[Nek5000-users] how to choose lx1
Mon Sep 24 17:30:10 CDT 2012
Hi Justin,
Thanks for your quick email.
I killed the simulation after half an hour later, because it was still
on the same line.
I don't think my setup is that big. So I am not sure if I should wait
more or not.
Best,
Mehmet
> Hi Mehmet,
> How long is nek at the gs_setup line? It can take several minutes for large
> cases.
> The last error you're having is because you've run out of memory. Remember
> that the memory footprint on each processor scales as lx1^3 * lelt. With
> certain compilers you can add the following option in makenek:
> G="-mcmodel=medium"
> This allows you compile larger arrays, and generally use more memory.
> Best,
> Justin
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120925/02e0e672/attachment.html>
