[Nek5000-users] convert mesh by MOAB
Thu Aug 29 13:34:06 CDT 2013
Before saving to the .cub file, use the Trelis (Cubit) command "compress ids all".
- tim
On 08/29/2013 01:21 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi All,
> I am trying to convert cubit mesh to .h5m using MOAB (mbconvert blah.cub blah.h5m), but I get this error
> Element ids are not contiguous!
> Failed to load "pipe.cub".
> Error code: MB_INDEX_OUT_OF_RANGE (1)
> Error message: No sparse tag CATEGORY value for Vertex 1
> I don't know what is the problem, does anybody can help in this problem. FYI, I used Trelis to make a mesh, is there
> anything wrong with my geometry or mesh?
> Thanks,
> Ami
> Nek5000-users mailing list
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
