[Nek5000-users] Download and running of nek5000
Mon Mar 25 16:46:18 CDT 2013
Dear sir ,
I am a new mac user . I am trying to download the Nek5000 software but my MacBook Pro is telling me "Checked out revision 906 " . Later when I try to implement the different commands needed for the initial build I have lots of comment like "command not found" or  " *** No rule to make target " and so on .
This is what I have from my terminal :
"Last login: Mon Mar 25 12:47:38 on ttys000
dhcp168:~ giacintogenco$ sudo svn co https://svn.mcs.anl.gov/repos/nek5/
svn: OPTIONS of 'https://svn.mcs.anl.gov/repos/nek5': Could not resolve hostname `svn.mcs.anl.gov': Host not found (https://svn.mcs.anl.gov)
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/maketools clean
make: *** No rule to make target `clean'.  Stop.
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/tools/maketools all
make: *** No targets specified and no makefile found.  Stop.
dhcp168:~ giacintogenco$ make -f <filename of makefile>
-bash: syntax error near unexpected token `newline'
dhcp168:~ giacintogenco$ svn co https://svn.mcs.anl.gov/repos/nek5/ nek5_svn
Checked out revision 906.
dhcp168:~ giacintogenco$ ~/nek_svn/trunk/tools/maketools
-bash: /Users/giacintogenco/nek_svn/trunk/tools/maketools: No such file or directory
Password:
Sorry, try again.
Password:
dhcp168:~ giacintogenco$ nek5_svn/trunk/tools/maketools
Usage: maketools [clean|all|tool(s)]
dhcp168:~ giacintogenco$ nek5_svn/trunk/postnek/makefile
-bash: nek5_svn/trunk/postnek/makefile: No such file or directory
dhcp168:~ giacintogenco$ maketools all
-bash: maketools: command not found
dhcp168:~ giacintogenco$ maketools clean
dhcp168:~ giacintogenco$ ~nek5_svn/trunk/nek/makenek
-bash: ~nek5_svn/trunk/nek/makenek: No such file or directory
dhcp168:~ giacintogenco$ ~/nek5_svn/trunk/nek/makenek
makenek - automatic build tool for Nek5000
usage: makenek [.usr filename | clean] < -nocompile >
dhcp168:~ giacintogenco$ "
What do you suggest me to do ? It seems that I have all the files I need ( X11 , Mac OS X Lion , etc ) but they are "disconnected " . Please if you have a number of instructions I should follow please send me . I will follow all th hints and the instructions you suggest me to do to run the NEK5000 .
Thank you !
Best Regards
Giacinto Genco
