[Nek5000-users] Setting up a case from scratch
Wed Nov 28 16:45:00 CST 2012
Oh, right, ok.  I'd forgotten that those parts of NekCEM and Nek5000 are different.
- tim
On 11/28/2012 01:35 PM, Misun Min wrote:
> Hi Tim
> MOAB supporting 2D quad meshes have been tested for NekCEM/LBM
> codes but not tested with nek5000. I'll check with Aleks to make
> sure the updated moab routines not to conflict with nek5000 and
> commit soon.
> Thanks
> Misun
> From: "Tim Tautges" <tautges at mcs.anl.gov>
> To: nek5000-users at lists.mcs.anl.gov, "Misun Min" <mmin at mcs.anl.gov>
> Sent: Wednesday, November 28, 2012 1:23:02 PM
> Subject: Re: [Nek5000-users] Setting up a case from scratch
> Misun and one of her students had that working recently, but I'm not sure if all her updates have been committed to the
> code.  Misun?
> - tim
> On 11/28/2012 11:28 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> It looks like Nek does not get the mesh from MOAB...
>> Also I doubt the currecnt version of Nek/MOAB supports 2D Quad meshes -- only 3D hexes, right, Tim?
>> Thanks.
>> Aleks
>> From: nek5000-users at lists.mcs.anl.gov
>> Sent: Wed, 28 Nov 2012 11:23:04 -0600 (CST)
>> Thanks. I am making little progress. Now I can compile. When running on h5m
>> mesh I get
>>    read .rea file
>>    ABORT: nelv is invalid in nekmoab_proc_map
>>    nelv, lelv =            0        1850
>> But mbsize shows
>> $ mbsize karman.h5m
>> File karman.h5m:
>>      type count   total     minimum     average         rms     maximum
>>    std.dev.
>>      Edge   212     5.5   0.0063678    0.026102    0.029283    0.048844
>>    0.013273
>>      Quad  1832    0.89  3.8386e-05   0.0004881  0.00054375   0.0011788
>>    0.00023963
>> 1D Side  7328 1.8e+02   0.0037915    0.024086    0.027266    0.048844
>>    0.012777
>>    Vertex  7540
>> praveen
>> On Wed, Nov 28, 2012 at 10:27 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Praven,
>>> use examples/moab/SIZE
>>> Thanks.
>>> Aleks
>>> On Wed, 28 Nov 2012, nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>wrote:
>>>    The gmsh file does have all vertices for the higher order elements.
>>>> I am now trying to compile with moab. I am doing everything in serial for
>>>> now. I compiled moab succesfully and can convert from gmsh to h5m.
>>>> But when compiling nek with moab I get this type of errors. This is the
>>>> first one.
>>>> gcc -c  -O2 -DMOAB -DPTRSIZE8 -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
>>>> /Users/praveen/Applications/**nek5_svn/trunk/nek/3rd_party/**imeshcutil.c
>>>> -o
>>>> obj/imeshcutil.o
>>>>      Included at
>>>> /Users/praveen/Applications/**nek5_svn/trunk/nek/3rd_party/**MOABCORE:17:
>>>>      Included at
>>>> /Users/praveen/Applications/**nek5_svn/trunk/nek/3rd_party/**NEKMOAB:51:
>>>>      Included at
>>>> /Users/praveen/Applications/**nek5_svn/trunk/nek/3rd_party/**moab.f:79:
>>>>        parameter (ldim=2)
>>>>                       1
>>>> Error: Symbol 'ldim' at (1) has no IMPLICIT type
>>>> My makenek looks like this
>>>> # Fortran compiler
>>>> F77="gfortran"
>>>> # C compiler
>>>> CC="gcc"
>>>> # pre-processor symbol list
>>>> # (set PPLIST=? to get a list of available symbols)
>>>> PPLIST="MOAB"
>>>> # plug-in list
>>>> PLUGIN_LIST=""
>>>> # OPTIONAL SETTINGS
>>>> # enable MPI (default true)
>>>> IFMPI="false"
>>>> # auxilliary files to compile
>>>> # NOTE: source files have to located in the same directory as makenek
>>>> #       a makefile_usr.inc has to be provided containing the build rules
>>>> #USR="foo.o"
>>>> # linking flags
>>>> #USR_LFLAGS="-L/usr/lib -lfoo"
>>>> # generic compiler flags
>>>> #G="-g"
>>>> # optimization flags
>>>> #OPT_FLAGS_STD=""
>>>> #OPT_FLAGS_MAG=""
>>>> # enable AMG coarse grid solver (default XXT)
>>>> #IFAMG="true"
>>>> #IFAMG_DUMP="true"
>>>> # CVODE path
>>>> #CVODE_DIR=$HOME/cvode/lib
>>>> # MOAB/iMESH path
>>>> MOAB_DIR="/opt/moab"
>>>> # For linking to MOAB, the following might be needed:
>>>> # NOTE: compiler specific, use the appropriate one depending on your
>>>> compiler
>>>> # GNU:
>>>> USR_LFLAGS="-lmpi_cxx -lstdc++"
>>>> # Intel:
>>>> # USR_LFLAGS="-cxxlib"
>>>> # PGI:
>>>> # USR_LFLAGS="-pgcpplibs"
>>>> # USR_LFLAGS=" -lmpi_cxx -lstdc++"
>>>> What am I doing wrong ?
>>>> Thanks
>>>> praveen
>>>> On Wed, Nov 28, 2012 at 8:46 PM, <nek5000-users at lists.mcs.anl.**gov<nek5000-users at lists.mcs.anl.gov>>
>>>> wrote:
>>>>    Try running 'mbsize' on the gmsh file, and check the number of vertices
>>>>> to
>>>>> make sure it's getting all of them.  Or, run mbsize -ll, piping the
>>>>> output
>>>>> to a file, and check one of the hexes to make sure it's 27-noded.  If
>>>>> that's the case, we're all set (modulo how to handle the BC's).
>>>>> - tim
>>>>    ______________________________**_________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.**gov <Nek5000-users at lists.mcs.anl.gov>
>>> https://lists.mcs.anl.gov/**mailman/listinfo/nek5000-users<https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
