[Nek5000-users] Stream function
Mon Oct 8 22:48:19 CDT 2012
sorry -- was a bit imprecise
SURFACE PLOT
... then go from there...
you can also get nice .ps output in black and white of the
contour lines if you want
(SET ATTRIBUTE
SET HARD COPY
SET HARD COPY ...
CLEAR
PLOT
Paul
On Mon, 8 Oct 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Paul,
> Great, thanks for the info.  I have not used postnek yet, but I will give
> it a shot.  One issue: the menu I see after choosing SET PLOT FORMAT is:
> ( 1) UP MENU
> ( 2) X-Y PLOT
> ( 3) SURFACE PLOT
> ( 4) VALUES
> ( 5) VOLUME
> ( 6) MULTIPLOT
> ( 7) DRAW MESH NODES
> ( 8) LABEL MESH NODES
> ( 9) DRAW MESH
> I do not see the SCALAR > CONTOUR LINES option.  Am I missing something?
> Best,
> David
