[Nek5000-users] Download and running of nek5000
Tue Mar 26 08:43:57 CDT 2013
Dear Giacinto,
The maketools command should be issued from
~/nek5_svn/trunk/tools
where you would type:
  ./maketools     (since it appears that "." is not in your path)
Similarly, makenek should be issued from (say) one of the
examples directories.    It is normal to copy the makenek
script to the location where you will build and run the
example, so that makenek and SIZE are in the same directory,
along with the .usr, .rea files, etc.
I hope this helps.
Paul Fischer
On Mon, 25 Mar 2013, nek5000-users at lists.mcs.anl.gov wrote:
> Dear sir ,
> I am a new mac user . I am trying to download the Nek5000 software but my MacBook Pro is telling me "Checked out revision 906 " . Later when I try to implement the different commands needed for the initial build I have lots of comment like "command not found" or  " *** No rule to make target " and so on .
> This is what I have from my terminal :
> "Last login: Mon Mar 25 12:47:38 on ttys000
> dhcp168:~ giacintogenco$ sudo svn co https://svn.mcs.anl.gov/repos/nek5/
> svn: OPTIONS of 'https://svn.mcs.anl.gov/repos/nek5': Could not resolve hostname `svn.mcs.anl.gov': Host not found (https://svn.mcs.anl.gov)
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/maketools clean
> make: *** No rule to make target `clean'.  Stop.
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/maketools all
> make: *** No targets specified and no makefile found.  Stop.
> dhcp168:~ giacintogenco$ make -f <filename of makefile>
> -bash: syntax error near unexpected token `newline'
> dhcp168:~ giacintogenco$ svn co https://svn.mcs.anl.gov/repos/nek5/ nek5_svn
> Checked out revision 906.
> dhcp168:~ giacintogenco$ ~/nek_svn/trunk/tools/maketools
> -bash: /Users/giacintogenco/nek_svn/trunk/tools/maketools: No such file or directory
> Password:
> Sorry, try again.
> Password:
> dhcp168:~ giacintogenco$ nek5_svn/trunk/tools/maketools
> Usage: maketools [clean|all|tool(s)]
> dhcp168:~ giacintogenco$ nek5_svn/trunk/postnek/makefile
> -bash: nek5_svn/trunk/postnek/makefile: No such file or directory
> dhcp168:~ giacintogenco$ maketools all
> -bash: maketools: command not found
> dhcp168:~ giacintogenco$ maketools clean
> dhcp168:~ giacintogenco$ ~nek5_svn/trunk/nek/makenek
> -bash: ~nek5_svn/trunk/nek/makenek: No such file or directory
> dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/nek/makenek
> makenek - automatic build tool for Nek5000
> usage: makenek [.usr filename | clean] < -nocompile >
> dhcp168:~ giacintogenco$ "
> What do you suggest me to do ? It seems that I have all the files I need ( X11 , Mac OS X Lion , etc ) but they are "disconnected " . Please if you have a number of instructions I should follow please send me . I will follow all th hints and the instructions you suggest me to do to run the NEK5000 .
> Thank you !
> Best Regards
> Giacinto Genco
> Nek5000-users mailing list
