[Nek5000-users] Maketools compile issue of prenek
Wed Aug 14 16:54:36 CDT 2013
Have you tried changing BIBMEM= false?
Otherwise, if you change your parameter limits (of nelm) in
tools/prenek/basics.inc,  you should be able to compile.  I would suggest
trying 100,000 to start.
Best,
Katie
On Wed, Aug 14, 2013 at 1:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Dear Neks
> I updated my tools today to the latest version and then after "./maketools
> clean" and "./maketools all" I encountered a problem in compiling prenek.
> Even after "rm -rf tools" and "svn update tools", I still see the same
> problem regardless. Also note that I have set BIGMEM="true" in my maketools.
> Since I did not have this problem the first time I built the tools, I am
> not sure how this could be related to my compiler or machine memory (which
> are all the same). So I would appreciate it if anyone can help me figure
> this out.
> Regards,
> Hesam
> Make prenek...
> make[1]: Entering directory `/home/p/peltier/hsalehip/src/**
> nek5_svn/trunk/tools/prenek'
> gfortran -o /home/p/peltier/hsalehip/bin/**prex prenek.o curve.o edit.o
> build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o
> vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o
> xdriver.o  -L/usr/lib/X11 -lX11 -lm
> curve.o: In function `hex_transition_3d_e_':
> curve.f:(.text+0x6309): relocation truncated to fit: R_X86_64_PC32 against
> symbol `ctmp2_' defined in COMMON section in zipper2.o
> curve.f:(.text+0x637e): relocation truncated to fit: R_X86_64_PC32 against
> curve.f:(.text+0x63ab): relocation truncated to fit: R_X86_64_PC32 against
> curve.f:(.text+0x63d8): relocation truncated to fit: R_X86_64_PC32 against
> curve.o: In function `hexagon_refine_e_':
> curve.f:(.text+0x75a5): relocation truncated to fit: R_X86_64_PC32 against
> curve.f:(.text+0x763d): relocation truncated to fit: R_X86_64_PC32 against
> curve.f:(.text+0x768d): relocation truncated to fit: R_X86_64_PC32 against
> build.o: In function `list_delete_':
> build.f:(.text+0x2d37): relocation truncated to fit: R_X86_64_32S against
> symbol `idelt_' defined in COMMON section in build.o
> build.f:(.text+0x2dd1): relocation truncated to fit: R_X86_64_32S against
> build.o: In function `imp_mesh_vtx_':
> build.f:(.text+0x30f3): relocation truncated to fit: R_X86_64_32S against
> symbol `c_xyz_' defined in COMMON section in build.o
> build.f:(.text+0x3124): additional relocation overflows omitted from the
> output
> collect2: error: ld returned 1 exit status
> make[1]: *** [prex] Error 1
> make[1]: Leaving directory `/home/p/peltier/hsalehip/src/**
> make: *** [all] Error 1
> ______________________________**_________________
> Nek5000-users mailing list
> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130814/6c1cfa19/attachment.html>
