'TOTAL'
       character*4 name4
       real u(1)
       integer icalld
       save    icalld
       data    icalld /0/
       icalld = icalld + 1
       u2   = vlsc2(u,u,n)
       umin = vlmin(u,n)
       umax = vlmax(u,n)
       ulst = u(n)
       if (nid.eq.0)
      $write(6,1) nid,icalld,istep,n,umin,umax,ulst,name4,' chkit',nid
     1 format(4i7,1p3e12.4,a4,a6,i1)
       return
       end
       subroutine outmesh
       include 'SIZE'
       include 'TOTAL'
       integer e,eg
       common /cmesh/ xt(2**ldim,ldim)
       len = wdsize*ndim*(2**ndim)
       if (nid.eq.0) open(unit=29,file='rea.new')
       do eg=1,nelgt
          mtype = eg
          call nekgsync()          !  belt
          jnid = gllnid(eg)
          e    = gllel (eg)
          if (jnid.eq.0 .and. nid.eq.0) then
             call get_el(xt,xm1(1,1,1,e),ym1(1,1,1,e),zm1(1,1,1,e))
             call out_el(xt,eg)
          elseif (nid.eq.0) then
             call crecv(mtype,xt,len)
             call out_el(xt,eg)
          elseif (jnid.eq.nid) then
             call csend(mtype,xt,len,0,0)
          endif
          call nekgsync()          !  suspenders
       enddo
       if (nid.eq.0) close(29)
       call nekgsync()
       call exitt
       return
       end
       subroutine out_el(xt,e)
       include 'SIZE'
       include 'TOTAL'
       real xt(2**ldim,ldim)
       integer e
       integer ed(8)
       save    ed
       data    ed  / 1,2,4,3 , 5,6,8,7 /
       write(29,1) e
       write(29,2) ((xt(ed(k),j),k=1,4),j=1,ndim)
       write(29,2) ((xt(ed(k),j),k=5,8),j=1,ndim)
     1 format(12x,'ELEMENT',i6,' [    1 ]    GROUP     0')
     2 format(1p4e18.10)
       return
       end
       subroutine get_el(xt,x,y,z)
       include 'SIZE'
       include 'TOTAL'
       real x(nx1,ny1,nz1),y(nx1,ny1,nz1),z(nx1,ny1,nz1)
       l = 0
       do k=1,nz1,nz1-1
       do j=1,ny1,ny1-1
       do i=1,nx1,nx1-1
          l = l+1
          xt(l,1) = x(i,j,k)
          xt(l,2) = y(i,j,k)
          xt(l,3) = z(i,j,k)
       enddo
       enddo
       enddo
       return
       end
       subroutine shear_calc_max(strsmx,scale,x0,ifdout,iftout)
c
c     Compute maximum shear stress on objects
c
c
c
       INCLUDE 'SIZE'
       INCLUDE 'TOTAL'
       real    strsmx(maxobj),x0(3),w1(0:maxobj)
      $                , scale_vf(3)
       endif
c
c    Compute sij
c
       nij = 3
c
c
c
c
c
c
c
       call rzero(strsmx,maxobj)
c
c
       nobj = 0
       do ii=1,nhis
           iobj   = lochis(1,ii)
c
             ifield = 1
c
c           Compute max stress for this object
c
             strsmx(ii) = 0.
             do mem=1,memtot
                   ie = gllel(ieg)
                   call get_strsmax
      $                    (strsmxl,xm0,ym0,zm0,sij,pm1,vdiff,ifc,ie)
                   call cmult(strsmxl,scale,1)
                   strsmx(ii)=max(strsmx(ii),strsmxl)
                endif
             enddo
           endif
         endif
       enddo
c
c     Max contributions over all processors
c
       call gop(strsmx,w1,'M  ',maxobj)
       return
       end
       subroutine get_strsmax(strsmax,xm0,ym0,zm0,sij,pm1,visc,f,e)
c
       INCLUDE 'SIZE'
       INCLUDE 'GEOM'
       INCLUDE 'INPUT'
       INCLUDE 'TOPOL'
       INCLUDE 'TSTEP'
c
       real dgtq(3,4)
       integer f,e,pf
       real    n1,n2,n3
       js1    = skpdat(1,pf)
       jf1    = skpdat(2,pf)
       js2    = skpdat(4,pf)
       jf2    = skpdat(5,pf)
          i       = 0
          strsmax = 0
             i = i+1
             n1 = unx(i,1,f,e)
             n2 = uny(i,1,f,e)
             n3 = unz(i,1,f,e)
c
             v  = visc(j1,j2,1,e)
c
c
             stress1 = -v*(s11*n1 + s12*n2 + s13*n3) ! viscous drag
             stress2 = -v*(s21*n1 + s22*n2 + s23*n3)
             stress3 = -v*(s31*n1 + s32*n2 + s33*n3)
             strsnrm = stress1*stress1+stress2*stress2+stress3*stress3
             strsmax = max(strsmax,strsnrm)
          enddo
          enddo
       else ! 2D
          i       = 0
          strsmax = 0
             i = i+1
             v  = visc(j1,j2,1,e)
             stress1 = -v*(s11*n1 + s12*n2) ! viscous drag
             stress2 = -v*(s21*n1 + s22*n2)
        enddo
        enddo
       endif
       if (strsmax.gt.0) strsmax = sqrt(strsmax)
       return
       end
       subroutine fix_geom ! fix up geometry irregularities
       include 'SIZE'
       include 'TOTAL'
       parameter (lt = lx1*ly1*lz1)
       common /scrns/ xb(lt,lelt),yb(lt,lelt),zb(lt,lelt)
       common /scruz/ tmsk(lt,lelt),tmlt(lt,lelt),w1(lt),w2(lt)
       integer e,f
       character*3 cb
       n      = nx1*ny1*nz1*nelt
       nxyz   = nx1*ny1*nz1
       nfaces = 2*ndim
       ifield = 1                   ! velocity field
       if (ifheat) ifield = 2       ! temperature field
       call rone  (tmlt,n)
       call dssum (tmlt,nx1,ny1,nz1)  ! denominator
       call rone  (tmsk,n)
       do e=1,nelfld(ifield)      ! fill mask where bc is periodic
       do f=1,nfaces              ! so we don't translate periodic bcs (z only)
          cb =cbc(f,e,ifield)
          if (cb.eq.'P  ') call facev (tmsk,e,f,0.0,nx1,ny1,nz1)
       enddo
       enddo
       do kpass = 1,ndim+1   ! This doesn't work for 2D, yet.
                             ! Extra pass is just to test convergence
c        call opcopy (xb,yb,zb,xm1,ym1,zm1) ! Must use WHOLE field,
c        call opdssum(xb,yb,zb)             ! not just fluid domain.
          call copy   (xb,xm1,n)
          call copy   (yb,ym1,n)
          call copy   (zb,zm1,n)
          call dssum  (xb,nx1,ny1,nz1)
          call dssum  (yb,nx1,ny1,nz1)
          call dssum  (zb,nx1,ny1,nz1)
          xm = 0.
          ym = 0.
          zm = 0.
             do i=1,nxyz                       ! compute averages of geometry
                s     = 1./tmlt(i,e)
                xb(i,e) = s*xb(i,e)
                yb(i,e) = s*yb(i,e)
                zb(i,e) = s*zb(i,e)
                xb(i,e) = xb(i,e) - xm1(i,1,1,e)   ! local displacements
                yb(i,e) = yb(i,e) - ym1(i,1,1,e)
                zb(i,e) = zb(i,e) - zm1(i,1,1,e)
                xb(i,e) = xb(i,e)*tmsk(i,e)
                yb(i,e) = yb(i,e)*tmsk(i,e)
                zb(i,e) = zb(i,e)*tmsk(i,e)
                xm = max(xm,abs(xb(i,e)))
                ym = max(ym,abs(yb(i,e)))
                zm = max(zm,abs(zb(i,e)))
             enddo
             if (kpass.le.ndim) then
                call gh_face_extend(xb(1,e),zgm1,nx1,kpass,w1,w2)
                call gh_face_extend(yb(1,e),zgm1,nx1,kpass,w1,w2)
                call gh_face_extend(zb(1,e),zgm1,nx1,kpass,w1,w2)
             endif
          enddo
             call add2(xm1,xb,n)
             call add2(ym1,yb,n)
             call add2(zm1,zb,n)
          endif
          xx = glamax(xb,n)
          yx = glamax(yb,n)
          zx = glamax(zb,n)
          xm = glmax(xm,1)
          ym = glmax(ym,1)
          zm = glmax(zm,1)
          if (nid.eq.0) write(6,1) xm,ym,zm,xx,yx,zx,kpass
     1    format(1p6e12.4,' xyz repair',i2)
       enddo
       param(59) = 1.       ! ifdef = .true.
       call geom_reset(1)   ! reset metrics, etc.
       return
       end
       subroutine gh_face_extend(x,zg,n,gh_type,e,v)
       include 'SIZE'
       real x(1),zg(1),e(1),v(1)
       integer gh_type
       if (ndim.eq.2) then
          call gh_face_extend_2d(x,zg,n,gh_type,e,v)
       else
          call gh_face_extend_3d(x,zg,n,gh_type,e,v)
       endif
       return
       end
       subroutine gh_face_extend_2d(x,zg,n,gh_type,e,v)
c
c     Extend 2D faces into interior via gordon hall
c
c     gh_type:  1 - vertex only
c               2 - vertex and faces
c
c
       real x(n,n)
       real zg(n)
       real e(n,n)
       real v(n,n)
       integer gh_type
c
c     Build vertex interpolant
c
       ntot=n*n
       call rzero(v,ntot)
       do jj=1,n,n-1
       do ii=1,n,n-1
          do j=1,n
          do i=1,n
             si     = 0.5*((n-ii)*(1-zg(i))+(ii-1)*(1+zg(i)))/(n-1)
             sj     = 0.5*((n-jj)*(1-zg(j))+(jj-1)*(1+zg(j)))/(n-1)
             v(i,j) = v(i,j) + si*sj*x(ii,jj)
          enddo
          enddo
       enddo
       enddo
       if (gh_type.eq.1) then
          call copy(x,v,ntot)
          return
       endif
c     Extend 4 edges
       call rzero(e,ntot)
c
c     x-edges
c
       do jj=1,n,n-1
          do j=1,n
          do i=1,n
             hj     = 0.5*((n-jj)*(1-zg(j))+(jj-1)*(1+zg(j)))/(n-1)
             e(i,j) = e(i,j) + hj*(x(i,jj)-v(i,jj))
          enddo
          enddo
       enddo
c
c     y-edges
c
       do ii=1,n,n-1
          do j=1,n
          do i=1,n
             hi     = 0.5*((n-ii)*(1-zg(i))+(ii-1)*(1+zg(i)))/(n-1)
             e(i,j) = e(i,j) + hi*(x(ii,j)-v(ii,j))
          enddo
          enddo
       enddo
       call add3(x,e,v,ntot)
       return
       end
       subroutine gh_face_extend_3d(x,zg,n,gh_type,e,v)
c
c     Extend faces into interior via gordon hall
c
c               2 - vertex and edges
c               3 - vertex, edges, and faces
c
c
       real x(n,n,n)
       real zg(n)
       real e(n,n,n)
       real v(n,n,n)
       integer gh_type
c
c
       ntot=n*n*n
       call rzero(v,ntot)
       do kk=1,n,n-1
       do jj=1,n,n-1
       do ii=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             sk       = 0.5*((n-kk)*(1-zg(k))+(kk-1)*(1+zg(k)))/(n-1)
             v(i,j,k) = v(i,j,k) + si*sj*sk*x(ii,jj,kk)
          enddo
          enddo
          enddo
       enddo
       enddo
       enddo
          call copy(x,v,ntot)
          return
       endif
c
c
c     Extend 12 edges
       call rzero(e,ntot)
c
c     x-edges
c
       do kk=1,n,n-1
       do jj=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             hk       = 0.5*((n-kk)*(1-zg(k))+(kk-1)*(1+zg(k)))/(n-1)
             e(i,j,k) = e(i,j,k) + hj*hk*(x(i,jj,kk)-v(i,jj,kk))
          enddo
          enddo
          enddo
       enddo
       enddo
c
c     y-edges
c
       do kk=1,n,n-1
       do ii=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             e(i,j,k) = e(i,j,k) + hi*hk*(x(ii,j,kk)-v(ii,j,kk))
          enddo
          enddo
          enddo
       enddo
       enddo
c
c     z-edges
c
       do jj=1,n,n-1
       do ii=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             e(i,j,k) = e(i,j,k) + hi*hj*(x(ii,jj,k)-v(ii,jj,k))
          enddo
          enddo
          enddo
       enddo
       enddo
c
       call add2(e,v,ntot)
c
       if (gh_type.eq.2) then
          call copy(x,e,ntot)
          return
       endif
c
c     Extend faces
c
       call rzero(v,ntot)
c
c     x-edges
c
       do ii=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             v(i,j,k) = v(i,j,k) + hi*(x(ii,j,k)-e(ii,j,k))
          enddo
          enddo
          enddo
       enddo
c
c     y-edges
c
       do jj=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             v(i,j,k) = v(i,j,k) + hj*(x(i,jj,k)-e(i,jj,k))
          enddo
          enddo
          enddo
       enddo
c
c     z-edges
c
       do kk=1,n,n-1
          do k=1,n
          do j=1,n
          do i=1,n
             v(i,j,k) = v(i,j,k) + hk*(x(i,j,kk)-e(i,j,kk))
          enddo
          enddo
          enddo
       enddo
c
       call add2(v,e,ntot)
       call copy(x,v,ntot)
       return
       end
       function ran1(idum)
c
       integer idum,ia,im,iq,ir,ntab,ndiv
       real    ran1,am,eps,rnmx
c
       parameter (ia=16807,im=2147483647,am=1./im,iq=127773,ir=2836)
       parameter (ntab=32,ndiv=1+(im-1)/ntab,eps=1.2e-7,rnmx=1.-eps)
c
c     Numerical Rec. in Fortran, 2nd eD.  P. 271
c
       integer j,k
       integer iv(ntab),iy
       save    iv,iy
       data    iv,iy /ntab*0,0/
c
       if (idum.le.0.or.iy.eq.0) then
          idum=max(-idum,1)
          do j=ntab+8,1,-1
             k    = idum/iq
             idum = ia*(idum-k*iq)-ir*k
             if(idum.lt.0) idum = idum+im
             if (j.le.ntab) iv(j) = idum
          enddo
          iy = iv(1)
       endif
       k    = idum/iq
       j     = 1+iy/ndiv
       iy    = iv(j)
       iv(j) = idum
       ran1  = min(am*iy,rnmx)
c     ran1  = cos(ran1*1.e8)
       return
       end
       subroutine rand_fld_h1(x)
       include 'SIZE'
       real x(1)
       n=nx1*ny1*nz1*nelt
       id = n
       do i=1,n
          x(i) = ran1(id)
       enddo
       call dsavg(x)
       return
       end
       subroutine rescale_x (x,x0,x1)
       include 'SIZE'
       real x(1)
       xmin = glmin(x,n)
       xmax = glmax(x,n)
       if (xmax.le.xmin) return
       scale = (x1-x0)/(xmax-xmin)
       do i=1,n
          x(i) = x0 + scale*(x(i)-xmin)
       enddo
       return
       end
       subroutine z_distribute(u)
c
c     Compute the z average of quantity u() and redistribute
c
c     Assumes you have nelx*nely elements, in the same order,
c     within each z plane
c
c
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'
       character*2 c2,name
       common /scravg/ ua(lyavg)
      $              , w1(lyavg)
      $              , w2(lyavg)
       call z_average          (ua,u,w1,w2)
       call z_average_transpose(u,ua) ! distribute ua to each z-plane
       return
       end
       subroutine z_average(ua,u,w1,w2)
c
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
       real dy2
       nelxy = nelx*nely
       if (nelxy.gt.lelx*lely) call exitti
      $  ('ABORT IN z_average. Increase lelx*lely in SIZE:$',nelxy)
       call rzero(ua,mxy)
       call rzero(w1,mxy)
       do e=1,nelt
          eg = lglel(e)
          do j=1,ny1
          do i=1,nx1
             dz2 = 1.0  !  Assuming uniform in "z" direction
             do k=1,nz1
                ua(i,j,ex,ey) = ua(i,j,ex,ey)+dz2*wzm1(k)*u(i,j,k,e)
                w1(i,j,ex,ey) = w1(i,j,ex,ey)+dz2*wzm1(k) ! redundant but clear
             enddo
          enddo
          enddo
       enddo
       call gop(w1,w2,'+  ',mxy)
       do i=1,mxy
       enddo
       return
       end
       subroutine z_average_transpose(u,ua) ! distribute ua to each z-plane
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
       real u(nx1,ny1,nz1,nelv),ua(nx1,ny1,nelx,nely)
       do e=1,nelt
          eg = lglel(e)
          do j=1,ny1
          do i=1,nx1
             do k=1,nz1
                u(i,j,k,e) = ua(i,j,ex,ey)
             enddo
          enddo
          enddo
       enddo
       return
       end
       subroutine no_z_profile(u)
c     Subtract the z_profile from u for a tensor-product array of elements
c     Assumes you have nelx*nely*nelz elements, in the same order,
c     and that lelx,lely,lelz are defined to be >= nelx,nely,nelz
       include 'SIZE'
       include 'TOTAL'
       include 'ZPER'         ! nelx,nely,nelz
       real u(1)
       parameter (lyavg = ly1*lely)
      $              , w1(lyavg)
      $              , w2(lyavg)
       common /scrmg/  ub(lx1*ly1*lz1*lelt)
       call z_profile          (ua,u,w1,w2)
       call z_profile_transpose(ub,ua) ! distribute ua to each z-plane
       call sub2(u,ub,n)
       return
       end
       subroutine z_profile(ua,u,w1,w2)
c
c     Compute the z profile of quantity u() - assumes global tens.prod.
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
       real ua(lz1,lelz),u (nx1,ny1,nz1,nelv)
      $    ,w1(lz1,lelz),w2(lz1,lelz)
       mz = nz1*nelz
       call rzero(ua,mz)
       call rzero(w1,mz)
       do e=1,nelt
          eg = lglel(e)
          do k=1,nz1
          do i=1,nx1*ny1
             ua(k,ez) = ua(k,ez) + area(i,1,5,e)*u(i,1,k,e)
             w1(k,ez) = w1(k,ez) + area(i,1,5,e)
          enddo
          enddo
       enddo
       call gop(ua,w2,'+  ',mz)
       call gop(w1,w2,'+  ',mz)
       do i=1,mz
       enddo
       return
       end
       subroutine z_profile_transpose(u,ua) ! distribute ua to each z-plane
       include 'SIZE'
       include 'PARALLEL'
       include 'ZPER'
       real u(nx1,ny1,nz1,nelv),ua(lz1,lelz)
       do e=1,nelt
          eg = lglel(e)
          do k=1,nz1
          do i=1,nx1*ny1
             u(i,1,k,e) = ua(k,ez)
          enddo
          enddo
       enddo
       return
       end
       subroutine no_y_profile(u)
c     Subtract the y_profile from u for a tensor-product array of elements
       include 'SIZE'
       include 'TOTAL'
       real u(1)
      $              , w1(lyavg)
      $              , w2(lyavg)
       call y_profile          (ua,u,w1,w2)
       call y_profile_transpose(ub,ua) ! distribute ua to each y-plane
       call sub2(u,ub,n)
       return
       end
       subroutine y_profile(ua,u,w1,w2)
c
c
       include 'SIZE'
       include 'GEOM'
       include 'PARALLEL'
       include 'WZ'
       include 'ZPER'
       my = ny1*nely
       call rzero(ua,my)
       call rzero(w1,my)
       do e=1,nelt
          eg = lglel(e)
          do k=1,nz1
          do j=1,ny1
          do i=1,nx1
             ua(j,ey) = ua(j,ey) + area(i,k,1,e)*u(i,j,k,e)
             w1(j,ey) = w1(j,ey) + area(i,k,1,e)
          enddo
          enddo
          enddo
       enddo
       call gop(ua,w2,'+  ',my)
       call gop(w1,w2,'+  ',my)
       do i=1,my
       enddo
       return
       end
       subroutine y_profile_transpose(u,ua) ! distribute ua to each z-plane
       include 'SIZE'
       include 'PARALLEL'
       include 'ZPER'
       do e=1,nelt
          eg = lglel(e)
          do k=1,nz1
          do j=1,ny1
          do i=1,nx1
             u(i,j,k,e) = ua(j,ey)
          enddo
          enddo
          enddo
       enddo
       return
       end
       subroutine build_filter(f,diag,nx)
       include 'SIZE'
       real f(nx,nx),diag(nx),zpts(nx)
       parameter (lm=4*lx1) ! Totally arbitrary
       common /cfilt1/ phi,pht,ft,rmult,Lj,gpts,indr,indc,ipiv
       real      phi(lm2),pht(lm2),ft(lm2),rmult(lm),Lj(lm),gpts(lm)
       integer nxl
       save    nxl
       data    nxl / -9 /
       if (nx.gt.lm) call exitti('ABORT in build_filter:$',nx)
       if (nx.ne.nxl) then
         nxl = nx
         call zwgll (gpts,f,nx)  ! Get nx GLL points
         kj = 0
         n  = nx-1
         do j=1,nx
          z = gpts(j)
          kj = kj+1
          pht(kj) = Lj(1)
          kj = kj+1
          pht(kj) = Lj(2)
          do k=3,nx
             kj = kj+1
          enddo
         enddo
       endif ! End of save section
       ij=0
       do j=1,nx
       do i=1,nx
          ij = ij+1
          ft(ij) = diag(i)*pht(ij)
       enddo
       enddo
                                           !          -1
       call mxm  (phi,nx,ft,nx,f,nx)       !     V D V
       return
       end
       subroutine g_filter(u,diag,ifld)
c
c     Generalized filter: F(u) with F = J^T D J, where D=diag(diag)
c
       include 'SIZE'
       include 'TOTAL'
       real u(1),diag(1)
       parameter (lxx=lx1*lx1,lxyz=lx1*ly1*lz1)
       common /ctmp0/ f(lxx),wk1(lxyz),wk2(lxyz),wk3(lxyz)
       ifldt = ifield
       ifield = ifld
       call build_filter(f,diag,nx1)
       call filterq(u,f,nx1,nz1,wk1,wk2,wk3,if3d,umax)
       ifield = ifldt
       return
       end
       subroutine cut_off_filter(u,mx,ifld) ! mx=max saved mode
c
c
       include 'SIZE'
       include 'TOTAL'
       real u(1)
       common /ctmp0/ f(lxx),wk1(lxyz),wk2(lxyz),wk3(lxyz),diag(lx1)
       ifldt = ifield
       ifield = ifld
       call rone(diag,nx1)
       do i=mx+1,nx1
          diag(i)=0.
       enddo
       ifield = ifldt
       return
       end
       subroutine filter_d2(v,nx,nz,wgt,ifd4)
       include 'SIZE'
       include 'TOTAL'
       parameter (lt=lx1*ly1*lz1)
       real v(lt,nelt)
       logical ifd4
       common /ctmp1/ w(lt,lelt),ur(lt),us(lt),ut(lt),w1(2*lt)
       integer e
       nn  = nx-1
       bmax = glamax(v,n)
       if (if3d) then
         do e=1,nel
           call local_grad3(ur,us,ut,v(1,e),nn,1,dxm1,dxtm1)
           do i=1,lt
             ur(i) = ur(i)*w3m1(i,1,1)
             us(i) = us(i)*w3m1(i,1,1)
             ut(i) = ut(i)*w3m1(i,1,1)
           enddo
           call local_grad3_t(w(1,e),ur,us,ut,nn,1,dxm1,dxtm1,w1)
         enddo
         call dsavg(w)  !NOTE STILL NEED BC TREATMENT !
         if (ifd4) then
            wght = 20./(nx1**4)
            do e=1,nel
              do i=1,lt
                w(i,e)  = wght*w(i,e)/w3m1(i,1,1)
              enddo
              call local_grad3(ur,us,ut,w(1,e),nn,1,dxm1,dxtm1)
              do i=1,lt
              enddo
            enddo
         endif
         wght = wgt/(nx1**4)
         do e=1,nel
           do i=1,lt
             v(i,e)  = v(i,e) - wght*w(i,e)/w3m1(i,1,1)
           enddo
         enddo
       else  ! 2D
         do e=1,nel
           call local_grad2(ur,us,v(1,e),nn,1,dxm1,dxtm1)
           do i=1,lt
           enddo
           call local_grad2_t(w(1,e),ur,us,nn,1,dxm1,dxtm1,w1)
         enddo
         if (ifd4) then
            wght = 200./(nx1**4)
            do e=1,nel
              do i=1,lt
              enddo
              call local_grad2(ur,us,w(1,e),nn,1,dxm1,dxtm1)
              do i=1,lt
              enddo
            enddo
         endif
         wght = wgt/(nx1**4)
         do e=1,nel
           do i=1,lt
           enddo
         enddo
       endif
       vmax = glamax(v,n)
       if (nid.eq.0) write(6,1) istep,time,vmax,bmax,' filter max'
     1 format(i9,1p3e12.4,a11)
       return
       end
       function dist3d(a,b,c,x,y,z)
       d = (a-x)**2 + (b-y)**2 + (c-z)**2
       dist3d = 0.
       if (d.gt.0) dist3d = sqrt(d)
       return
       end
       function dist2d(a,b,x,y)
       dist2d = 0.
       if (d.gt.0) dist2d = sqrt(d)
       return
       end
       subroutine domain_size(xmin,xmax,ymin,ymax,zmin,zmax)
       include 'SIZE'
       include 'TOTAL'
       xmin = glmin(xm1,n)
       xmax = glmax(xm1,n)
       ymin = glmin(ym1,n)
       ymax = glmax(ym1,n)
       if (if3d) then
          zmin = glmin(zm1,n)
          zmax = glmax(zm1,n)
       else
          zmin = 0.
          zmax = 0.
       endif
       return
       end
       subroutine cheap_dist(d,ifld,b)
c     Finds a pseudo-distance function.
c     INPUT:  ifld - field type for which distance function is to be found.
c             ifld = 1 for velocity
c             ifld = 2 for temperature, etc.
c     OUTPUT: d = "path" distance to nearest wall
c     This approach has a significant advantage that it works for
c     periodict boundary conditions, whereas most other approaches
c     will not.
       include 'SIZE'
       include 'GEOM'       ! Coordinates
       include 'INPUT'      ! cbc()
       include 'TSTEP'      ! nelfld
       include 'PARALLEL'   ! gather-scatter handle for field "ifld"
       real d(lx1,ly1,lz1,lelt)
       character*3 b  ! Boundary condition of interest
       integer e,eg,f
       nel = nelfld(ifld)
       n = nx1*ny1*nz1*nel
       call domain_size(xmin,xmax,ymin,ymax,zmin,zmax)
       xmn = min(xmin,ymin)
       xmx = max(xmax,ymax)
       if (if3d) xmn = min(xmn ,zmin)
       if (if3d) xmx = max(xmx ,zmax)
       big = 10*(xmx-xmn)
       call cfill(d,big,n)
       nface = 2*ndim
       do e=1,nel     ! Set d=0 on walls
       do f=1,nface
          if (cbc(f,e,ifld).eq.b) call facev(d,e,f,0.,nx1,ny1,nz1)
       enddo
       enddo
       do ipass=1,10000
          dmax    = 0
          nchange = 0
          do e=1,nel
            do k=1,nz1
            do j=1,ny1
            do i=1,nx1
              i0=max(  1,i-1)
              j0=max(  1,j-1)
              k0=max(  1,k-1)
              i1=min(nx1,i+1)
              j1=min(ny1,j+1)
              k1=min(nz1,k+1)
              do kk=k0,k1
              do jj=j0,j1
              do ii=i0,i1
               if (if3d) then
                dtmp = d(ii,jj,kk,e) + dist3d(
      $           xm1(ii,jj,kk,e),ym1(ii,jj,kk,e),zm1(ii,jj,kk,e)
      $          ,xm1(i ,j ,k ,e),ym1(i ,j ,k ,e),zm1(i ,j ,k ,e))
               else
                dtmp = d(ii,jj,kk,e) + dist2d(
      $          ,xm1(i ,j ,k ,e),ym1(i ,j ,k ,e))
               endif
               if (dtmp.lt.d(i,j,k,e)) then
                 d(i,j,k,e) = dtmp
                 nchange = nchange+1
                 dmax = max(dmax,d(i,j,k,e))
               endif
              enddo
              enddo
              enddo
            enddo
            enddo
            enddo
          enddo
          call gs_op(gsh_fld(ifld),d,1,3,0) ! min over all elements
          nchange = iglsum(nchange,1)
          dmax = glmax(dmax,1)
          if (nid.eq.0) write(6,1) ipass,nchange,dmax
     1    format(i9,i12,1pe12.4,' max wall distance 1')
          if (nchange.eq.0) goto 1000
       enddo
  1000 return
       end
       subroutine distf(d,ifld,b,dmin,emin,xn,yn,zn)
c     Generate a distance function to boundary with bc "b".
c     This approach does not yet work with periodic boundary conditions.
c     OUTPUT: d = distance to nearest boundary with boundary condition "b"
c     Work arrays:  dmin,emin,xn,yn,zn
       include 'SIZE'
       character*3 b
       real dmin(lx1,ly1,lz1,lelt),emin(lx1,ly1,lz1,lelt)
       real xn(lx1,ly1,lz1,lelt),yn(lx1,ly1,lz1,lelt)
       real zn(lx1,ly1,lz1,lelt)
       integer e,eg,f
       nel = nelfld(ifld)
       n = nx1*ny1*nz1*nel
       big = 10*(xmx-xmn)
       call cfill (d,big,n)
       call opcopy(xn,yn,zn,xm1,ym1,zm1)
       nface = 2*ndim
       do f=1,nface
          if (cbc(f,e,1).eq.b) call facev(d,e,f,0.,nx1,ny1,nz1)
       enddo
       enddo
       nxyz = nx1*ny1*nz1
       do ipass=1,10000
          dmax    = 0
          nchange = 0
          do e=1,nel
             do k=1,nz1
             do j=1,ny1
             do i=1,nx1
               i0=max(  1,i-1)
               j0=max(  1,j-1)
               k0=max(  1,k-1)
               i1=min(nx1,i+1)
               j1=min(ny1,j+1)
               k1=min(nz1,k+1)
               do kk=k0,k1
               do jj=j0,j1
               do ii=i0,i1
                dself  = d(i,j,k,e)
                dneigh = d(ii,jj,kk,e)
                if (dneigh.lt.dself) then  ! check neighbor's nearest point
                   d2 = (xm1(i,j,k,e)-xn(ii,jj,kk,e))**2
      $               + (ym1(i,j,k,e)-yn(ii,jj,kk,e))**2
                   if (if3d) d2 = d2 + (zm1(i,j,k,e)-zn(ii,jj,kk,e))**2
                   if (d2.gt.0) d2 = sqrt(d2)
                   if (d2.lt.dself) then
                     nchange = nchange+1
                     d (i,j,k,e) = d2
                     xn(i,j,k,e) = xn(ii,jj,kk,e)
                     yn(i,j,k,e) = yn(ii,jj,kk,e)
                     zn(i,j,k,e) = zn(ii,jj,kk,e)
                   endif
                endif
               enddo
               enddo
               enddo
             enddo
             enddo
             enddo
             re = lglel(e)
             call cfill(emin(1,1,1,e),re,nxyz)
             call copy (dmin(1,1,1,e),d(1,1,1,e),nxyz)
          enddo
          call gs_op(gsh_fld(ifld),dmin,1,3,0) ! min over all elements
          nchange2=0
          do e=1,nel
          do i=1,nxyz
           if (dmin(i,1,1,e).ne.d(i,1,1,e)) then
              nchange2 = nchange2+1
              emin(i,1,1,e) = 0  ! Flag
           endif
          enddo
          enddo
          call copy(d,dmin,n)                !   Ensure updated distance
          nchange2 = iglsum(nchange2,1)
          nchange  = nchange + nchange2
          call gs_op(gsh_fld(ifld),emin,1,4,0) ! max over all elements
          do e=1,nel    ! Propagate nearest wall points
          do i=1,nxyz
           eg = emin(i,1,1,e)
           if (eg.ne.lglel(e)) then
              xn(i,1,1,e) = 0
              yn(i,1,1,e) = 0
              zn(i,1,1,e) = 0
           endif
          enddo
          enddo
          call gs_op(gsh_fld(ifld),xn,1,1,0) !   Sum over all elements to
          call gs_op(gsh_fld(ifld),yn,1,1,0) !   convey nearest point
          call gs_op(gsh_fld(ifld),zn,1,1,0) !   to shared neighbor.
     1    format(i9,i12,1pe12.4,' max wall distance 2')
       enddo
  1000 continue
c     wgt = 0.3
c     call filter_d2(d,nx1,nz1,wgt,.true.)
       return
       end
c-----------------------------------------------------------------------
