[Nek5000-users] Element connectivity information
Thu Mar 15 07:16:39 CDT 2012
Dear Outi,
Thank you for the update.  Just so I understand better, what are
the degrees of freedom for your eigenvalue problem?   Are there
ndim velocity components, plus pressure, plus temperature?
Regarding pressure, are you using PnPn or PnPn-2 ?
What about boundary conditions?  If you are eliminating redundant
velocity variables then you presumably also need to eliminate inactive
boundary values.
Once I have a handle on what you need I'll see if we can come up with
a strategy.
Best regards,
Paul
On Thu, 15 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Paul,
> I am using the parallel version of ARPACK. It is currently only called inside
> userchk. When the Arnoldi operations finish, the Nek5000 velocity vector is
> updated, and I force Nek5000 to start with the new vector as an initial
> condition.
> (I am aware of that this is not an elegant implementation, but we thought
> other options would imply modifying the source).
> I have verified the code against the local Orr-Sommerfeld spectrum in a
> channel flow (using periodic BC in the streamwise direction), and the wake
> behind a cylinder.
> It seems like the spectrum is reproduced correctly, except from a few
> spurious eigenvalues, that are always located "exactly" at zero (real and
> imaginary part). Those do not appear for all cases I have studied, but for
> many cases. So far, I have ignored the spurious eigenvalues, though they make
> the convergence slower.
> Best regards,
> Outi
> 14 Mar 2012 kl. 22:23 skrev nek5000-users at lists.mcs.anl.gov:
>> Dear Outi,
>> Can you tell me a bit more about the Arnoldi solver? (I know
>> about the method.  Here, I mean the specific source code that
>> you are using, what the interface to the code is, etc.)
>> Best regards,
>> Paul
>> On Wed, 14 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Paul,
>>> Thank you for a quick response.
>>> My current understanding is that the error occurs since Arnoldi treats the
>>> velocities in the duplicated points as separate degrees of freedom (which
>>> they are not in Nek5000, since they come out always equal).
>>> So, therefore I am not so sure that a weighting operation would remove the
>>> problem.
>>> Anyway, I will test what you suggest in a few cases and tell you how it
>>> comes out.
>>> But if it turns out that counting the points once is the only option
>>> (asymmetrically, as you point out), is it possible to do this?
>>> (Another option is always that I make changes inside the Arnoldi
>>> algorithm, but this might be a bit more elaborate.)
>>> Thanks a lot,
>>> Outi
>>> 14 Mar 2012 kl. 13:40 skrev nek5000-users at lists.mcs.anl.gov:
>>>> Hi Outi,
>>>> We encounter this problem all the time in conjugate gradient
>>>> and gmres iteration.
>>>> For reasons of symmetry (and, hence, commutativity and associativity,
>>>> which are two essential ingredients for parallel execution), I would
>>>> suggest that you not try to store the data only once, but rather
>>>> scale by the inverse counting-matrix (aka, multiplicity), so that
>>>> interface points are not counted twice when computing your inner
>>>> products.
>>>> The inverse counting-matrix is stored in vmult() and tmult().  A
>>>> typical application is:
>>>>   alpha = glsc3(vx,vmult,vx,n)   (n=nx1*ny1*nz1*nelv)
>>>> which gives the l2 inner product:  alpha := sum_i (vx_i)^2 for a vector
>>>> VX.
>>>> Note that if you instead want the L2 inner product
>>>>   alpha = \int_Omega (vx)^2 dV
>>>> you would compute this as:
>>>>   alpha = glsc3(vx,bm1,vx,n)
>>>>         = vx^T B vx
>>>> which is the inner product of vx with the (diagonal) mass matrix B.
>>>> If you want the average of the physical rms (say), it would be:
>>>>   if (alpha.gt.0) alpha = sqrt(alpha/volvm1)
>>>> etc.
>>>> In summary, for linear algebra, use vmult(). For physics, use bm1()
>>>> (B, on Mesh 1).
>>>> Please let me know if this help to resolve your problem.
>>>> Best regards,
>>>> Paul
>>>>> Hi Neks,
>>>>> I am using Nek5000 coupled to an Arnoldi algorithm for hydrodynamic
>>>>> stability computations. In these, I form a vector of the velocities,
>>>>> which I regularly pass to the Arnoldi solver. Then, a new velocity
>>>>> vector is formed which is passed back to Nek5000.
>>>>> Now, the code works as it is, but in addition to the physical modes it
>>>>> produces some spurious modes, which I think originate from the fact that
>>>>> the velocities at the element-common boundaries are accounted for twice.
>>>>> To fix this, I need to access the element connectivity information. Can
>>>>> you please guide me to in which variable this is stored?
>>>>> In particular, this is what I would like to do:
>>>>> -  add the element-common points to the local vector only for one of two
>>>>> adjacent elements (and for a corner point, only one of the four elements
>>>>> adjacent to it).
>>>>> - for the vector that Arnoldi returns, make sure that the new values of
>>>>> the velocity are inserted also for the other adjacent element(s).
>>>>> Thanks a lot in advance!
>>>>> Outi
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
