[Nek5000-users] Compilation Error on BG/Q
Tue Sep 11 07:10:23 CDT 2012
Do you get an executable from the compiler? In this case, just go ahead a
give it a whirl.
-Stefan
Well, the answer is pretty simple: If your compiler was able to create an
executable
On Tue, Sep 11, 2012 at 12:07 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>  Hi Stefan,
> Aren't those lines tagged with "(E)" errors (and "(W)" warnings)?
> "$NEKDIR/trunk/nek/plan4.f", line 408.19: 1516-023 (E) Subscript is out of
> bounds.
> "$NEKDIR/trunk/nek/plan4.f", line 409.28: 1516-023 (E) Subscript is out of
> bounds.
> "$NEKDIR/trunk/nek/plan4.f", line 413.21: 1516-023 (E) Subscript is out of
> bounds.
> "$NEKDIR/trunk/nek/plan4.f", line 414.30: 1516-023 (E) Subscript is out of
> bounds.
> and
> "$NEKDIR/trunk/nek/ic.f", line 935.29: 1516-023 (E) Subscript is out of
> bounds.
> and
> "$NEKDIR/trunk/nek/jl/poly_imp.h", line 8.28: 1506-1418 (E) Assignment
> between restrict pointers "w" and "data" is not allowed. Only
> outer-to-inner scope assignments between restrict pointers are allowed.
> In your opinion everything should work fine?
> Fabian
> On 09/11/2012 10:47 AM, nek5000-users at lists.mcs.anl.gov wrote:
> I cannot see any errors (only warnings) in your compiler.out?
> -Stefan
> On Tue, Sep 11, 2012 at 10:33 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi neks!
>> On the BG/Q in Jülich we encounter several errors while compiling nek5000
>> (Revision: 853). Please find attached the compiler output, the makenek
>> script and the makefile.
>> The installed compiler versions are "IBM XL C/C++ for Blue Gene, V12.1"
>> and "IBM XL Fortran for Blue Gene, V14.1".
>> Did you come across similar problems on your BG/Q runs? Do you have any
>> hint how I can fix this?
>> Thanks in advance
>> Fabian
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Nek5000-users mailing listNek5000-users at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20120911/2ba52c24/attachment.html>
