[Nek5000-users] convert mesh by MOAB
Thu Aug 29 14:49:44 CDT 2013
Try going through ExodusII (.exo or .g), that might work.  Also, which version of cubit are you using?
- tim
On 08/29/2013 02:38 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks tim for your answer,
> I used that command and now I get this error.
> Segmentation fault (core dumped)
> I don't know whatis the problem with my meshing because I can convert from gmsh files (.msh) to .h5m but for cubit it
> gets stocked!! Do you have any idea what is the problem wiht my meshing stuff with cubit?
> Thanks,
> Amirreza
> On Thu, Aug 29, 2013 at 2:34 PM, <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Before saving to the .cub file, use the Trelis (Cubit) command "compress ids all".
>     - tim
>     On 08/29/2013 01:21 PM, nek5000-users at lists.mcs.anl.__gov <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>         Hi All,
>         I am trying to convert cubit mesh to .h5m using MOAB (mbconvert blah.cub blah.h5m), but I get this error
>         Element ids are not contiguous!
>         Failed to load "pipe.cub".
>         Error code: MB_INDEX_OUT_OF_RANGE (1)
>         Error message: No sparse tag CATEGORY value for Vertex 1
>         I don't know what is the problem, does anybody can help in this problem. FYI, I used Trelis to make a mesh, is there
>         anything wrong with my geometry or mesh?
>         Thanks,
>         Ami
>         _________________________________________________
>         Nek5000-users mailing list
>         Nek5000-users at lists.mcs.anl.__gov <mailto:Nek5000-users at lists.mcs.anl.gov>
>         https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users
>         <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>     ==============================__==============================__====
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
>     https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
