[Nek5000-users] Element connectivity information
Thu Mar 15 06:34:36 CDT 2012
Dear Paul,
I am using the parallel version of ARPACK. It is currently only called
inside userchk. When the Arnoldi operations finish, the Nek5000
velocity vector is updated, and I force Nek5000 to start with the new
vector as an initial condition.
(I am aware of that this is not an elegant implementation, but we
thought other options would imply modifying the source).
I have verified the code against the local Orr-Sommerfeld spectrum in
a channel flow (using periodic BC in the streamwise direction), and
the wake behind a cylinder.
It seems like the spectrum is reproduced correctly, except from a few
spurious eigenvalues, that are always located "exactly" at zero (real
and imaginary part). Those do not appear for all cases I have studied,
but for many cases. So far, I have ignored the spurious eigenvalues,
though they make the convergence slower.
Best regards,
Outi
14 Mar 2012 kl. 22:23 skrev nek5000-users at lists.mcs.anl.gov:
> Dear Outi,
> Can you tell me a bit more about the Arnoldi solver? (I know
> about the method.  Here, I mean the specific source code that
> you are using, what the interface to the code is, etc.)
> Best regards,
> Paul
> On Wed, 14 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul,
>> Thank you for a quick response.
>> My current understanding is that the error occurs since Arnoldi
>> treats the velocities in the duplicated points as separate degrees
>> of freedom (which they are not in Nek5000, since they come out
>> always equal).
>> So, therefore I am not so sure that a weighting operation would
>> remove the problem.
>> Anyway, I will test what you suggest in a few cases and tell you
>> how it comes out.
>> But if it turns out that counting the points once is the only
>> option (asymmetrically, as you point out), is it possible to do this?
>> (Another option is always that I make changes inside the Arnoldi
>> algorithm, but this might be a bit more elaborate.)
>> Thanks a lot,
>> Outi
>> 14 Mar 2012 kl. 13:40 skrev nek5000-users at lists.mcs.anl.gov:
>>> Hi Outi,
>>> We encounter this problem all the time in conjugate gradient
>>> and gmres iteration.
>>> For reasons of symmetry (and, hence, commutativity and
>>> associativity,
>>> which are two essential ingredients for parallel execution), I would
>>> suggest that you not try to store the data only once, but rather
>>> scale by the inverse counting-matrix (aka, multiplicity), so that
>>> interface points are not counted twice when computing your inner
>>> products.
>>> The inverse counting-matrix is stored in vmult() and tmult().  A
>>> typical application is:
>>>    alpha = glsc3(vx,vmult,vx,n)   (n=nx1*ny1*nz1*nelv)
>>> which gives the l2 inner product:  alpha := sum_i (vx_i)^2 for a
>>> vector VX.
>>> Note that if you instead want the L2 inner product
>>>    alpha = \int_Omega (vx)^2 dV
>>> you would compute this as:
>>>    alpha = glsc3(vx,bm1,vx,n)
>>>          = vx^T B vx
>>> which is the inner product of vx with the (diagonal) mass matrix B.
>>> If you want the average of the physical rms (say), it would be:
>>>    if (alpha.gt.0) alpha = sqrt(alpha/volvm1)
>>> etc.
>>> In summary, for linear algebra, use vmult(). For physics, use bm1()
>>> (B, on Mesh 1).
>>> Please let me know if this help to resolve your problem.
>>> Best regards,
>>> Paul
>>>> Hi Neks,
>>>> I am using Nek5000 coupled to an Arnoldi algorithm for
>>>> hydrodynamic stability computations. In these, I form a vector of
>>>> the velocities, which I regularly pass to the Arnoldi solver.
>>>> Then, a new velocity vector is formed which is passed back to
>>>> Nek5000.
>>>> Now, the code works as it is, but in addition to the physical
>>>> modes it produces some spurious modes, which I think originate
>>>> from the fact that the velocities at the element-common
>>>> boundaries are accounted for twice. To fix this, I need to access
>>>> the element connectivity information. Can you please guide me to
>>>> in which variable this is stored?
>>>> In particular, this is what I would like to do:
>>>> -  add the element-common points to the local vector only for one
>>>> of two adjacent elements (and for a corner point, only one of the
>>>> four elements adjacent to it).
>>>> - for the vector that Arnoldi returns, make sure that the new
>>>> values of the velocity are inserted also for the other adjacent
>>>> element(s).
>>>> Thanks a lot in advance!
>>>> Outi
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
