[Nek5000-users] Download and running of nek5000
Tue Mar 26 17:50:39 CDT 2013
Hello Alex !
Thanks for the very useful links . I am a Ph.D student working for
Professor A. Ostrogorsky at IIT in Chicago  . I am trying to install
Nek5000 on my Mac Personal computer , in order to run FE elements
simulations on my mac pc .  I partially solved my problem but now the
terminal is saying :
" Last login: Tue Mar 26 17:39:07 on ttys000
Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ ~/bin/prex
Can't open display
 Did you setenv DISPLAY to your localHost
 and xhost + on the local display?
Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ "
Now I do not know how to solve this " display " , but hope and think is no
big deal . Can you give me an advice on what to do ? Thank you very much
indeed since now ,
Best Regards ,
sincerely
Giacinto M. F. Genco
On Tue, Mar 26, 2013 at 10:41 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Giacinto,
> Google unix commands -- perhaps, the following will be helpful
> http://doors.stanford.edu/~sr/computing/basic-unix.html
> Also your can read the wiki to learn more about Nek
> http://nek5000.mcs.anl.gov/index.php/UG
> Best.
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Tuesday, March 26, 2013 10:02:26 AM
> Subject: Re: [Nek5000-users] Download and running of nek5000
> Dear Paul ,
> thanks for your kind reply and useful information . The terminal says :
> "Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ ~/nek5_svn/trunk/tools
> -bash: /Users/giacintogenco/nek5_svn/trunk/tools: is a directory
> Giacinto-Gencos-MacBook-Pro:~ giacintogenco$ ./maketools
> -bash: ./maketools: No such file or directory
> How can I create the directory ? Maybe it is easier than I think , but I
> am stuck here . Thank you for your precious help ,
> Best Regards
> Giacinto Genco
> On Tue, Mar 26, 2013 at 8:43 AM, < nek5000-users at lists.mcs.anl.gov >
> wrote:
> Dear Giacinto,
> The maketools command should be issued from
> where you would type:
> ./maketools (since it appears that "." is not in your path)
> Similarly, makenek should be issued from (say) one of the
> examples directories. It is normal to copy the makenek
> script to the location where you will build and run the
> example, so that makenek and SIZE are in the same directory,
> along with the .usr, .rea files, etc.
> I hope this helps.
> Paul Fischer
> On Mon, 25 Mar 2013, nek5000-users at lists.mcs.anl. gov wrote:
> Dear sir ,
> I am a new mac user . I am trying to download the Nek5000 software but my
> MacBook Pro is telling me "Checked out revision 906 " . Later when I try to
> implement the different commands needed for the initial build I have lots
> of comment like "command not found" or " *** No rule to make target " and
> so on .
> This is what I have from my terminal :
> "Last login: Mon Mar 25 12:47:38 on ttys000
> dhcp168:~ giacintogenco$ sudo svn co https://svn.mcs.anl.gov/repos/ nek5/
> svn: OPTIONS of ' https://svn.mcs.anl.gov/ repos/nek5 ': Could not
> resolve hostname ` svn.mcs.anl.gov ': Host not found (
> https://svn.mcs.anl.gov )
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/ maketools clean
> make: *** No rule to make target `clean'. Stop.
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/ maketools all
> make: *** No targets specified and no makefile found. Stop.
> dhcp168:~ giacintogenco$ make -f <filename of makefile>
> -bash: syntax error near unexpected token `newline'
> dhcp168:~ giacintogenco$ svn co https://svn.mcs.anl.gov/repos/ nek5/
> nek5_svn
> Checked out revision 906.
> dhcp168:~ giacintogenco$ ~/nek_svn/trunk/tools/ maketools
> -bash: /Users/giacintogenco/nek_svn/ trunk/tools/maketools: No such file
> or directory
> Password:
> Sorry, try again.
> Password:
> dhcp168:~ giacintogenco$ nek5_svn/trunk/tools/maketools
> Usage: maketools [clean|all|tool(s)]
> dhcp168:~ giacintogenco$ nek5_svn/trunk/postnek/ makefile
> -bash: nek5_svn/trunk/postnek/ makefile: No such file or directory
> nek5_svn
> dhcp168:~ giacintogenco$ maketools all
> -bash: maketools: command not found
> dhcp168:~ giacintogenco$ maketools clean
> dhcp168:~ giacintogenco$ ~nek5_svn/trunk/nek/makenek
> -bash: ~nek5_svn/trunk/nek/makenek: No such file or directory
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/nek/makenek
> makenek - automatic build tool for Nek5000
> usage: makenek [.usr filename | clean] < -nocompile >
> dhcp168:~ giacintogenco$ "
> What do you suggest me to do ? It seems that I have all the files I need (
> X11 , Mac OS X Lion , etc ) but they are "disconnected " . Please if you
> have a number of instructions I should follow please send me . I will
> follow all th hints and the instructions you suggest me to do to run the
> NEK5000 .
> Thank you !
> Best Regards
> Giacinto Genco
> ______________________________ _________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl. gov
> https://lists.mcs.anl.gov/ mailman/listinfo/nek5000-users
> Master of Science in Nuclear Engineering , Purdue University
> Master of Science in Aerospace Engineering , Purdue University
> Italian " Laurea " in Mechanical Engineering , Politecnico di Bari , Bari
> , Italy .
Italian " Laurea " in Mechanical Engineering , Politecnico di Bari , Bari ,
Italy .
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130326/b82fac28/attachment.html>
