[Nek5000-users] convert mesh by MOAB
Thu Aug 29 14:38:31 CDT 2013
Thanks tim for your answer,
I used that command and now I get this error.
Segmentation fault (core dumped)
I don't know whatis the problem with my meshing because I can convert from
gmsh files (.msh) to .h5m but for cubit it gets stocked!! Do you have any
idea what is the problem wiht my meshing stuff with cubit?
Amirreza
On Thu, Aug 29, 2013 at 2:34 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Before saving to the .cub file, use the Trelis (Cubit) command "compress
> ids all".
> - tim
> On 08/29/2013 01:21 PM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>> Hi All,
>> I am trying to convert cubit mesh to .h5m using MOAB (mbconvert blah.cub
>> blah.h5m), but I get this error
>> Element ids are not contiguous!
>> Failed to load "pipe.cub".
>> Error code: MB_INDEX_OUT_OF_RANGE (1)
>> Error message: No sparse tag CATEGORY value for Vertex 1
>> I don't know what is the problem, does anybody can help in this problem.
>> FYI, I used Trelis to make a mesh, is there
>> anything wrong with my geometry or mesh?
>> Thanks,
>> Ami
>> ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130829/e879f159/attachment.html>
