[Nek5000-users] Maketools compile issue of prenek
Fri Aug 16 10:10:47 CDT 2013
Hi Katie
Thanks for your reply. I did manage to compile prenek with 100,000 nelm.
Making BIGMEM = false did not change it though.
Hesam
On 13-08-14 05:54 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> Have you tried changing BIBMEM= false?
> Otherwise, if you change your parameter limits (of nelm) in
> tools/prenek/basics.inc,  you should be able to compile.  I would
> suggest trying 100,000 to start.
> Best,
> Katie
> On Wed, Aug 14, 2013 at 1:25 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Dear Neks
>     I updated my tools today to the latest version and then after
>     "./maketools clean" and "./maketools all" I encountered a problem
>     in compiling prenek. Even after "rm -rf tools" and "svn update
>     tools", I still see the same problem regardless. Also note that I
>     have set BIGMEM="true" in my maketools.
>     Since I did not have this problem the first time I built the
>     tools, I am not sure how this could be related to my compiler or
>     machine memory (which are all the same). So I would appreciate it
>     if anyone can help me figure this out.
>     Regards,
>     Hesam
>     Make prenek...
>     make[1]: Entering directory
>     `/home/p/peltier/hsalehip/src/nek5_svn/trunk/tools/prenek'
>     gfortran -o /home/p/peltier/hsalehip/bin/prex prenek.o curve.o
>     edit.o build.o build1.o build2.o bound.o plot.o xinterface.o
>     glomod.o legend.o vprops.o iolib.o subs.o zipper2.o postnek6.o
>     screen.o revert.o crs.o mxm.o xdriver.o  -L/usr/lib/X11 -lX11 -lm
>     curve.o: In function `hex_transition_3d_e_':
>     curve.f:(.text+0x6309): relocation truncated to fit: R_X86_64_PC32
>     against symbol `ctmp2_' defined in COMMON section in zipper2.o
>     curve.f:(.text+0x637e): relocation truncated to fit: R_X86_64_PC32
>     curve.f:(.text+0x63ab): relocation truncated to fit: R_X86_64_PC32
>     curve.f:(.text+0x63d8): relocation truncated to fit: R_X86_64_PC32
>     curve.o: In function `hexagon_refine_e_':
>     curve.f:(.text+0x75a5): relocation truncated to fit: R_X86_64_PC32
>     curve.f:(.text+0x763d): relocation truncated to fit: R_X86_64_PC32
>     curve.f:(.text+0x768d): relocation truncated to fit: R_X86_64_PC32
>     build.o: In function `list_delete_':
>     build.f:(.text+0x2d37): relocation truncated to fit: R_X86_64_32S
>     against symbol `idelt_' defined in COMMON section in build.o
>     build.f:(.text+0x2dd1): relocation truncated to fit: R_X86_64_32S
>     build.o: In function `imp_mesh_vtx_':
>     build.f:(.text+0x30f3): relocation truncated to fit: R_X86_64_32S
>     against symbol `c_xyz_' defined in COMMON section in build.o
>     build.f:(.text+0x3124): additional relocation overflows omitted
>     from the output
>     collect2: error: ld returned 1 exit status
>     make[1]: *** [prex] Error 1
>     make[1]: Leaving directory
>     make: *** [all] Error 1
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20130816/ef76aba3/attachment.html>
