[Nek5000-users] convert mesh by MOAB
Thu Aug 29 15:07:49 CDT 2013
Sorry, but that doesn't work too, it gives me
Failed to load "pipe.e".
Error code: MB_INDEX_OUT_OF_RANGE (1)
Error message: pipe.e: Trouble reading vertices
I tried every exporting format but none of them wasn't work, I just made a
pipe with map type meshing and then I used ''compress ids all" then I
exported it as output. everything before that seems good but MOAB gives me
different errors!!
Ami
On Thu, Aug 29, 2013 at 3:49 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Try going through ExodusII (.exo or .g), that might work.  Also, which
> version of cubit are you using?
> - tim
> On 08/29/2013 02:38 PM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Thanks tim for your answer,
>> I used that command and now I get this error.
>> Segmentation fault (core dumped)
>> I don't know whatis the problem with my meshing because I can convert
>> from gmsh files (.msh) to .h5m but for cubit it
>> gets stocked!! Do you have any idea what is the problem wiht my meshing
>> stuff with cubit?
>> Thanks,
>> Amirreza
>> On Thu, Aug 29, 2013 at 2:34 PM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov><mailto:
>> nek5000-users at lists.**mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>>>
>> wrote:
>>     Before saving to the .cub file, use the Trelis (Cubit) command
>> "compress ids all".
>>     - tim
>>     On 08/29/2013 01:21 PM, nek5000-users at lists.mcs.anl.__**gov <mailto:
>> wrote:
>>         Hi All,
>>         I am trying to convert cubit mesh to .h5m using MOAB (mbconvert
>> blah.cub blah.h5m), but I get this error
>>         Element ids are not contiguous!
>>         Failed to load "pipe.cub".
>>         Error message: No sparse tag CATEGORY value for Vertex 1
>>         I don't know what is the problem, does anybody can help in this
>> problem. FYI, I used Trelis to make a mesh, is there
>>         anything wrong with my geometry or mesh?
>>         Thanks,
>>         Ami
>>         ______________________________**___________________
>>         Nek5000-users mailing list
>>         Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.*
>> *mcs.anl.gov <Nek5000-users at lists.mcs.anl.gov>>
>>         https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users>
>>         <https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>     ==============================**__============================**
>> ==__====
>>     "You will keep in perfect peace him whose mind is
>>        steadfast, because he trusts in you."               Isaiah 26:3
>>                   Tim Tautges            Argonne National Laboratory
>>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)
>>  (telecommuting from UW-Madison)
>>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>
>>  1500 Engineering Dr.
>>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>
>>  Madison, WI 53706
>>     Nek5000-users at lists.mcs.anl.__**gov <mailto:Nek5000-users at lists.**
>>     https://lists.mcs.anl.gov/__**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/__mailman/listinfo/nek5000-users><
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130829/3eaf4ff6/attachment-0001.html>
