[Nek5000-users] Compilation Error on BG/Q
Tue Sep 11 07:13:38 CDT 2012
btw: What follows is a statement from the compiler manual:
(E) An error that the compiler can correct. The program should run
correctly.
hth,
-Stefan
On Tue, Sep 11, 2012 at 2:10 PM, S K <stgeke at gmail.com> wrote:
> Do you get an executable from the compiler? In this case, just go ahead a
> give it a whirl.
> -Stefan
> Well, the answer is pretty simple: If your compiler was able to create an
> executable
> On Tue, Sep 11, 2012 at 12:07 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>  Hi Stefan,
>> Aren't those lines tagged with "(E)" errors (and "(W)" warnings)?
>> "$NEKDIR/trunk/nek/plan4.f", line 408.19: 1516-023 (E) Subscript is out
>> of bounds.
>> "$NEKDIR/trunk/nek/plan4.f", line 409.28: 1516-023 (E) Subscript is out
>> of bounds.
>> "$NEKDIR/trunk/nek/plan4.f", line 413.21: 1516-023 (E) Subscript is out
>> of bounds.
>> "$NEKDIR/trunk/nek/plan4.f", line 414.30: 1516-023 (E) Subscript is out
>> of bounds.
>> and
>> "$NEKDIR/trunk/nek/ic.f", line 935.29: 1516-023 (E) Subscript is out of
>> bounds.
>> and
>> "$NEKDIR/trunk/nek/jl/poly_imp.h", line 8.28: 1506-1418 (E) Assignment
>> between restrict pointers "w" and "data" is not allowed. Only
>> outer-to-inner scope assignments between restrict pointers are allowed.
>> In your opinion everything should work fine?
>> Fabian
>> On 09/11/2012 10:47 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> I cannot see any errors (only warnings) in your compiler.out?
>> -Stefan
>> On Tue, Sep 11, 2012 at 10:33 AM, <nek5000-users at lists.mcs.anl.gov>wrote:
>>> Hi neks!
>>> On the BG/Q in Jülich we encounter several errors while compiling
>>> nek5000 (Revision: 853). Please find attached the compiler output, the
>>> makenek script and the makefile.
>>> The installed compiler versions are "IBM XL C/C++ for Blue Gene, V12.1"
>>> and "IBM XL Fortran for Blue Gene, V14.1".
>>> Did you come across similar problems on your BG/Q runs? Do you have any
>>> hint how I can fix this?
>>> Thanks in advance
>>> Fabian
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Dipl.-Ing. Fabian Hennig
>> Wissenschaftlicher Mitarbeiter
>> Institut für Technische Verbrennung (ITV)
>> RWTH Aachen
>> Templergraben 64
>> 52056 Aachen
>> Telefon: +49-241-80-94614
>> E-Mail: fhennig at itv.rwth-aachen.de
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120911/c8460273/attachment.html>
