[Nek5000-users] Maketools compile issue of prenek
Wed Aug 14 13:25:18 CDT 2013
Dear Neks
I updated my tools today to the latest version and then after "./maketools clean" and "./maketools all" I encountered a problem in compiling prenek. Even after "rm -rf tools" and "svn update tools", I still see the same problem regardless. Also note that I have set BIGMEM="true" in my maketools.
Since I did not have this problem the first time I built the tools, I am not sure how this could be related to my compiler or machine memory (which are all the same). So I would appreciate it if anyone can help me figure this out.
Hesam
Make prenek...
make[1]: Entering directory `/home/p/peltier/hsalehip/src/nek5_svn/trunk/tools/prenek'
gfortran -o /home/p/peltier/hsalehip/bin/prex prenek.o curve.o edit.o build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o xdriver.o  -L/usr/lib/X11 -lX11 -lm
curve.o: In function `hex_transition_3d_e_':
curve.f:(.text+0x6309): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.f:(.text+0x637e): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.f:(.text+0x63ab): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.f:(.text+0x63d8): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.o: In function `hexagon_refine_e_':
curve.f:(.text+0x75a5): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.f:(.text+0x763d): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
curve.f:(.text+0x768d): relocation truncated to fit: R_X86_64_PC32 against symbol `ctmp2_' defined in COMMON section in zipper2.o
build.o: In function `list_delete_':
build.f:(.text+0x2d37): relocation truncated to fit: R_X86_64_32S against symbol `idelt_' defined in COMMON section in build.o
build.f:(.text+0x2dd1): relocation truncated to fit: R_X86_64_32S against symbol `idelt_' defined in COMMON section in build.o
build.o: In function `imp_mesh_vtx_':
build.f:(.text+0x30f3): relocation truncated to fit: R_X86_64_32S against symbol `c_xyz_' defined in COMMON section in build.o
build.f:(.text+0x3124): additional relocation overflows omitted from the output
collect2: error: ld returned 1 exit status
make[1]: *** [prex] Error 1
make[1]: Leaving directory `/home/p/peltier/hsalehip/src/nek5_svn/trunk/tools/prenek'
make: *** [all] Error 1
