[Nek5000-users] Element connectivity information
Thu Mar 15 09:34:01 CDT 2012
Dear Paul,
I answer this one as well, despite that you think removing the element
boundaries might be unnecessary.
Only velocities (ndim components) are included. I use PnPn-2.
Currently, I don't remove the outer boundary points, but I have
thought about removing those as well, and that I know how to do.
Best regards,
Outi
15 Mar 2012 kl. 12:16 skrev nek5000-users at lists.mcs.anl.gov:
> Dear Outi,
> Thank you for the update.  Just so I understand better, what are
> the degrees of freedom for your eigenvalue problem?   Are there
> ndim velocity components, plus pressure, plus temperature?
> Regarding pressure, are you using PnPn or PnPn-2 ?
> What about boundary conditions?  If you are eliminating redundant
> velocity variables then you presumably also need to eliminate inactive
> boundary values.
> Once I have a handle on what you need I'll see if we can come up with
> a strategy.
> Best regards,
> Paul
> On Thu, 15 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Paul,
>> I am using the parallel version of ARPACK. It is currently only
>> called inside userchk. When the Arnoldi operations finish, the
>> Nek5000 velocity vector is updated, and I force Nek5000 to start
>> with the new vector as an initial condition.
>> (I am aware of that this is not an elegant implementation, but we
>> thought other options would imply modifying the source).
>> I have verified the code against the local Orr-Sommerfeld spectrum
>> in a channel flow (using periodic BC in the streamwise direction),
>> and the wake behind a cylinder.
>> It seems like the spectrum is reproduced correctly, except from a
>> few spurious eigenvalues, that are always located "exactly" at zero
>> (real and imaginary part). Those do not appear for all cases I have
>> studied, but for many cases. So far, I have ignored the spurious
>> eigenvalues, though they make the convergence slower.
>> Best regards,
>> Outi
>> 14 Mar 2012 kl. 22:23 skrev nek5000-users at lists.mcs.anl.gov:
>>> Dear Outi,
>>> Can you tell me a bit more about the Arnoldi solver? (I know
>>> about the method.  Here, I mean the specific source code that
>>> you are using, what the interface to the code is, etc.)
>>> Best regards,
>>> Paul
>>> On Wed, 14 Mar 2012, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi Paul,
>>>> Thank you for a quick response.
>>>> My current understanding is that the error occurs since Arnoldi
>>>> treats the velocities in the duplicated points as separate
>>>> degrees of freedom (which they are not in Nek5000, since they
>>>> come out always equal).
>>>> So, therefore I am not so sure that a weighting operation would
>>>> remove the problem.
>>>> Anyway, I will test what you suggest in a few cases and tell you
>>>> how it comes out.
>>>> But if it turns out that counting the points once is the only
>>>> option (asymmetrically, as you point out), is it possible to do
>>>> this?
>>>> (Another option is always that I make changes inside the Arnoldi
>>>> algorithm, but this might be a bit more elaborate.)
>>>> Thanks a lot,
>>>> Outi
>>>> 14 Mar 2012 kl. 13:40 skrev nek5000-users at lists.mcs.anl.gov:
>>>>> Hi Outi,
>>>>> We encounter this problem all the time in conjugate gradient
>>>>> and gmres iteration.
>>>>> For reasons of symmetry (and, hence, commutativity and
>>>>> associativity,
>>>>> which are two essential ingredients for parallel execution), I
>>>>> would
>>>>> suggest that you not try to store the data only once, but rather
>>>>> scale by the inverse counting-matrix (aka, multiplicity), so
>>>>> that interface points are not counted twice when computing your
>>>>> inner
>>>>> products.
>>>>> The inverse counting-matrix is stored in vmult() and tmult().  A
>>>>> typical application is:
>>>>>  alpha = glsc3(vx,vmult,vx,n)   (n=nx1*ny1*nz1*nelv)
>>>>> which gives the l2 inner product:  alpha := sum_i (vx_i)^2 for a
>>>>> vector VX.
>>>>> Note that if you instead want the L2 inner product
>>>>>  alpha = \int_Omega (vx)^2 dV
>>>>> you would compute this as:
>>>>>  alpha = glsc3(vx,bm1,vx,n)
>>>>>        = vx^T B vx
>>>>> which is the inner product of vx with the (diagonal) mass matrix
>>>>> B.
>>>>> If you want the average of the physical rms (say), it would be:
>>>>>  if (alpha.gt.0) alpha = sqrt(alpha/volvm1)
>>>>> etc.
>>>>> In summary, for linear algebra, use vmult(). For physics, use
>>>>> bm1()
>>>>> (B, on Mesh 1).
>>>>> Please let me know if this help to resolve your problem.
>>>>> Best regards,
>>>>> Paul
>>>>>> Hi Neks,
>>>>>> I am using Nek5000 coupled to an Arnoldi algorithm for
>>>>>> hydrodynamic stability computations. In these, I form a vector
>>>>>> of the velocities, which I regularly pass to the Arnoldi
>>>>>> solver. Then, a new velocity vector is formed which is passed
>>>>>> back to Nek5000.
>>>>>> Now, the code works as it is, but in addition to the physical
>>>>>> modes it produces some spurious modes, which I think originate
>>>>>> from the fact that the velocities at the element-common
>>>>>> boundaries are accounted for twice. To fix this, I need to
>>>>>> access the element connectivity information. Can you please
>>>>>> guide me to in which variable this is stored?
>>>>>> In particular, this is what I would like to do:
>>>>>> -  add the element-common points to the local vector only for
>>>>>> one of two adjacent elements (and for a corner point, only one
>>>>>> of the four elements adjacent to it).
>>>>>> - for the vector that Arnoldi returns, make sure that the new
>>>>>> values of the velocity are inserted also for the other adjacent
>>>>>> element(s).
>>>>>> Thanks a lot in advance!
>>>>>> Outi
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
