[Nek5000-users] Add/subtract 1d-mean profile
Fri Mar 9 08:34:30 CST 2012
Hi Jan,
Here are routines that I sometimes use that call avg_all for the list of a dump binary files given in a.list
http://www.mcs.anl.gov/~obabko/avg_fld.usr
Use
     call avg_fld_all
in post-processing mode of Nek5000 (nsteps=0 in .rea) with a created a.list file of your binary .f files (for .fld files uncomment line with p66 & p67 = 4)
Best.
Aleks
----- Original Message -----
To: nek5000-users at lists.mcs.anl.gov
Sent: Wednesday, March 7, 2012 4:10:44 AM
Subject: [Nek5000-users] Add/subtract 1d-mean profile
Hi NEKs,
I'm new to NEK and as a first exercise I'm calculating DNS of turbulent channel flow. So far everything is fine and works as is should.
Now i wanna do some postprocessing with the (binary) files I dumped out. Let's say I wanna look at a single file:
Is it possible to calc the 1d mean of u over the whole channel domain (for example with "call planar_average_s") then take this 1d mean profile and subtract it from u at every point to get u' (=> u'(i,j,k,e) = u(i,j,k,e) - <u>(j))?
As I didn't dump the averages with "avg_all()" the hint given in https://lists.mcs.anl.gov/mailman/htdig/nek5000-users/2010-May/000451.html in this case is not applicable.
Thanks!
Jan Frielinghausen
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
