[Nek5000-users] Download and running of nek5000
Tue Mar 26 10:41:41 CDT 2013
Hi Giacinto,
Google unix commands -- perhaps, the following will be helpful
http://doors.stanford.edu/~sr/computing/basic-unix.html
Also your can read the wiki to learn more about Nek
http://nek5000.mcs.anl.gov/index.php/UG
Best.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Tuesday, March 26, 2013 10:02:26 AM
Subject: Re: [Nek5000-users] Download and running of nek5000
Dear Paul ,
thanks for your kind reply and useful information . The terminal says :
"Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ ~/nek5_svn/trunk/tools
-bash: /Users/giacintogenco/nek5_svn/trunk/tools: is a directory
Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ ./maketools
-bash: ./maketools: No such file or directory
Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ "
How can I create the directory ? Maybe it is easier than I think , but I am stuck here . Thank you for your precious help ,
Best Regards
Giacinto Genco
On Tue, Mar 26, 2013 at 8:43 AM, < nek5000-users at lists.mcs.anl.gov > wrote:
Dear Giacinto,
The maketools command should be issued from
where you would type:
./maketools (since it appears that "." is not in your path)
Similarly, makenek should be issued from (say) one of the
examples directories. It is normal to copy the makenek
script to the location where you will build and run the
example, so that makenek and SIZE are in the same directory,
along with the .usr, .rea files, etc.
I hope this helps.
Paul Fischer
On Mon, 25 Mar 2013, nek5000-users at lists.mcs.anl. gov wrote:
Dear sir ,
I am a new mac user . I am trying to download the Nek5000 software but my MacBook Pro is telling me "Checked out revision 906 " . Later when I try to implement the different commands needed for the initial build I have lots of comment like "command not found" or " *** No rule to make target " and so on .
This is what I have from my terminal :
"Last login: Mon Mar 25 12:47:38 on ttys000
dhcp168:~ giacintogenco$ sudo svn co https://svn.mcs.anl.gov/repos/ nek5/
svn: OPTIONS of ' https://svn.mcs.anl.gov/ repos/nek5 ': Could not resolve hostname ` svn.mcs.anl.gov ': Host not found ( https://svn.mcs.anl.gov )
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/ maketools clean
make: *** No rule to make target `clean'. Stop.
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/ maketools all
make: *** No targets specified and no makefile found. Stop.
dhcp168:~ giacintogenco$ make -f <filename of makefile>
-bash: syntax error near unexpected token `newline'
dhcp168:~ giacintogenco$ svn co https://svn.mcs.anl.gov/repos/ nek5/ nek5_svn
Checked out revision 906.
dhcp168:~ giacintogenco$ ~/nek_svn/trunk/tools/ maketools
-bash: /Users/giacintogenco/nek_svn/ trunk/tools/maketools: No such file or directory
Password:
Sorry, try again.
Password:
dhcp168:~ giacintogenco$ nek5_svn/trunk/tools/maketools
Usage: maketools [clean|all|tool(s)]
dhcp168:~ giacintogenco$ nek5_svn/trunk/postnek/ makefile
-bash: nek5_svn/trunk/postnek/ makefile: No such file or directory
dhcp168:~ giacintogenco$ maketools all
-bash: maketools: command not found
dhcp168:~ giacintogenco$ maketools clean
dhcp168:~ giacintogenco$ ~nek5_svn/trunk/nek/makenek
-bash: ~nek5_svn/trunk/nek/makenek: No such file or directory
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/nek/makenek
makenek - automatic build tool for Nek5000
usage: makenek [.usr filename | clean] < -nocompile >
dhcp168:~ giacintogenco$ "
What do you suggest me to do ? It seems that I have all the files I need ( X11 , Mac OS X Lion , etc ) but they are "disconnected " . Please if you have a number of instructions I should follow please send me . I will follow all th hints and the instructions you suggest me to do to run the NEK5000 .
Thank you !
Best Regards
Giacinto Genco
______________________________ _________________
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl. gov
https://lists.mcs.anl.gov/ mailman/listinfo/nek5000-users
Giacinto M. F. Genco
Master of Science in Nuclear Engineering , Purdue University
Master of Science in Aerospace Engineering , Purdue University
Italian " Laurea " in Mechanical Engineering , Politecnico di Bari , Bari , Italy .
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
