[Nek5000-users] Setting up a case from scratch
Wed Nov 28 21:40:01 CST 2012
Thanks. I will be eagerly waiting for this.
praveen
On Thu, Nov 29, 2012 at 4:15 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Oh, right, ok.  I'd forgotten that those parts of NekCEM and Nek5000 are
> different.
> - tim
> On 11/28/2012 01:35 PM, Misun Min wrote:
>> Hi Tim
>> MOAB supporting 2D quad meshes have been tested for NekCEM/LBM
>> codes but not tested with nek5000. I'll check with Aleks to make
>> sure the updated moab routines not to conflict with nek5000 and
>> commit soon.
>> Thanks
>> Misun
>> ----- Original Message -----
>> From: "Tim Tautges" <tautges at mcs.anl.gov>
>> To: nek5000-users at lists.mcs.anl.**gov <nek5000-users at lists.mcs.anl.gov>,
>> "Misun Min" <mmin at mcs.anl.gov>
>> Sent: Wednesday, November 28, 2012 1:23:02 PM
>> Subject: Re: [Nek5000-users] Setting up a case from scratch
>> Misun and one of her students had that working recently, but I'm not sure
>> if all her updates have been committed to the
>> code.  Misun?
>> - tim
>> On 11/28/2012 11:28 AM, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>> It looks like Nek does not get the mesh from MOAB...
>>> Also I doubt the currecnt version of Nek/MOAB supports 2D Quad meshes --
>>> only 3D hexes, right, Tim?
>>> Thanks.
>>> Aleks
>>> From: nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>
>>> Sent: Wed, 28 Nov 2012 11:23:04 -0600 (CST)
>>> Thanks. I am making little progress. Now I can compile. When running on
>>> h5m
>>> mesh I get
>>>    read .rea file
>>>    ABORT: nelv is invalid in nekmoab_proc_map
>>>    nelv, lelv =            0        1850
>>> But mbsize shows
>>> $ mbsize karman.h5m
>>> File karman.h5m:
>>>      type count   total     minimum     average         rms     maximum
>>>    std.dev.
>>>      Edge   212     5.5   0.0063678    0.026102    0.029283    0.048844
>>>    0.013273
>>>      Quad  1832    0.89  3.8386e-05   0.0004881  0.00054375   0.0011788
>>>    0.00023963
>>> 1D Side  7328 1.8e+02   0.0037915    0.024086    0.027266    0.048844
>>>    0.012777
>>>    Vertex  7540
>>> praveen
>>> On Wed, Nov 28, 2012 at 10:27 PM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>>
>>> wrote:
>>>  Hi Praven,
>>>> use examples/moab/SIZE
>>>> Thanks.
>>>> Aleks
>>>> On Wed, 28 Nov 2012, nek5000-users at lists.mcs.anl.****gov<
>>>> nek5000-users at lists.mcs.**anl.gov <nek5000-users at lists.mcs.anl.gov>
>>>> >wrote:
>>>>    The gmsh file does have all vertices for the higher order elements.
>>>>> I am now trying to compile with moab. I am doing everything in serial
>>>>> for
>>>>> now. I compiled moab succesfully and can convert from gmsh to h5m.
>>>>> But when compiling nek with moab I get this type of errors. This is the
>>>>> first one.
>>>>> gcc -c  -O2 -DMOAB -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE
>>>>> -DGLOBAL_LONG_LONG
>>>>> /Users/praveen/Applications/****nek5_svn/trunk/nek/3rd_party/***
>>>>> *imeshcutil.c
>>>>> -o
>>>>> obj/imeshcutil.o
>>>>>      Included at
>>>>> *MOABCORE:17:
>>>>>      Included at
>>>>> *NEKMOAB:51:
>>>>>      Included at
>>>>> *moab.f:79:
>>>>>        parameter (ldim=2)
>>>>>                       1
>>>>> Error: Symbol 'ldim' at (1) has no IMPLICIT type
>>>>> My makenek looks like this
>>>>> # Fortran compiler
>>>>> F77="gfortran"
>>>>> # C compiler
>>>>> CC="gcc"
>>>>> # pre-processor symbol list
>>>>> # (set PPLIST=? to get a list of available symbols)
>>>>> PPLIST="MOAB"
>>>>> # plug-in list
>>>>> PLUGIN_LIST=""
>>>>> # OPTIONAL SETTINGS
>>>>> # enable MPI (default true)
>>>>> IFMPI="false"
>>>>> # auxilliary files to compile
>>>>> # NOTE: source files have to located in the same directory as makenek
>>>>> #       a makefile_usr.inc has to be provided containing the build
>>>>> rules
>>>>> #USR="foo.o"
>>>>> # linking flags
>>>>> #USR_LFLAGS="-L/usr/lib -lfoo"
>>>>> # generic compiler flags
>>>>> #G="-g"
>>>>> # optimization flags
>>>>> #OPT_FLAGS_STD=""
>>>>> #OPT_FLAGS_MAG=""
>>>>> # enable AMG coarse grid solver (default XXT)
>>>>> #IFAMG="true"
>>>>> #IFAMG_DUMP="true"
>>>>> # CVODE path
>>>>> #CVODE_DIR=$HOME/cvode/lib
>>>>> # MOAB/iMESH path
>>>>> MOAB_DIR="/opt/moab"
>>>>> # For linking to MOAB, the following might be needed:
>>>>> # NOTE: compiler specific, use the appropriate one depending on your
>>>>> compiler
>>>>> # GNU:
>>>>> USR_LFLAGS="-lmpi_cxx -lstdc++"
>>>>> # Intel:
>>>>> # USR_LFLAGS="-cxxlib"
>>>>> # PGI:
>>>>> # USR_LFLAGS="-pgcpplibs"
>>>>> # USR_LFLAGS=" -lmpi_cxx -lstdc++"
>>>>> What am I doing wrong ?
>>>>> Thanks
>>>>> praveen
>>>>> On Wed, Nov 28, 2012 at 8:46 PM, <nek5000-users at lists.mcs.anl.****gov<
>>>>> nek5000-users at lists.mcs.**anl.gov <nek5000-users at lists.mcs.anl.gov>>>
>>>>> wrote:
>>>>>    Try running 'mbsize' on the gmsh file, and check the number of
>>>>> vertices
>>>>>> to
>>>>>> make sure it's getting all of them.  Or, run mbsize -ll, piping the
>>>>>> output
>>>>>> to a file, and check one of the hexes to make sure it's 27-noded.  If
>>>>>> that's the case, we're all set (modulo how to handle the BC's).
>>>>>> - tim
>>>>>>     ______________________________****_________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.****gov <Nek5000-users at lists.mcs.anl.**gov<Nek5000-users at lists.mcs.anl.gov>
>>>> https://lists.mcs.anl.gov/****mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users>
>>>> **<https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
>>> ______________________________**_________________
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20121129/a0c0fba5/attachment-0001.html>
