[Nek5000-users] does load_fld() work with .f00* files ?? (default binary files)
Thu Oct 11 07:10:58 CDT 2012
Hi Nek's,
I have some troubles with the load_fld subroutine. It seems to load the
files I want, however it sets everything (vx, vy, vz) to zero...
Here is what I have in my usrchk routine:
      n = nx1*ny1*nz1*nelt
      ifto = .true.
      if(nid.EQ.0) then
         open(unit=199,file='file.list',form='formatted',status='old')
         read(199,'(A80)') (filename(i),i=1,ncli+1)
         close(199)
      endif
      call bcast(filename,(ncli+1)*80)
      do i = 1,ncli+1
         call load_fld(filename(i))
         if(nid.EQ.0) write(*,*) 'File', filename(i), 'loaded.'
         call lambda2(t(1,1,1,1,1))
         call outpost(vx,vy,vz,pr,t,'PRT')
      enddo
And here is what I get in my logfile for the first file for instance:
       nsteps=0 -> skip time loop
       running solver in post processing mode
       call userchk
       set initial conditions
       nekuic (1) for ifld            1
       call nekuic for vel
       xyz min     0.0000       0.0000       0.0000
       uvwpt min  0.99960E-20  0.99960E-20  0.99960E-20   0.0000
0.99960E-20
       PS min      0.0000       0.0000      0.99000E+22
       xyz max     1.0000       1.0000       1.0000
       uvwpt max  0.80000E-19  0.80000E-19  0.80000E-19   0.0000
0.80000E-19
       PS max      0.0000       0.0000     -0.99000E+22
       done :: set initial conditions
       File prtcav0.f00001 loaded.
Have I been doing something wrong using the load_fld routine?
On 12 March 2012 13:00, <nek5000-users at lists.mcs.anl.gov> wrote:
> nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov> a
> écrit :
>  Hi everyone, i am trying to post process some data but it seems load_fld
>> doesn't load the velocity field correctly.
>> My binary files are default .f00* files (param(66)=param(67)=0)
>> I want to recalculate the vortex size (aa in my code) in a 2D case.
>> So here is what i want my userchk() to do
>> Open one by one .f00* files,
>> Calculate the vorticity field from velocity field
>> Restrain the domain to avoid Boundary conditions
>> Calculate the circulation
>> Calculate The vorticity barycenter coordinates
>> Calculate The vorticity Size (aa)
>> Output to "Rayon_Circulation_domaine_**entier" file the quantity sqrt(aa)
>> Does load_fld() work only with .fld files ?? Because with this i got only
>> negative values for the vorticity size and the circulation value is not good
>> B.regards
>> Can
>> My post-precessing part in my userchk() is like
>>         ! read file-list
>>         if (nid.eq.0) then
>>            open(unit=199,file='file.list'**,form='formatted',status='old'
>>            read(199,*) nfiles
>>            read(199,'(A80)') (filename(j),j=1,nfiles)
>>            close(199)
>>         endif
>>         call bcast(nfiles,isize)
>>         call bcast(filename,nfiles*80)             do j = 1,nfiles
>>        call load_fld(filename(j))
>>    call comp_vort3(vort,work1,work2,**vx,vy,vz)
>>        do i=1, ntot
>>            if((abs(xm1(i,1,1,1))<14.9) .and. (abs(ym1(i,1,1,1))<14.9))
>> &     then                x_new(i)=xm1(i,1,1,1)
>>            y_new(i)=ym1(i,1,1,1)
>>            rId(i)=1.0
>>          else
>>            x_new(i)=0.0
>>            y_new(i)=0.0
>>            rId(i)=0.0
>>          endif
>>          enddo
>>          circ=glsc3(rId,bm1,vort(1,1),**ntot)
>>          x_c=glsc3(x_new,bm1,vort(1,1),**ntot)/circ
>> ! Calculation of vorticity barrycenter
>>          y_c=glsc3(y_new,bm1,vort(1,1),**ntot)/circ
>>          do i=1, ntot
>> &     then            rr(i)=(xm1(i,1,1,1)-x_c(1))**2 + (ym1(i,1,1,1)
>>     &                  -y_c(1))**2
>>          else
>>            rr(i)=0.0
>>          endif
>>          enddo
>>          aa=glsc3(rr,bm1,vort(1,1),**ntot)/circ
>>       ! Calculation of vorticity size
>>    print*,'aa=',aa
>>          if (nid.eq.0) then
>>    open(UNIT=1,FILE='Rayon_**Circulation_domaine_entier',**STATUS='unknown')
>>   !Output to 'Rayon_Circulation_domaine_**entier' file
>>    write(1,'(1p20E15.7)') time,sqrt(aa),circ
>>    endif
>>        enddo
>>     !we are done
>>         call exitt
>> c    ==============================**==============================**
>> ______________________________**_________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
> Well sorry for this, load_fld() works great with .f00* files
> Le problem was related to my grid in the domain which was not tight enough
> for x>10
> Thx anyways
Jean-Christophe
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121011/58a54002/attachment.html>
