[Nek5000-users] how to choose lx1
Mon Sep 24 17:20:56 CDT 2012
Hi Justin,
Thanks for your quick email.
I killed the simulation after half an hour later, because it was still
on the same line.
I don't think my setup is that big. So I am not sure if I should wait
more or not.
Best,
Mehmet
Hi Mehmet,
How long is nek at the gs_setup line? It can take several minutes for large
cases.
The last error you're having is because you've run out of memory. Remember
that the memory footprint on each processor scales as lx1^3 * lelt. With
certain compilers you can add the following option in makenek:
G="-mcmodel=medium"
This allows you compile larger arrays, and generally use more memory.
Best,
Justin
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120925/9bc5c94b/attachment.html>
