[Nek5000-users] does load_fld() work with .f00* files ?? (default binary files)
Thu Oct 11 07:29:19 CDT 2012
PS:
   - ncli is an integer I have defined as parameter earlier in usrchck.
   - it actually seems like useric subroutine is called at some point
   zeroing out all my vx,vy,vz. I have tried specifying ux = 1234 in useric
   and then re-run the code and I get uvwpt min  1234 ...
   - when I want to load just one single file using the restart option in
   blah.rea, it works just fine.
On 11 October 2012 14:10, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Nek's,
> I have some troubles with the load_fld subroutine. It seems to load the
> files I want, however it sets everything (vx, vy, vz) to zero...
> Here is what I have in my usrchk routine:
>       n = nx1*ny1*nz1*nelt
>       ifto = .true.
>       if(nid.EQ.0) then
>          open(unit=199,file='file.list',form='formatted',status='old')
>          read(199,'(A80)') (filename(i),i=1,ncli+1)
>          close(199)
>       endif
>       call bcast(filename,(ncli+1)*80)
>       do i = 1,ncli+1
>          call load_fld(filename(i))
>          if(nid.EQ.0) write(*,*) 'File', filename(i), 'loaded.'
>          call lambda2(t(1,1,1,1,1))
>          call outpost(vx,vy,vz,pr,t,'PRT')
>       enddo
> And here is what I get in my logfile for the first file for instance:
>        nsteps=0 -> skip time loop
>        running solver in post processing mode
>        call userchk
>        set initial conditions
>        nekuic (1) for ifld            1
>        call nekuic for vel
>        xyz min     0.0000       0.0000       0.0000
>        uvwpt min  0.99960E-20  0.99960E-20  0.99960E-20   0.0000
> 0.99960E-20
>        PS min      0.0000       0.0000      0.99000E+22
>        xyz max     1.0000       1.0000       1.0000
>        uvwpt max  0.80000E-19  0.80000E-19  0.80000E-19   0.0000
> 0.80000E-19
>        PS max      0.0000       0.0000     -0.99000E+22
>        done :: set initial conditions
>        File prtcav0.f00001 loaded.
> Have I been doing something wrong using the load_fld routine?
> Regards,
> On 12 March 2012 13:00, <nek5000-users at lists.mcs.anl.gov> wrote:
>> nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov> a
>> écrit :
>>  Hi everyone, i am trying to post process some data but it seems load_fld
>>> doesn't load the velocity field correctly.
>>> My binary files are default .f00* files (param(66)=param(67)=0)
>>> I want to recalculate the vortex size (aa in my code) in a 2D case.
>>> So here is what i want my userchk() to do
>>> Open one by one .f00* files,
>>> Calculate the vorticity field from velocity field
>>> Restrain the domain to avoid Boundary conditions
>>> Calculate the circulation
>>> Calculate The vorticity barycenter coordinates
>>> Calculate The vorticity Size (aa)
>>> Output to "Rayon_Circulation_domaine_**entier" file the quantity
>>> sqrt(aa)
>>> Does load_fld() work only with .fld files ?? Because with this i got
>>> only negative values for the vorticity size and the circulation value is
>>> not good
>>> B.regards
>>> Can
>>> My post-precessing part in my userchk() is like
>>>         ! read file-list
>>>         if (nid.eq.0) then
>>>            open(unit=199,file='file.list'**
>>> ,form='formatted',status='old'**)
>>>            read(199,*) nfiles
>>>            read(199,'(A80)') (filename(j),j=1,nfiles)
>>>            close(199)
>>>         endif
>>>         call bcast(nfiles,isize)
>>>         call bcast(filename,nfiles*80)             do j = 1,nfiles
>>>        call load_fld(filename(j))
>>>    call comp_vort3(vort,work1,work2,**vx,vy,vz)
>>>        do i=1, ntot
>>>            if((abs(xm1(i,1,1,1))<14.9) .and. (abs(ym1(i,1,1,1))<14.9))
>>> &     then                x_new(i)=xm1(i,1,1,1)
>>>            y_new(i)=ym1(i,1,1,1)
>>>            rId(i)=1.0
>>>          else
>>>            x_new(i)=0.0
>>>            y_new(i)=0.0
>>>            rId(i)=0.0
>>>          endif
>>>          enddo
>>>          circ=glsc3(rId,bm1,vort(1,1),**ntot)
>>>          x_c=glsc3(x_new,bm1,vort(1,1),**ntot)/circ
>>> ! Calculation of vorticity barrycenter
>>>          y_c=glsc3(y_new,bm1,vort(1,1),**ntot)/circ
>>>          do i=1, ntot
>>> &     then            rr(i)=(xm1(i,1,1,1)-x_c(1))**2 + (ym1(i,1,1,1)
>>>     &                  -y_c(1))**2
>>>          else
>>>            rr(i)=0.0
>>>          endif
>>>          enddo
>>>          aa=glsc3(rr,bm1,vort(1,1),**ntot)/circ
>>>       ! Calculation of vorticity size
>>>    print*,'aa=',aa
>>>          if (nid.eq.0) then
>>>    open(UNIT=1,FILE='Rayon_**Circulation_domaine_entier',**STATUS='unknown')
>>>   !Output to 'Rayon_Circulation_domaine_**entier' file
>>>    write(1,'(1p20E15.7)') time,sqrt(aa),circ
>>>    endif
>>>        enddo
>>>     !we are done
>>>         call exitt
>>> c    ==============================**==============================**
>>> ______________________________**_________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>> Well sorry for this, load_fld() works great with .f00* files
>> Le problem was related to my grid in the domain which was not tight
>> enough for x>10
>> Thx anyways
> Jean-Christophe
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121011/6176dbf7/attachment-0001.html>
